Question about Toro Lawnmower 20099 Mower Mowers Lawn
I cannot pull the lever back on my Toro Grandstand in order to lift the blade into the height I would like. Would you know how to fix this? Thank you
  • Toro Master
  • 2,540 Answers
Have you ever oiled all the little working parts on your mower? The adjusters also get dry and they rust up or just get dirty. You can try to oil all the areas that move on the height adjusters and see what happens.
Posted on May 03, 2015
5 Suggested Answers
#1 Taper
  • 1041 Answers
SOURCE: toro mower dies when i try to pull out
Disassemble carburetor and spray with carb. cleaner. Use a Den Tek Brush,
(http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Make sure that the small screen is free of debris. Reassemble and start.
If this doesn't work, then you will need to buy a carb. kit and replace all the appropriate parts.
Jim
Posted on Jun 09, 2009
carlsbiz
  • 1124 Answers
SOURCE: how do you start a new toro 6.5 hp lawn mower. I
One lever is to make it go - wheels will turn & pull the mower..
The other lever is to keep it running - it this lever is released it will shut off..
This is the lever you need to keep pushed for it to start..
When starting - there should be a rubber push button on the engine near the carb.. Push it 4 times before starting.. This pumps gas into the carb for quick starts.. Good luck ;o)
Posted on Jul 08, 2009
USMC ETECH
  • 60 Answers
SOURCE: have a toro 217d 1986 model with a 30562 62inch
THIS IS THE WEBSITE FOR THE MANUAL. SO FAR THIS IS THE ONLY SITE I HAVE FOUND WITH THE INFORMATION.
https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=19462&control=SetCommunity&CommunityID=214&PageID=238#manualsResultPage
I HOPE THIS HELPS IF NOT PLEASE LET ME KNOW AND I WILL FIND SOMETHING BETTER.
Posted on Feb 23, 2010
  • 2540 Answers
SOURCE: Hi my toro 20975 dual blade lawn mowers blades
Sounds like you have hit something and bent the frame Did you change the blades if so are they installed the proper way or are they the right ones for that machine. A number of things could have happened.
Posted on Nov 05, 2014
I need a deck lever assembly schrmatic for a toro wheel horse 14-38 hxl
Request the assembly diagram (not a schematic) directly from Toro.
Jun 09, 2017 | Toro Garden
Bought a used Yard Man 13horse power riding lawn mower how to engage cutting blades?
I dont know how yours is set up but most newer mowers have a lever for height and a lever that engages the blades usually on the dash.
Dec 05, 2016 | Yard Man Garden
I have a Toro model number 20622 auto start go forward and backward the blade won't turn it's like it's got a break on it how do I get this to work when I pulled the lever nothing happens
Anon, a lot of these Toro decks do have a type of brake on one of the idler arm and pulley to stop blade. You will have to get a repair/service manual if your owners manual does not show it. Normally can be seen in deck belt installation diagram. If blade brake checks out OK, it is possible one or both blade spindles bearings are seizing.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Lawn Mower Spindle Assembly Replacement Craftsman Lawn Mower Repair...
How to Replace Brake Pads on Mower Cutting Deck
Mower Deck Return Spring Replacement Craftsman Riding Lawn Mower Repair...
Apr 18, 2016 | Toro Garden
LTX 1040. Why doesn't blade lever move when engaging blades?
How's the cable?... when you pull back on the lever, do you have tension?
Oct 11, 2015 | Cub Cadet Garden
How to lift saw blade. My saw is many your old and bought for another. I now need to use it but do not know how to lift cutting blade
The bed moves down so that less blade shows on a skill saw. The locking lever is usually between the blade guard and the handle. Look for a lever and pull it up to unlock, then move the bed down to expose less blade, then push the lever down to lock the bed in place. Please supply a picture of the saw you are using.
Apr 13, 2015 | Saws
How do I change blades on a toro 42 in zero turn
Lift front of machine and secure,
Use a pipe wrench over top of blade and against deck, to keep blade from turning,
Use 1/2 " breaker bar to loosen bottom bolt,
Remove blade,
If the bottom bolt doesn't loosen, you may need a wrench at top of deck, above the bottom bolt, to loosen the bottom bolt.
Replace, or sharpen blades, install in reverse order.
GOOD LUCK FRIEND.
Sep 16, 2014 | Toro 42 In 22 Hp Kawasaki Vtwin...
I need to adjust my scag mower deck
The mower deck can be adjusted from a height of 1.0 inch to 6.0 inches at 1/4-inch intervals. To adjust the cutting height:
1. Disengage the power to the cutter blades.
2. Push the cutting height adjustment foot pedal all the way forward using your right foot until it locks in place
3. Insert the lanyard pin into the cutting height index at the desired cutting height. Push forward on the deck lift foot lever, hold in place and pull back on the deck release lever. Slowly release the foot pedal. A deck height decal is located on the cutting height index as an aid in adjusting the deck to the desired height.
Aug 18, 2013 | Scag STT61V-27CH Hydrostatic, Gas Turf...
Toro 20017 clogs up all the time even if grass is mainly dry.Have moved the height up but still contines to clog
This is not a safe fix,but it works.Tie a string to the top of the chute the grass comes out of.Lift it just a lil and tie off the string.
May 11, 2011 | Toro Lawn Mower With Toro Power Tools
I HAVE A 1999 WHEELHORSE 312 IT WILL NOT START WITHOUT JUMPERING THE STARTING SOLENOID I HAVE REPLACED THE STARTER SWITCH AND SOLENOID AND CHECKED THE RELAYS AND SAFETY SWITCHES
check whatever engages your mower blades. If it has a lever that you lift into place to engage blades try wiggling it while turning the key
Aug 02, 2009 | Toro Lawn Mower With Toro Power Tools
Very little grass is shooting into the bag to fill it
Hello monica_skinn:
If the Underside of the Deck is Clean and the Blades are Tightened Properly, then the Problem is Caused by the Blade Lifts being Worn or the Blades are Not a High Lift (Bagger Blade) Blades.
A Bagger Blade has a Very High Lift Ear on the Backside of the Blade Across from the Cutting Edge. This Extra Lift is What Gives the Extra Lift and Throw (by increasing air Flow under the Mower) the Grass gets to be Bagged.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 11, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawnmower 20099 Mower Mowers Lawn Logo
163 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
