Question about Central Machinery 9" Bench Top Band Saw
Screeches when I cut wood
How or what to do to make the LOUD screeching noise go away. Ive adjusted the guides and it still does it.
  • 692 Answers
Bearings may be going bad, causing the blade to twist. I believe the noise you hear is the blade rubbing against the wood you are cutting. GOOD LUCK FRIEND.
Posted on Apr 17, 2015
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 114 Answers
Also try waxing your blade with a little bees wax.
Posted on Apr 02, 2015
    Sergeant:
  • 317 Answers
Check the blade for sap - clean it. Make sure you unplug it first. .Check for worn teeth on blade. Give machine a good cleaning. Try cutting at a slower pace. Check blade tension.and alignment.
    Top Expert:
  • Central Mach... Master
  • 50,380 Answers
Open the front and watch it when you turn on sounds like you have a piece of wood stuck somewhere
Posted on Apr 01, 2015
  • Karen Mann Apr 02, 2015
    I contacted the store I purchased the saw and returned it for another one. Brought the new one home, changed the blade and it STILL screekes. Like worse than fingernails on chaulk board. Still dont have any answers.
My car makes loud screeching noise when starting.
could be your serpentine belt. usually when they get worn they will start to either slip or cause a very high pitched screeching noise. to verify that is the cause get some water or brake clean in a spray bottle and spray it on to the belt while the vehicle is running. if the noise goes away for a moment you found your cause. if not then its something else. Hope this helps
May 29, 2014 | 2009 Hyundai Sonata
Screeching noise
Your car needs alignment. The screaming noise comes from tires being dragged over aspnalt. This wears tires very fast.
Nov 18, 2013 | Cars & Trucks
Engine screeches when running. revving the motor makes it stop momentarily
Could be a belt screeching. Fan belt, A/C belt, Serpentine Belt, alternator belt, etc. Easiest way to isolate which belt is to open the hood and use your ears to see where the screeching is coming from. Left, right, front, behind the engine? Spray some WD-40 on the belt you think is making noise and if it quiets right away, then that is the belt making the noise. Either the tensioner needs adjusting or the belt needs replacing. The WD-40 does not hurt the car, it'll start screeching again in a few days when it wears off.
Sep 30, 2013 | 2005 Chevrolet Express Cargo
Loud Screeching Noise & Stopping While Driving
starter bendix is probably bad or it has stripped teeth on the flywheel. the acceleration problem sounds like you were in limp mode
Sep 22, 2013 | 2000 Lincoln Navigator
Loud screeching noise when I turn on a/c
Likely just to be the A/C belt. It may need an adjustment or replacement. With key out of car just smear a little bit of grease (not much) on the belt. Start the vehicle & turn on A/C. If noise gone or quieter the belt is the problem.
Jun 29, 2012 | 2005 Hyundai Tucson
Loud screeching noise upon starting
It is your serpentine belt slipping on one of the metal pulleys and the friction is causing the high pitch screech. The belt may need to be tightened or replaced, which is an easy fix.
Jul 28, 2010 | 2003 Chevrolet Monte Carlo
1999 neon making a loud screeching noise under hood passenger side
It sounds like you have a belt or pulley problem, or possibly a bad bearing in the alternator, or water pump. I would suggest, having it looked at, by a mechanic right away.
Apr 24, 2010 | Plymouth Neon Cars & Trucks
Loud screech noise from deck area
This can be due to a belt slipping or a bad spindle bearing.
And on the difficulty scale,10 being extremely difficult, The belt would be a 1 or 2 and the spindle about 6 or 7 (because the deck usually needs removed for this job)
Apr 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My 1999 malibu screeches loud .
Is this screeching like a sqealing? It will be a belt problem, the belt is slipping on the pulley system you may be able to adjust tension or spray on some belt dressing but will most likely need to change the belt hope this helps you,good luck
Nov 10, 2008 | 1999 Chevrolet Malibu
Central Machinery 9" Bench Top Band Saw Logo
342 people viewed this question
Top Central Machinery Saws Experts
ray gallant
dannydoesita
Alcolu John
Alcolu John
Are you a Central Machinery Saw Expert? Answer questions, earn points and help others
