Question about Bunn Tea & Coffee Maker Infusion Series ITCB-DV 29
Bunn s series water cames out cold - Bunn Tea & Coffee Maker Infusion Series ITCB-DV 29
    Top Expert:
  • Bunn Master
  • 48,461 Answers
Heating element went bye bye
Posted on Apr 01, 2015
Bunn CW Coffee Brewer not brewing enough coffee - amount is half
Have you cleaned lately, put in an empty filter and fill with cold water with a tablespoon of white/clear vinegar. Run the brew cycle, empty pot and while still worm fill with cold water again with out vinegar. Than check filter to see how much hard water chunks are in the filter. Repeat with and without vinegar tell filter is clean. One question though is there a lot of steam coming out of the top during the brewing cycle if so inside there is a tube that may be cracked, broken or came loose, have to look inside. requires opening or disassembling unit to check. REMEMBER when taking apart UNPLUG unit first.
Nov 17, 2015 | Bunn CW Aps Single Airpot Coffee Brewer,...
Bunn coffee maker leaks
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
Jun 17, 2014 | Bunn VPR Coffee Maker
Bunn VPR Series Coffee Maker will NOT dispense the water into the coffee pot?
This machine has a reservoir that holds about 2.5 pots and keeps them at brewing temperature. Therefore you should pour in 3 pots (with a pot in place under the filter basket) until water flows from the basket. Then, and ONLY then, it is safe to plug in the brewer. If you plug in the brewer BEFORE filling the reservoir you will burn up the heating element and will have to have it replaced.
After the initial filling and heat up (about 20 minutes) you are ready to pour through a pot of COLD water through and brew.
Sep 10, 2010 | Bunn VPR Coffee Maker
I have a Bunn VPR, it brews fine for a couple pots
Try running a quarter-pot 50/50 solution of white vinegar and cold water through to clean out calcium deposits in the pump system. Use a clean filter to catch the pumped debris. When pumped through, let cool somewhat, and reuse the cold mixture again twice more. Pour out the vinegar solution and run several cold water loads through to wash out the taste. Hope this helps!
May 24, 2010 | Bunn VPR Coffee Maker
I haveBX-B . I had the pot set up for me to push the on button for Monday Morning, but the water ran throug and it was not on.So now I have cold coffee in the Decanter.
The Bunn coffee maker does not operate as most coffee makes do. You cannot leave the Bunn in the off position and then just flip the switch to on and pour the water in. You will always get cold coffee if you do this. It takes time for it to heat the water. The On/Off switch should be left in the On position all the time. This keeps the water hot in the tank, thus providing hot water when you need to make coffee. You then just pour the cold water in the top, shut the lid, and have a pot of coffee in 3 minutes. The On/Off switch is a vacation switch, and you use it only when you are not going to use the coffee maker for a couple of days. Older Bunn coffee makers did not even have an On/Off button. You simply unplugged them when going on vacation. So turn the switch to the On position and leave it there. The unit will then work as designed. Forget how other coffee makers work, this is a Bunn and it is the fastest coffee maker you can buy and must be left on all the time. that way the water stays hot and the unit will keep it that way.
Nov 16, 2009 | Bunn BX HOME BREWER 10-Cup Coffee Maker
The Bunn CW Series overflows the pot. How canwe
Open the front panel, there is a set of instructions on it, you will have to make sure the board is set to program and not lock, before you adjust.
Aug 14, 2009 | Bunn NHB Coffee Maker
Bunn Series VPR, pour water in, water comes out cold
Test that you have it plugged into an operating outlet.... Check that all of the switches are "on" (the warmer and the heater switches). If this doesn't help, you'll need to unplug the unit and test the switch and element for proper operation. Both can be tested for continuity. If they all test good, then I'd suspect the thermostat.
Good luck and best regards, --W/D--
Jul 18, 2009 | Bunn VPR Coffee Maker
Bad tasting coffee
you can always clean a coffeemaker with vinegar, but always pour in cold, so you can do it twice or more, but dont re-use the stuff you just used, wait till it's cold or just use some other.after use clean by let water through 2 or 3 times, (also only cold water)
Jan 28, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Bunn Coffeemaker CWTF35-4
Hook it up to cold water. It has a heating element in the tank that heats the water.
Oct 24, 2007 | Bunn RL Coffee Maker
Coffee Makers & Espresso Machines Logo
93 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
