Question about Qca Spas Dream Series Dream Master Hot Tub with Flex Cover
I have this pump modelpf-40-2n22c cam i chang it out for this model numbert55cxcas-1179
  • Qca Spas Master
  • 1,631 Answers
If the water flow according to each pumps spec's match up and the plumbing lines up, with little or no modification, then all is good.
but...
remember this, if the water flow does (GPM's) not matchup, you will ever overdrive your hydraulics system causing premature leaking, or if undersized, your jet action will be diminished!
you can find this information by obtaining the "Pump Curve" chart from each pump manufacturer.
btw... The numbers you provided don't help much.
Make and model name of each pump??
Posted on Apr 02, 2015
Change the oil pump in a f-150 4.6 2002 model
Ford F150 5.4L Timing Chains and Guides Oil Pan Oil Pump ...
? 5:08
https://www.youtube.com/watch?v=BgvGjfzrRjU
May 10, 2014 - Uploaded by dezertol
Ford F150 5.4L Timing Chains and Guides, Oil Pan, Oil Pump, Cam ... i am looking into changing the oil pump myself... did you try removing the intake ... I need help with my timing for i 3v4.6 mustang gt, im about to take of my ...
Ford 4.6L, 5.4L, 6.8L Engines -Melling Oil Pumps - YouTube
Nov 04, 2015 | Cars & Trucks
When to change cam belt on 407 hdi 1600 cc ?
It should be changed every 50000 mile's. When changing the cam belt on these engines be sure to fit a new water pump and pulley's. The water pump most of all. It is driven with the cam belt and they can and do fail. Can lead to complete engine rebuild.
Aug 11, 2014 | Cars & Trucks
T55cxcas-1179
Provide make and model of your pool pump. Emerson is a motor manufacturer. Not pumps.
Jan 12, 2014 | Emerson Pool & Spa
Broken oil pump need to change
Why, why, why do people expect a decent answer if they do not give complete information, in this case MODEL YEAR?
In 1999, there was a change over from the Evolution engine to the Twin Cam engine.
This resulted in a total change of the oil pump.
Up through the Evo, the oil pump was mounted to the outside back end of the motor case, and could be remove - reinstalled/replaced fairly easy.
Starting with the Twin Cam, the oil pump was completely redesigned and move to inside the engine, so you have to go inside to change,
Either way, beings as the oil pump could be considered the "Heart" of the Harley's circulation system, you should know what you're doing if you plan on tackling this yourself.
Dec 07, 2013 | Harley Davidson FLHTCUI Electra Glide...
Emerson Motor model T55CXCAS-1179 230 volt
There should be a wiring diagram sticker on the motor. If not, let me know at questions@oskopoolnspa.com
Jun 03, 2013 | Emerson Pool & Spa
Does a universal remote work with a sony KV-32LS60U?
Hello
Sony TV can be synchronised with [RCA RCR311B] model universal remote control. The codes are:
1001, 1036, 1093, 1135, 1177, 1179
OK.
Aug 13, 2011 | Televison & Video
Windows 7 dirver
Was unsure about the model number of your laptop; is it the Toshiba Tecra S3. Information on how to find drivers and software is here. Unfortunately I do not believe support for Windows 7 is provided for this model.
All available information on the Tecra S3 here.
Please see this bulletin for information on how to use the Toshiba Upgrade Assistant when upgrading to Windows 7. This program may help provide a definitive answer as to whether it would be possible to upgrade.
Dec 31, 2010 | Toshiba S3 Graphics SuperSavage/IXC 1179
Tv goes on but shows nothing on the screen.
Replace the main board (BU board), Part# A-1179-055-D, cost around $85.
Apr 25, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Wacs 7000
Don't know if you still need this, but instructions as follows:
Press Menu
Use down arrow to select Настройки
Then use right arrow to select Язық
Then use up arrow to select English.
Press OK
Now should be in English.
Dec 26, 2008 | Philips WACS700 Shelf System
Qca Spas Dream Series Dream Master Hot Tub with Flex Cover Logo
59 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
