Question about Miscellaneous
Where can I get a replacement screw in fuse cap for my p-701???? This ish is crazy!!!!! I've searched every possible avenue on the internet and I can't find any contact #'s for this company!!!!! Wack!
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Shoot I think I have a couple of those.
Posted on Apr 01, 2015
Tip
How to make an inexpensive "shelf" for books
Plumbing piping can actually be used <i>outside</i> of the walls. I've seen and done things myself using metal plumbing piping as decorative yet effective tools. I've seen them as curtain rods, lighting fixtures and legs for tables.<br>My favorite, though, is screwing them into walls and using them as shelves for books. You can make all kinds of crazy patterns and designs using extensions. Google plumbing and shelves. See what you find!
on Jul 18, 2013 | Furniture
Stalls on acceleration
I've seen lots of things cause this problem, without seeing the car i cannot give you an absolute fix. but i can give you a list of possibilities.
clogged fuel filter, partly clogged catalitic converter. bad air fuel mixture solenoid, marginal coil pack, clogged pickup screen in the gas tank (on the fuel pump), Corrosion in the distributor cap. Falty ECM. vacuum leak (around the EGR circut) to name a few. You can try and pull trouble codes off the ecm by grounding the A and the B pin on the ALDL connector refered to now as the OBD connector.
to do this you need a paperclip. ground pin B to Pin A turn ignition on and the check engine light will flash a series of 2 digit codes which you can look up on the internet or in a service manual.
Oct 19, 2012 | 1992 Buick Park Avenue
The windows wont go up on my 1996 buick park avenue i need to know where the fuse for the window is and other possible problems
I have an '03 buick regal and I've had window regulator problems, as many other buick owners have. After the third regulator breaking, and close inspection of broken pieces, every regulator failed and broke in the same identical spot. The weak part is on the regulator guide where the end cables connect in a plastic "housing". On my latest replacement regulator, before installing I made a small re-inforcement piece out of aluminum to back up the weak plastic piece. I've had no problems or breakage since. So I also took apart the other 3 window regulators and upgraded them before they broke...again.
Aug 20, 2011 | 1996 Buick Park Avenue
Need to find heater blower resistor on 1991 Buick Park Avenue
GM: Electra/Park Avenue/Ninety-Eight 1990-1993 REpair Guide
Blower Resistor Module
Fig. 1 Blower resistor assembly is underneath the fuse block
REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable.
  2. Remove the rear sight shield.
  3. Remove the fuse/relay block assembly and bracket.
  4. Disconnect the resistor module connector.
  5. Remove the retaining screws and remove the resistor module.
To install:
  1. Inspect the gasket and replace or repair as required.
  2. Install the resistor module and secure with screws.
  3. Connect the resistor module connector.
  4. Install the bracket and fuse/relay block assembly. Install the sight shield.
  5. Connect the negative battery cable, and check the climate control system for proper operation.
Hope this help (remember rated and comment this).
Mar 29, 2010 | 1991 Buick Park Avenue
Na virus un asus 701 laptop ko. pina format ko pero ayaw gumana un LAN at un wireless internet connections
HI...
MAG-DOWNLOAD KA NG DRIVER SA LAPTOP MO. IT'S THE ONLY WAY SEARCH MO "ASUS 701 DRIVER DOWNLOAD" SA SEARCH ENGINES...
GOODLUCK!!!
Jan 04, 2010 | ASUS Eee PC 701 Notebook
Unable to open yahoomail in safarie or internet explorer
Yahoo! INTERNATIONAL Help Form @ http://help.yahoo.com/l/us/yahoo/edit/intl.html?from_url
YAHOO HELP @ http://help.yahoo.com/
Yahoo! Inc.
701 First Avenue
Sunnyvale, CA 94089
Tel: (408) 349-3300
Fax: (408) 349-3301
Yahoo Customer Care
866-562-7219
408-349-3300
(408) 349-1572
8am - 5pm M-F (Pacific Time)
Nov 30, 2008 | Yahoo Mail
Miscellaneous Logo
19 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
