Question about Vtech CS6859-2 Cordless Phone - DECT 6.0 1 x Phone Line - 1 x Handset - Answering Machine - Caller ID - Speakerphone - Backlight
I plug it up to my modem and it works, when I tried plugging my other handset in it says cannot connect. Please help
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 76 Answers
Are they on the same channel?
Posted on Apr 01, 2015
All three were working but 2 of them quit suddenly and say "Check Tel Line". The one that still works is plugged directly into modem. The 2 that say check tel line will work if i plug them into modem just...
This phone system should only have one physical phone jack connection as all the handsets are wireless. It sounds like you may be getting your phone service via your Internet Service Provider. It would help to know how you are connecting your home telephone wiring to your equipment.
Oct 29, 2013 | Uniden DECT1560-3 DECT 6.0 Expandable...
My cable light dont blink
Turn off your modem (unplug it from the wall or surge protector).
Once you have done this, wait for at least ten seconds, if not one full minute. (This allows the modem to reset itself)
Plug the modem back into the wall or surge protector.
The modem will begin its start-up sequence and finally it should respond with a "blinking" connectivity light.
If you have a wireless or wired router connected to your modem you must make certain that you follow the next steps, or the router may not work to provide you with an Internet connection.
1. Unplug the Modem.
2. Unplug the Router.
3. Wait for one full minute.
4. Plug the Modem back in to the wall or surge protector.
5 Wait for the modem to complete its start-up sequence.
6. Plug in the router. (if you plugged in the router the same time you plugged in your modem, start at step #1 and try again...)
7. Wait for the router to finish its start-up sequence.
8. Test the connectivity to the Internet.
If this does not work, please add some clarification as to what service provider you are using, the type of modem/brand, and if you have a router...
I’m happy to help further over the phone at https://www.6ya.com/expert/steven_142d2a6ad692ab09
Oct 22, 2012 | Televison & Video
I have a uniden Tru9466 base station and a uniden TWX 977 that the later that was previously registered with the first displayed a out of range notice so I went thru the process in the owner's manual...
Welcome to FixYa.
  1. Turn OFF your handset (TWX977) and any other handset registered to the base (9466).
  2. Unplug the base from its power source.
  3. Unplug the phone line from the base.
  4. Wait for 15 mins.
  5. Plug back the power source and the phone line.
  6. Turn ON the handset (TWX977)
  7. Reset the handset (TW977) by doing the following:
  • Press the MENU soft key. Select the DEREGISTRATION submenu.
  • ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
  • To clear other handset information, please follow these steps:
  • From the handset, press and hold [ ] and [#] for more than 5 seconds. Select the DEREGISTER HS submenu.
  • Move the cursor to select the handset ID to be de-registered from the list, and then press the OK soft key.
  • DEREGISTER HS appears. Move the cursor to select YES. Press the OK soft key.
  • ARE YOU SURE? appears. Move the cursor to select YES, and then press the OK soft key. You will hear a confirmation tone.
8. Register the handset by doing the following:
  • With the base in standby, press the MENU soft key.
  • Move the cursor to select REGISTER HANDSET. Press the OK soft key.
  • On the handset, press and hold [#] until you hear a beep.
  • While the handset is registering, HANDSET REGISTERING will appear in the LCD. When REGISTRATION
  • COMPLETE is displayed; the handset has been registered to the base. If REGISTRATION FAILED appears,
  • please try these steps again.
Thank you for using FixYa.
Have a great day.
Jas247
Aug 22, 2011 | Uniden TRU9466 Cordless Phone
How ti insatall CDMA Handset modem ?
Here is a Safe Link for you to try.. PLEASE BE SURE TO ALWAYS INSTALL THE SOFTWARE FIRST, BEFORE PLUGGING IN YOUR DEVICE, UNLESS YOU ARE INSTRUCTED TO DO DIFFERENT, OKAY? GOOD LUCK 2 U.. lucky4lynn2 : )
Feb 23, 2010 | Acer Aspire 5100-3357 Notebook
Hi, I'm an idiot! PLEASE HELP
you may be suffering from mixed Cat 5 and Cat 6 cabling.
The wiring is slightly different and they don't work well when mixed in routers and modems etc. One or the other will work , but when they're mixed it'll do what you have going on here...
I would recommend wiring everything with cat 6 ethernet cabling. Look on your cable and you will find the labeling on the outer casing.
Sep 20, 2009 | Computers & Internet
Cant play online on cod HELP!!!!!!!!!!
try to reboot your router and modem.
step one turn off your ps3 and wirelss router if you have one and un plug them.
step two turn off modem and unplug that.
then wait a few mins.
then plug your modem in and let it fire up so that all lights are working and you have your dsl light is solid.
then plug in your wireless router if you have one and do the same. you should then see the activity light on the modem go off and on.
once your router is ready and fired up then plug in your playstation. and go through the set up process. do a test and make sure it at least passes the IP test.
then try it again if that doesnt work get ahold of your internet provider
hope it works for ya!
Jul 31, 2009 | Sony Playstation 3 (PS3) Console
I am trying to use the fax facility on my epson600fw.my isp is aol .Problem no dial tone. What connections are necessary............via printer,modem & computer ?
Typically, a fax machine is connected directly to a telephone wall jack with a known working connection. Try plugging the fax machine directly into a wall jack first and pick up the handset on the fax machine if it has one. You should get a dial tone. Then try to fax something to someone you know.
The machine can also usually be routed through the modem in a computer by connecting the "line" cord on the modem to the wall jack and plugging the fax machine into the the "phone" jack on the modem. You may need to install the software that came with the fax machine to get this to work.
If you have no dial tone, check the wall jack with a known to be working single line phone. If there is a dial tone, it's something to do with fax machine, the computer modem or the connections.
Some fax machines can take advantage of internet faxing through a cable modem or DSL connection. Check your manual for the options available.
Apr 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
No internet connection by using the ethernet cable
Unplug the power to the modem and the USB cable. Plug in Ethernet cable in computer and plug in the modem. Wait for WAN side of the modem to connect and stabilize. If your PC is already on, you should see the network connection appear in the task bar (if it's configured to show up). Open a command prompt. Type 'ping 192.168.1.1' and press Enter. You should get 4 ping responses from the modem which indicates that you LAN connection to the modem is functional.
Let me know if this doesn't work and I'll guide you through other methods to get it working.
Apr 09, 2009 | Arris SURFboard SB5120 Modem
Can't connect Motorola sb5100 to a Linksys wrt54g
Make sure that you have the ethernet cord from your modem plugged into the WAN/Internet port on your router. Then unplug the power cord from your cable modem and plug it right back in. After the modem fully comes back online, unplug the power cord on the wireless router and plug it back in. wait 30 - 60 sec and then try and connect.
Most cable companies only allow one active"CPE" at a time for internet access. All this means is when you change what is connected to the cable modem you must always reboot the cable modem to allow access.
Hope this helps. Let me know if it does not work.
Please Rate
Jan 29, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
ACN Video phone CVP-6000
You'll need to make sure that you allow internet sharing with your laptop and video phone. The phone will not work unless the speed is higher than 128 kbps and usualy needs to be connected to a wireless modem or to a laptop/aircard. If you want more help visit myacn.com/digitalphone/support.
Under hot topics there;s info on how to connect using wireless interent, even tough is not the recomended method , it will work if you follow the steps on there. JSantana
Dec 16, 2008 | Lands Phones
Vtech CS6859-2 Cordless Phone - DECT 6.0 1 x Phone Line - 1 x Handset - Answering Machine - Caller ID - Speakerphone - Backlight Logo
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
