Question about Kyocera Cell Phones
My virgin mobile Kyocera Qualcomm 3g/4g how to make it only4g LTE
    Top Expert:
  • Kyocera Master
  • 50,296 Answers
No way can it be done .
Posted on Apr 28, 2015
  • 4 Answers
SOURCE: unlocking my virgin mobile wildcard
if you buy any virgin mobile phone the lock code is always the last 4 digits of your cell number if you buy it used from someone then you have to either get the last for digits of their number or take it in to virgin mobile and have then change it for you
Posted on Dec 25, 2008
SOURCE: Virgin mobile locked my phone during assistance.Can you unlock?
SIR, MY VIRGIN MOBILE LOCKED , CAN U UNLOCK MY PHONE
Posted on Jul 10, 2009
SOURCE: I am looking for a manual for the kyocera qualcomm
Try turning it on and off, that should stop the beep.
Posted on Aug 17, 2009
  • 161 Answers
SOURCE: forgot my virgin mobile kyocera unlock code
you may try some default codes......
Posted on Oct 22, 2010
SOURCE: My Kyocera S1300, Qualcomm 3G CDMA isnt allowing
Ftm mode
Posted on Sep 13, 2011
Get 4G working again after last system update on a Samsung Galaxy Core Prime on the Virgin Mobile network. It's a Virgin Mobile phone and does not require a SIM card.
Try rebooting the phone. If that fails you may need to have virgin re authorize the phone. It may even require factory reset. Make sure you back up any data...photos, contacts, etc. First.
Nov 12, 2016 | Samsung Cell Phones
How do i factory data reset my kyocera Qualcomm 3g/4g phone?
http://cellphoneusermanuals.com/download-online/how-to-factory-reset-a-kyocera-qualcomm/
Mar 21, 2016 | Kyocera Cell Phones
I have a 4G LTE phone that is only picking up 3G service in an area confirmed to have 4G LTE service. LTE setting on phone is enabled. Mobile Network access points configured correctly. Turned on "Airplane...
Check to make sure that the 4g is configured properly on your phone first. I don't know your phone, but even if you toggled airplane mode nothing would have changed if 4g wasn't enabled to begin with. If that doesn't work, try contacting your carrier.
Mar 10, 2015 | Cell Phones
Samsung s4 I deleted the apn on accident how can I get them back
Every carrier uses its own APN Settings to get its 3G/4G LTE network working on an Android smartphone or tablet device. Now, these APN settings are usually "downloaded" automatically to your phone when you insert a SIM card. BUT, there are times where the APN are not selected automatically OR when the APN settings are not downloaded.
In those instances, your 3G/4G LTE data will not work but that can easily be fixed.
Step 1. First, browse your Settings menu and find the "Access Point Names" menu. This is usually under "Mobile Network Settings" or "More Mobile Networks" or "Mobile Networks" under Settings menu depending on the Android device used.
Step 2. Once you are in the APN Settings menu, first thing you should check it that the APN is on the correct one. If the correct APN is not checked (sometimes this happens), simply check ON the correct APN for your carrier. That will make your 3G/4G LTE data working right away.
Step 3. There are also times where the wrong APN is listed or there's simply no APNs listed. In these rare cases, you can simply add a new APN, hit the "+" button. 25264381-evzu5111kn4ie1titkzzffdn-4-2.jpg
Step 4. For APN setting, the "Name" can be anything. "APN" setting is the most important, usually you only have to fill this out for your phone to work.
Step 6. Hit "Save" when done.
Step 7. Next, make sure to select the new APN Setting you have saved. Within 5-30 seconds, your phone should start picking up 3G or 4G LTE signals and your data should be working again on the phon 25264381-evzu5111kn4ie1titkzzffdn-4-14.jpg
Nov 01, 2014 | Cell Phones
LG Mach LS860 won't connect to 4G
I alsohave a sprint service plan, it sucks but it works when it wants to. the issue with the 3g and 4g with sprint is this. wherever you friend is located and the towers that are around she will be able to get 4g signal, if not then the phone/ network will automaticaly go to 3g as a backup. this would explain why shecan still send and recieve txt and make calls still.
try going into system setting , under share and connect tap more then scroll down to mobile networks, she cant adjust the 4g settings because its automatic. She can then choose network mode and set it to to CDMA aka 3g. when she chooses this the phone will operate in 3g mode. The net will be a bit slower than 4g , but it'll work. now when she goes out of that dead zone into a area where 4g is available then she can repeat this process and switch back over.
LTE/CDMA is what the Sprint network is running on most of the time though. CDMA= 3g
LTE=4g
CDMA+LTE= 3g and 4g switching automaticaly.
good luck
Feb 16, 2014 | LG KM555 Cell Phone
8ta 2gb sim package giving limited service error with zte mf820 lte usb modem. Same sim works on 3g in BB9810 mobile phone in same area. same in different telkom mobile areas. Modem works on 3g with Mtn...
You may need to upgrade to a newer sim card. There have been changes recently, esp. with the broader adoption of, and newer versions of LTE. LTE is a whole different radio system than 3g or even 4g. (It is actually 3g on super steroids) I think a sim upgrade should fix the problem.
Aug 11, 2013 | Lantronix LMR 8TA (LMR8TA-02) Networking...
Virgin Mobile Overdrive 3G/4G Pro won used on eBay and cannot activate.
They are correct. You will need to replace the SIM card.
May 27, 2013 | Computers & Internet
May 25, 2009 | Kyocera Cell Phones
Cell Phones Logo
107 people viewed this question
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
DROPNDEAL
DROPNDEAL
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
