What size is this evaporator coil, trane R384JM9FG
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 23 Answers
3ton,the #38 in model # close to 36.12,000 1ton,24,000 2ton.etc
Posted on Apr 03, 2015
Trane gas furnace TDE060A936Mo what size should cooling coil/ condenser be?
You need to do a heat load calculation on you house to know you unit size. It doesn't matter what furnace you have
Jun 22, 2017 | Heating & Cooling
My ac unit is about 20 years old. it is frosting up now. should i replace it or fix it.
alot of items can cause it to frost up. dirty evaporator coil, dirty impellers on evaporator fan, low on freon, trying to operate system at to low a room temperture will result in pressure drop to a point that will form ice.
Jun 15, 2015 | Heating & Cooling
Where do i find the expansion valve on a 3.5 ton trane air handler. Model no of the trane air handler is: 2TEC3F42C1000AA
The TXV (thermostatic expansion valve) is always at the end of the high pressure liquid line as it enters the evaporator. This is the small line. The outlet of the TXV will usually have 4, 6 or 8 smaller lines feeding proportional portions of the evaporator coil. You have to remove the cover of the evaporator to access it.
Some units do not use a TXV, so you may have a 'fixed restrictor' instead. It too is located where above described.
Apr 28, 2015 | Heating & Cooling
What size is it.R384JM9FG
Multi mode. 62.5 microns
Apr 01, 2015 | Heating & Cooling
What is the correct size for evaporator coils piston ?
.078 is Shipped with Coil
Note: For a properly matched system and piston sizing information, refer to Goodman piston kit chart of the corresponding Goodman
outdoor
unit.
Oct 26, 2012 | Goodman Manufacturing Goodman CAPF3642C6...
Determining the age and size of a Trane evaporator Model # TXH054A4HPAF
The serial number on that evaporator will have the date code in it, the model will tell the capacity (size). It looks like it is a 4 and a half ton or 54,000 BTU coil and has a TXV valve to meter the refrigerant.
Jun 16, 2011 | Ruud UAKA037 Air Conditioner
Can a Carrier 38CKB030300 be replaced with a Trane XE1000 if both are 2½ tons? 'The Carrier unit is older and I'm not sure how much life is left on it. The Trane is newer and claims to be energy...
the tons is the power of the unit, so sure. if you were happy with the power of your old unit, get the same. if you felt it was never strong enough to cool your house, get the next size up. newer units have the same power, but use less energy.
Jun 15, 2009 | Weather King 12AJA4801AH Air Conditioner
Carrier evaporator coil
I recently contacted Carrier Corp after our routine annual HVAC check on our residential system indicated that our 4 ton AC unit and 3 ton unit had leaking evaporator coils.
They basically told me to shove it in a very curt letter - In other words even though a leaking evaporator coil is a manufacturing defect they will not offer any financial assistance in replacing the failed evaporator coils.
I spoke to several HVAC engineers and they indicated Carrier has a high percentage of evaporator coils and compressor failures on residental HVAC systems.
The copper wall of the evaporator coil is being drawn thinner than in earlier years and the R22 being acidic slowly eats through the copper tubing.
Evaporator coils should not fail according to the HVAC Engineers if properly manufactured.
The Bear
May 19, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
