Question about Hampton Bay Dryers
Remote works with fan but not with the light (I changed the battery)?
    Genius:
  • Hampton Bay Master
  • 1,617 Answers
Try different bulbs. Also, if the light kit has a pull chain, make sure it's in the on position. Lastly, check the light wires at ceiling & fan to make sure the didn't come disconnected.
Posted on Apr 01, 2015
Hampton Bay Chateau Deville with remote stuck in high. Remote works fine for light with dimmer, but will not turn off fan or change speed. Stuck on high.
When you had the batteries out of the remote, did you press all the buttons to be sure one is not stuck? Also, this could be a button failure.
Nov 21, 2013 | Hampton Bay Ceiling Fan. Chateau Deville...
Set up remote on harbor breeze
Check the frequency on the receiver & transmitter to make sure they match.
Mar 29, 2013 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan remote will not turn off light it just dims the light
Try this. Remove power from the fan. Remove batteries from the remote. Press butttons on remote (might be stuck). Apply power to the fan. Install batteries in the remote and try all functions. If this doesn't work, the remote may be defective or the remote receiver may be defective. I can tell you from my own experience I have a ceiling fan that loses its mind whenever there is a power outage. Has to be reeducated from scratch
Oct 06, 2012 | Hunter Ceiling Fan Remote Transmitter...
Remote quit working for litex ceiling fan
after changing the batteries make sure you didn't change the remote code. If you didn't there should be a reset button inside the battery compartment, it may just look like a small hole. Just use a toothpick and insert it into the hole and lightly depress the reset switch.Replace the battery cover and try using the remote again.
Apr 13, 2012 | Casablanca Fan Dryers
My light works works from the siwtch but my fan will not come on.
Have you changed the batteries?
If they are low on power you may get an Led to light up but not a strong enough signal to operate the fan
Jul 20, 2009 | Hunter Ceiling Fan Remote Receiver...
Need instruction page for the Hunter light/fan remote control
There is a battery in the hand held remote and another battery in the receiver which gets tucked into the ceiling mount cover. Remove the ceiling cover and you will see the battery there, usually a 12 volt battery.
The upp/down slide is a dimmer.
In the event that changing the batteries doesn't solve your problems, Hunter makes replacement remote sets, available at Home Depot, lowes, etc and usually around twenty dollars.
May 31, 2009 | Hunter Ceiling Fan Remote Transmitter...
Remote not working at all
Check the fan and the remote to see the code switches are same. Sometimes depending on the age and humidity you may have to slide the switches back and forth to clean the contacts. Did it ever work? Are the batteries in the proper polarities? The fan and remote have to have the same numbers picked to operate properly.
Nov 16, 2008 | Hampton Bay 48670 Flemish Pewter Finish...
Remote control stopped working
Under the dome (where the electrical connections are) is the receiver unit for the fan. It could be that it is no longer working. Also the remote may have dip switches to change the frequency channel (sometimes located behind the batteries) check that these have not been changed or check they correspond to the receiver unit on the fan.
Jul 22, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Dryers Logo
50 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
