Question about Verona Kitchen Ranges
My oven won't light after years of flawless use. The ignitor clicks and the flame ignites, but won't stay lit when release knob.
SOURCE: burner will not stay lit
Presuming the flame is touching the thermocouple, try putting slightly more pressure on the knob and hold for a few seconds longer. If this doesn't work try going through the same process with the knob removed - if this works you need to put a small piece of packing in the shaft of the knob ( a small piece paper might do). If this fails you need a new thermocouple.
Posted on Nov 18, 2007
SOURCE: Nexgrill patio heater won't stay lit
I called Nexgrill technical support at 1-800-913-8999. They are sending me a new thermo couple to keep the valve open when ignited - so the patio heater will stay on. I needed to give them the serial number (inside the propane tank door) and fax them a copy of the receipt.
Hope this helps.
Posted on Jul 18, 2008
  • 333 Answers
SOURCE: dyna-glo rmc-fa100a won't stay lit after releasing pilot knob
You should hold the pilot knob in at least 1 to 2 minutes, if it still goes out you need to replace the thermocouple. I hope this helps you out.
Posted on Nov 29, 2008
huuum
  • 750 Answers
SOURCE: top burners often wont light if oven is already lit
Hello and welcome,
If your range has electronic igniters, then you seem to have one or more bad igniters on top of the range if you have a pilot range then you have a gas restriction or clogged orifice tube.
Even if they make the click noise while trying to light they may not get hot enough to draw the gas on a constant speed!
This will need to be diagnosed hands on at your location.
But this is the fault!
Thank you for using fixya.
Huum
Please remember to leave a solved rating before you leave!
Posted on Dec 07, 2008
TheMobilian
  • 8220 Answers
SOURCE: ignitor works but stays lit!
That is the way it works. As long as the burner is on the ignitor will also be on. Want to see why?
Click here To see the circuit in motion
Posted on Dec 22, 2008
Oven won't stay lit after ignition. When knob released, gas goes of.
Cookers have a flame failure safety device. Yours may be faulty.
They are designed so that if the flame goes out then the gas shuts off, but it may think there is no flame and keeps shutting off despite it being lit.
Will need an expert on this I think.
Feb 14, 2016 | Kitchen Ranges
Oven lights but then flame goes out as soon as I release the knob
The flame sensor seems to be bad.
When I light my pilot light, it stays on till I release the button ...
askville.amazon.com > Home > Home Improvement
Mar 18, 2008 - Similar Questions: light pilot stays till release button suggestions ... If you have held it for a long time and it still won't stay lit, then your thermocouple is bad.... the gas valve doesn't think a flame is burning the gas coming out of the pilot ... less likely but somewhat common is the gasvalve... if the knob you are ...
Troubleshooting Gas Range and Oven Problems ' Back ...
blog.etundra.com > Tundra's Tech Talk
Dec 15, 2015 | Fisher Paykel Fisher & Paykel 24-in...
Push knob in on oven sparks & lights release knob flames go out
Often on ovens you have to hold the knob down for a period of time before the flame will stay alight.
Try getting the oven lit then holding the knob down for 30 seconds. That should be more than enough time if that is indeed the problem.
Is it a new oven or has the problem just arisen? It
Jul 23, 2015 | Ovens
My becko gas cooker is new and when i turn the oven on the hob ignitors keep clicking what do i do pls
So when you are turning the oven on, It is the same process as your cooktop. you turn the knob to ignite( so its clicking) and once it catches fire you back off the knob to adjust your flame. the oven is the same. its just bthat all your igniters will want to light at the same time, but gas is only being fed to the location of whatever knob your turning. omnce oven is lit, turn back the knob to dedired temp setting. hope that amsers your question. good luck. Or, if no gas is getting to the location, make sure the valve for your gas is on.
Jun 20, 2015 | Kitchen Ranges
I have a Frigidaire model FCG30B6Q0JWI-5A gas stove (Made in Costa Rica) and can't get the oven to stay lit. There is no electronic ignition, no pilot, it's just a regular run-of-the-mill light a...
While your holding in the knob after lighting the pilot,their is a thermocoupler that is heating up and will hold automatically what your pushing in, that thermocoupler is defective
Jul 28, 2011 | Ovens
My stove lights very slow with a low flame. Should the igniter stay on after it lights oven
Yes the ignitor stays on even after the burner is lit. The ignitor is wired in series with the oven valve. It sounds like the oven valve isn't opening all the way. A new ignitor should solve this problem. The old igniter builds up resistance and doesn't let the correct voltage through to the oven valve for it to open properly.
Tom
Aug 16, 2010 | Magic Chef CGR3725 Gas Kitchen Range
How do i turn on a flavel milano 50 oven?. Never worked with gas stoves before and no manual in sight.
Turn on the gas knob for the oven (below the grill)
You will see an ignition button below the one that switches on the oven light,it is clearly marked.
Press in and hold the gas knob and press ignite button,you will see the safety bar flame light,when the safe to operate temperature is reached,the oven will stay lit after you release the gas supply knob.
Set oven temperate guage (gas mark 4 is approx electric 200 degrees,thats all there is too it
Hope that helps
yorkypaul@gmail.com
Sep 05, 2009 | Ovens
Igniter wont stop firing
Make sure that the small burner holes near the ignitor are not clogged. if no flame is visibly touching the ignitor, then the ignitor will not sense that it is lit. The fact that it seems to take longer to light than normal leads me to this as well.
If there is good flame contact with the ignitor, then sometimes it will not sense the flame if you had a boilover and water got down between the wire and the ceramic body. This can happen with oil as well. Removing the ignitor (carefully! if you crack it, it will "leak" its spark and not work properly), cleaning it and letting it thoroughly dry will help. Most of the time I just leave the burner on and the clicking will stop after about a minute when the whole assembly heats up and drys out.
If all that checks out, then the ignition module is bad. Mine went out after 6 years use. They are available online (I bought mine from a Viking parts store...surprisingly). Replacement is fairly easy. Turn off the power to the stove. Remove the screws that hold the burner knob/oven knob faceplate to the range (Two are only accessed by opening the oven door, the rest are tucked up at the top of the faceplate and under the top-front lip of the range) The ignition module has many wires attached and they are easy to remove. MAKE SURE YOU ATTATCH THE WIRES TO THE NEW MODULE IN EXACTLY THE SAME SPOTS ON THE NEW IGNITOR. That includes the same ignitor wires that are all colored the same.
I absolutely love my Bluestar. I wish my convection fan was quieter, but the power of the range is simply awesome.
Apr 23, 2009 | BlueStar RNB36 (Gas) Kitchen Range
Kitchen Ranges Logo
101 people viewed this question
Top Verona Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Verona Kitchen Range Expert? Answer questions, earn points and help others
