How do I get the Athlon 3200+ to run at 2.2 GHz?
How do I set the dip switches to run at the fast speed?
  • 1,602 Answers
You could look in the bois setting, in the advance section
cpu configuration, 32Bit data transfer, core performance boost, cpu smart fan calibratioon, control mode,shutdown temperature, plug and play OS, chipset menu,
look at software that allow you optimizes your system
glarysoft, glary utilities, DONT BUY ANY, LOOK FOR FREE ONES IF YOU FIND ONE THAN BUY IT.
Posted on Apr 19, 2015
3 Suggested Answers
nuwan chinth
  • 111 Answers
SOURCE: Bus Speed 200mhz instead 1000mhz
PLEASE INDICATE WHAT IS YOUR PROBLEM....
Posted on Jan 09, 2009
  • 289 Answers
SOURCE: Set CPU/FSB speed on KT40A-ANH MB
Don't screw around with jumpers. There are a buttload of fan speed hacks for software on the computer. Google Fan speed hack and you might find one that works.
Posted on Sep 27, 2009
Assassins Creed iV Settings : Very Low But I cant run it good
Does your machine qualify for or above the minimum specification to run the game in all departments?
Minimum system required
CPU: Intel Core2Quad Q8400 @ 2.6 GHz or AMD Athlon II X4 620 @ 2.6 GHz CPU Speed: Info RAM: 2 GB OS: Windows Vista SP or Windows 7 SP1 or Windows 8 (both 32/64bit versions) Video Card: Nvidia Geforce GTX 260 or AMD Radeon HD 4870 (512MB VRAM with shader Model 4.0 or higher) Sound Card: Yes Free Disk Space: 30 GB
Jan 25, 2014 | Activision Spider-Man: Web of Shadows for...
I would like to improve the speed of my PC. Currently running Soyo KT333 dragon Ultra plus; AMD Athlon 2400+ 2.0GHz; 1.5 GB RAM. What can I upgrade to these days?
Hi.
The motherboard has an athlon xp socket, so you can upgrade your processor to an Athlon xp 2800+, that will give you a boost from 2.0 ghz to 2.250 ghz.
The motherboard can accept ddr333 type ram, to a max of 3 gb's of ram.
The ram increase will probably provide you with a better performance boost than the processor will, and it is most likely alot cheaper as well.
I hope this helps you out, and have a good day.
May 30, 2011 | Soyo SY-KT333 DRAGON Ultra Motherboard
Conflict adding RAM memory
you can deselect from BIOS - CAS LATENCY TIMER to value 2, or better (2,5)
Jun 26, 2009 | AMD Athlon XP 2000+, 1.67 GHz Retail...
Fast processor's speed
Your motherboard accepts Socket AM2 for AMD Athlon™ 64FX / 64X2 / 64 and Sempron processors
The board has safe overclocking - so unless you know what you're doing I would stay away from changing any settings manually or you could fry the mobo.
How much memory do you have - more memory can increase speed. Faster HDD
If you want you could go for the Athlon 64,
The Sempron only goes to 2.31 so there wouldn't be much difference in speed.
Apr 25, 2009 | Computers & Internet
How fast does AMD athlon as a modem. as in scrolling the web and searching and application.would it be fast enough in compared to other cpu.
Your cpu isn't what determines your browsing speed, it's the modem that determines that. The faster the modem, the faster the actions.
Feb 17, 2009 | AMD Athlon 64 4000+, 2.4 GHz...
Jan 08, 2009 | ASUS M2N-E Motherboard
E2180 Vs Athlon 64 X2 5000+
depends on what you plan to do with the cpu amd are good but a 3200 may only run @ 1.8 to 3.2 ghz depending while a intel 3200 will run 3.2 ghz.
I believe intel are more stable & run cooler than AMD but AMD benchmarks on Games better but run hotter (so get a good cooling fan & heatsink both pentium / celeron d & intel dou / dual core / core 2 dou and amd x2 have 2 cores (but watch your front side bus and cache the higher the better but the more $ also) then You need a good stable mobo that supports the chip you get (I preffer asus & msi for Gamers and biostar / msi for home users)
Sep 18, 2008 | AMD Athlon 64 X2 4600+, 2.4 GHz...
Processor upgrade
Need to look at the motherboard specs along with the processor "Socket". It will usually be a 754 or 939 depending on what your motherboard says. I wouldn't try too fast and set yourself up for disappointment. I would upgrade the RAM before the processor.
Mar 22, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Upgrading processor
i think that the FSB needs to be set at 133 as this relates to your memory timing and im guessing your ram will be sdram, apologies if it's ddr, but you will find that you can up the cpu speed within the bios, in small increments. Don't forget the speed of athlon processors does not match the model number, the 2400 means it will be the equivelant of a pentium 2.4 GHZ, but it will probably show a GHZ rating of 2 or 2.2 Also try reseting the cmos by shorting a clrcmos2, clrcmos,clrrtc or putting the jumper from pins 1-2 to pins 2-3 then back again if it's a JBAT1 terminal, depending on your board.
Jun 13, 2007 | Asrock K7S41GX Motherboard
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
