Question about ASUS A7V400-MX Motherboard
I replaced the Sempron 2500 1.8ghz with Athlon 3200 2.2ghz, how do a get the motherboard to run at that speed?
The 'system properties' still show the speed at 1.83 ghz. what can I doto get it to run faster? Joe
    Brigadier General:
  • ASUS Master
  • 3,400 Answers
ASUS LIST OF CPU-SUPPORT
Posted on Apr 04, 2015
What can i use processor in this motherboard can i use 1.8 mhz
Processor speed 1.8 MHz is not the parameter for using this kind of motherboard. Upgrading or replacing CPU on motherboard is based on the socket CPU, and your motherboad support AMD® Socket AM2 Athlon 64 X2 / Athlon 64 FX / Athlon 64/ Sempron....
Aug 06, 2011 | ASUS M2N-MX Motherboard
Can u upgrade the processorto anything high then a amd duron(tm) 1.29ghz
On this motherboard you can use:
AMD Athlon (Highest being the Athlon 1400C running at 1.4GHz)
AMD Duron (Highest being the Duron 1800 running at 1.8GHz)
AMD Athlon XP (Highest being the Athlon XP 3200+ running at 2.3GHz)
AMD Athlon MP (Highest being the Athlon MP 2800+ running at 2.1GHz)
AMD Sempron (Highest being the Sempron 3300+ running at 2.2GHz)
Feb 25, 2011 | EliteGroup K7SOM Motherboard
Yea i need to purchase a new processor chip the motherboard is a 754 socket my pc takes a 3100+ amd sempron processor my pc is 1.8ghz im just not sure what to buy some say they are 64 bit and this one is...
please purchase the processor that is compatible to your motherboard. if the motherboard can be upgrade to a higher speed of processor then purchase it. if not, stick to the required specs. if you still want to upgrade, replace the motherboard, processor and the memory.
Mar 23, 2010 | Computers & Internet
Can I put a dual core processor on my Chaintech S1689 mother board--Athlon 64 FX w/ 939 socket? I don't think my CPU fan is working and I need to replace it.
Form Factor: ATX (305mm x 200mm)
CPU: Supports Socket-939 Athlon 64 / Athlon 64 FX and Dual-Core (X2) / Sempron with the new v6.0 BIOS and above. Processor interface via 2000MT/s HyperTransport bus.
Chipset: ULi M1689
Main Memory: Four 184-pin DDR DIMM up to 4GB Supports Dual Channel DDR266/333/400 memory.
Expansion Slots: X4/X8 AGP Slot and Five 32bit PCI Slots (v2.2 compliant)
Audio: Realtek ALC850 with 8 Channels
SATA: Supports 2 Serial ATA devices for the highest data transfer rates (1.5Gbps burst) with RAID 0 & RAID 1 solution.
UltraDMA IDE Ports: Supports 2 UltraDMA-66/100/133 IDE ports
FDD: One FDD connector supports up to 2.88MB
USB 2.0: Supports total 8 USB2.0 ports with High-Speed Devices at 480 Mb/s Transfer Rates
System monitoring: Two Temperature and Fan Sensors for CPU and System
Jun 01, 2009 | AMD Athlon 64 Socket 939 Chaintech S1689...
Cpu
If functioning correctly, your motherboard will support the following types and speeds of CPU's
  • Supported Processors:
  • AMD Athlon XP/Sempron/Duron
  • Socket A processors
  • 200/266/333 MHz FSB
So likely it tops out at Athlon XP3000+ /333MHz
or
Sempron 3000+ socketA/462.
May 31, 2009 | SIS741GX-MN Motherboard
Fast processor's speed
Your motherboard accepts Socket AM2 for AMD Athlon™ 64FX / 64X2 / 64 and Sempron processors
The board has safe overclocking - so unless you know what you're doing I would stay away from changing any settings manually or you could fry the mobo.
How much memory do you have - more memory can increase speed. Faster HDD
If you want you could go for the Athlon 64,
The Sempron only goes to 2.31 so there wouldn't be much difference in speed.
Apr 25, 2009 | Computers & Internet
IS MCP61S THE SAME AS NF61S MICRO 754
Biostar offers NF61S MICRO 754 Motherboard + AMD Mobile Athlon 3200+ (COMBO56), NF61S MICRO 754 Motherboard + AMD Mobile Sempron 3300+ (COMBO56A),NF61S MICRO
Motherboard Processor:
Socket 754
Supports AMD Athlon 64/Sempron Processor
Support AMD HyperTransport up to 1.6G
Supports AMD Cool'nQuiet Technology
• Chipset:
NVIDIA MCP61S(GeForce 6100/nForce 405)
they are the same motherboard .hope this helps pls appreciate by rating it as fixyaa
Oct 10, 2008 | Computers & Internet
Maldonado223
best processor
AMD Athlon, Athlon XP, Duron, and Sempron processors
200 / 266 / 333MHz front side bus
for further information visit the link
http://www.biostar-usa.com/mbdetails.asp?model=M7VIG+400
Jun 26, 2008 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
How to upgrade
Here is the list of compatible processors for your motherboard:
AMD Athlon 650, 700, 750, 800, 850, 900, 950, 1.0G, 1.1G, 1.2G, 1.3G, 1.33G, 1.4G (Thunderbird)
AMD Athlon MP 1.0G, 1.2G, 1500+, 1600+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon MP 2000+, 2200+, 2400+, 2600+ (Thoroughbred)
AMD Athlon MP 2800+ (Barton)
AMD Athlon XP 1500+, 1600+, 1700+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon XP 1600+, 1700+, 1800+, 1900+, 2000+, 2100+, 2200+, 2400+, 2600+, 2700+, 2800+ (Thoroughbred)
AMD Athlon XP 2500+, 2600+, 2800+, 3000+, 3200+ (Barton)
AMD Athlon XP 2000+, 2200+, 2400+ (Thorton)
AMD Sempron 2200+, 2300+, 2400+, 2500+, 2600+, 2800+ (Thoroughbred)
AMD Sempron 2200+, 2400+, 2500+, 2600+, 2800+ (Thorton)
AMD Sempron 3000+ (Barton)
AMD Duron 600, 650, 700, 750, 800, 850, 900, 950 (Spitfire)
AMD Duron 1.0G, 1.1G, 1.2G, 1.3G (Morgan)
AMD Duron 1.4G, 1.6G, 1.8G (Applebred)
You motherboard uses a "Socket A" CPU and therefore has limits to how high you can go.. I would recommend the XP 2200 or 2400+ as a good choice, but you can make your own choice.
Apr 03, 2008 | AMD Duron , 750 MHz Processor
Sempron 2800 cpu speed
hey, here is the latest bios witch is required for your new sempron!
http://download.aopen.com.tw/userdownload_List.aspx?RecNo=9923&Model=vKM400Am-S
Dont foget to rate the solution as fixya! Thanks
If you need more assistance let me know, I'm here to help
Apr 02, 2008 | AOpen vKM400Am-S Motherboard
ASUS A7V400-MX Motherboard Logo
50 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
