SOURCE: updates
Dear Customer,
you have to check your HDD of your PS3 cause this type of error only occured when HDD have some bad sector related to data writing to that place,
so try to replace your drive with another having to your friend than make copy of that or repair with recovery bad sector software for your ps3 HDD,
try & get fuunnn,
THNX
SOURCE: PS3 can't detect access point
i have some solutions..
1. if there's lots of walls between the router and your ps3 it may not detect the signal. i had a very weak signal until i moved some stuff around.
2. you can manually type in your wireless name and i think it should at least reconize it, and maybe connect.
3. make sure theres no firewalls or anything to block other connections from entering your signal.
thats all i can say, sorry im not a tech guy-only 17!
SOURCE: trying to ps3 online
i had the same problem to solve, i got an ethrenet cable and changed the settings from wireless to cable it then worked amazingly quickly. hope that helped
SOURCE: keep gettin error code 80710723 when updating system on ps3
mae your playstation 3 wired then download it. once downloaded then go back to wireless.
SOURCE: trying to update ps3 keep getting error 80710723
Hello woiworrung
This error is a timeout when trying to connect to the network server. This is due to either a slow connection or high traffic from your internet service provider (ISP).
Keep trying and different intervals during the day. If you´re still having problems, contact your ISP and ask them to check your internet speed.
If they report no problems, then it probably has something to do with your own network. I can try to help you further, but I will first need to know what type of connection you are using, e.g. wired/wireless.
Hope this helps. Good luck!
ajblaj
