Gigabytes BIOS flash instructions - Computers & Internet
    Top Expert:
  • 1,144 Answers
Which is smaller, gigabytes or megabytes
megabits is smaller
if you want to back up 2.83 gb get a usb flash drive
get a 5gb unit
usb sticks (flash drive) rated at 5 gb will hold 4.5 gb of data as the rating is the total capacity but all flash drives require a small amount of space to work so the actual amount of data capacity is always less than the stated size on the flash drive
the capacity rating is-- smallest to largest --bytes, mega bytes , gigabytes, and terabytes
Nov 05, 2016 | Computers & Internet
Pavilion 9700 bios amd
There is no such thing as a BIOS driver. BIOS instructs hardware during boot. BIOS should only flashed if there is a TRUE problem. Not recommended.
http://www.techrepublic.com/blog/10things/10-common-mistakes-you-should-avoid-when-flashing-your-bios/357
Oct 04, 2012 | Computers & Internet
I can't find the bios flash instructions .how do you flash the bios on my toshiba a35s159
You should check the Toshiba WEB site for instructions to how to upgrade (flash) your BIOS, if you make a mistake you may not be able to repair or recover from your mistake.
I have done BIOS upgrades on a few computers.
If your Toshiba has a floppy drive and you can boot up from this floppy drive then the BIOS upgrade needs to be downloaded to a boot floppy. Then boot up from this floppy and run the BIOS upgrade program. When completed, remove the floppy disk and boot up your laptop.
YOU MUST CHECK THE TOSHIBA WEB SITE AS THESE INSTRUCTION MAY NOT BE APPLICABLE FOR YOUR TOSHIBA LAPTOP.
Jun 02, 2012 | Toshiba Computers & Internet
Asus f5 bios download
If you don't know what you're doing flashing the bios can really screw things up. You might already be at the latest bios version, so be sure to check it.
You would get the bios driver to flash it from the manufacturer's website and follow the instructions.
Get online and got to www.google.com In the google search box type: "ASUS Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the BIOS drivers. There will be instructions on flashing the bios. Also check your current bios version.
May 16, 2012 | ASUS Computers & Internet
I have a DFI LANPARTY UT nF4 Ultra-D and have been been unable to use all of the memory slots. I originally bought 4GB but have only been able to use 2. Is there a setting that i need to enable?
Hi, you can use up to 3 gigabytes on windows xp 32 bit with service pack 3.
You need a 64 bit operating system to use 4 gigabytes of ram.
Here is some info:
CPU
AMD Athlon 64 FX / Athlon 64 / Sempron Socket 939
Chipset
NVIDIA nForce4 Ultra
Front Side Bus
2000MT/s
HyperTransport interface
Memory
Four 184-pin
DDR SDRAM DIMM sockets
Supports dual channel (128-bit wide) memory interface
Supports up to 4GB system memory
Supports
DDR266, DDR333 and DDR400 DDR SDRAM DIMM
BIOS
Award BIOS
CMOS Reloaded
CPU/DRAM
overclocking
CPU/DRAM/Chipset overvoltage
4Mbit flash memory
Aug 30, 2011 | DFI LANPARTY UT nF4 Ultra-D Motherboard
Get message "bios not loaded"
Hi there, Your bios is damaged. You will need to re-flash your Bios to get your board to work again. You can download your BIOS and BIOS Utility for your board at this site below. http://support.asus.com/Download.aspx?SLanguage=en&m=P4C800-E+Deluxe&p=1&s=15 Just follow the instructions and be warned sometimes flashing a bios wont work and then your board will be useless so follow the instructions to the DOT.
Hope it helps regards,
Jul 28, 2011 | Intel ASUS P4C800-E Deluxe 875P Socket 478...
Main BIOS checksum error Retrieving recovery source from HPA .............. ..................
download bios and flash whit program if not u have programer creat floppy disk then power on press enter
Dec 24, 2010 | Gigabyte GA-G31M-ES2L Motherboard
Scanning BIOS Image in Hard Drive
Your BIOS to your GA-8I848P-G Motherboard would be flashable to the BIOS chip on the Board it's self. Make sure you read Gigabytes BIOS flash instructions. If the board is up and running Windows, then Gigabyte has there LIVE BIOS update you can run from there website!
Good luck..
Thanks for visiting FixYa.com
Nov 11, 2010 | Gigabyte GA-8I848P-G Motherboard
BIOS flashing problem. Latest BIOS from Biostar site is on flash drive, F12 during POST opens the flash screen, file is selected; but then the process hangs at blinking message "Reading file, please wait",...
If I am right, writing Bios files isn't possible with your Motherboard Bios Flash Memory. I've done updating bios on many motherboards, but most of them can't be written, when I contact the manufacturers, they only say that I must have done something wrong, following the instructions, but with the same instructions and procedures, it worked on some motherboards. Not all motherboards support flashing bios, since some bus and flash memory are faster and some are not. Sometimes your pendrive (flash drive) creates this problem, so I would suggest you to use another flash drive. I hope you did format the flash drive before you write the Bios updates files, if not, you should do it and you have to write the files on an empty drive.
(This isn't a solution, only an assistance, if this doesn't help, you can still ask for another expert's help)
Good luck.
Thanks for using FixYa.
Aug 05, 2010 | Computers & Internet
I want to install xp on the slave HD but i cant...
DFI is the board manufacturer. They may or may not offer support since this is a really old board by computer standards. Hope this helps.
Mar 04, 2009 | DFI CA61 Motherboard
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
