Question about Measuring Tools & Sensors
The inside unit will not show outside temperature. Have replaced batteries in both units. Up till now it has worked well. Help appreciated
  • 17 Answers
SOURCE: outside temp does not read new batterys in both
Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed.
Posted on Oct 21, 2010
SOURCE: Omnitech Wireless Weather Station model
Push and hold down the channel button, wait for beep, then on the sensor, push and hold the tx button, wait for beep.
Posted on Nov 16, 2010
SOURCE: My Nexxtech wireless weather station
You must move the remote sensor close to the base unit to reset it and it will work fine. After it shows the temp then you can move it back to its location. thanks for asking at Fixya.com.
Posted on Dec 02, 2010
app_3rp12804
SOURCE: No longer shows temp (indoor
Mine did the same thing. I just had to replace the batteries in the main unit and it is working again. Good luck!
Posted on Jan 14, 2012
  • 43031 Answers
SOURCE: I am unable to get the remote temperature to show on the base unit. It appears that there is no signal.
In general, batteries are installed in the remote transmitter first and time is allowed for the transmitter to begin sending data. Batteries are installed in the receiver next and you should see the outside temperature displayed.
Posted on Dec 26, 2014
The outside temp won't show up on my new weather station
  • Remove all batteries
  • Install batteries in outside unit and wait for it to begin sending temperature signal to inside unit.
  • Install batteries in inside unit. You should see outside temperature displayed.
  • If this doesn't work, the outside unit may be defective.
Apr 04, 2018 | Measuring Tools & Sensors
No outside temp in de display only - - -in thedisplay i see the room temp. No outside temp. I have checked the outside transmitter end i see the red flash.
my unit tells me to insert fresh batteries into the outside sending unit first. then insert new batteries into the inside receiving unit. after the outside temperature shows up, then can reset my inside unit's time, choose F or C and
switch channels. please try changing channels if your
outside temp doesn't show. you can do both units in the house then put one outside after they work properly.
Mar 29, 2018 | Home
Outside temp battery quit yesterday. replaced batteries inside and out. outside temp will not show. what to do?
  • Remove batteries from both units
  • Install batteries in outside unit. Allow time for it to initialize and begin transmitting data.
  • Install batteries in inside unit. You should see outside temperature displayed. If not, there may be a problem with the outside unit.
Mar 18, 2018 | Measuring Tools & Sensors
Barolo AU9 weather station. I replaced batteries in the outside temp unit. how do I activate it to show outside temp on the main inside unit
  • Install batteries in outside transmitter and wait for it to initialize and begin sending data
  • Install batteries in inside receiver and observe temperature reading
Sep 22, 2017 | Measuring Tools & Sensors
How do I get it to display outside temperature?
Usually, batteries have to be installed in the remote unit first, followed by house unit. Allow time for the remote unit to begin sending data to the house unit, then you should see it displayed.
May 15, 2015 | Measuring Tools & Sensors
I have model 9630 The Weather Channel. I was not receiving the outside temp so I replaced the batteries in both units. After several trys it's still not working. The receiver shows OF.L for the inside
  • Install batteries in outside unit and allow time for it to begin transmitting date
  • Install batteries in inside unit. You should see outside temperature displayed. If not, the outside unit may be defective.
Oct 31, 2017 | Measuring Tools & Sensors
Radio Shack 63-1090 indoor/outdoor temperature unit. Won't give outdoor readings. Temps are cold, -5F but it always worked before. Put in new batteries in the inside and outside units, wiped outdoor sensor...
According to instructions for similar systems, you have to replace batteries in the outdoor unit first, then the indoor unit and wait 10 minutes without pressing any buttons for the indoor unit to begin displaying the outdoor temperature.
Dec 31, 2013 | Heating & Cooling
I cannot get the outside temperature to show on the inside monitor
Try the usual fix by removing batteries and reinstalling/replacing batteries starting with the outside unit. Wait for as long as 10 minutes for the ouside temperature to be displayed on the indoor unit. If nothing happens after 10 minutes, the outside unit may have failed.
Oct 20, 2013 | Oregon Scientific Bar806hga Helios Solar...
Measuring Tools & Sensors Logo
109 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
