Question about LG LRE30453ST (Electric) Stainless Steel Range
My LG electric range overheats every time it is turned on
I replaced the sensor and thermal fuse but the heat rises to 500 degrees every time you turn on the temperature
  • LG Master
  • 473 Answers
If the sensor you changed is the rod type one in the oven itself then the only other thing possible is the control board where you set the temperature. The sensor works with that board to control oven temp.
Posted on Apr 01, 2015
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    I turned on the self cleaning and the door locked but is the heat supposed to go on and off
    Yes. It is maintaining a temperature hot enough to burn off residue but not overheat and burn the house down. It should be running somewhere around 500 degrees f
    Sep 16, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    LG Dryer. No display. Won't turn on.
    Hi,On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
    If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
    Thank you!
    May 09, 2010 | LG DLE5932W Electric Dryer
    Oven not heating up
    Problem with oven sensor or control board (ERC). Oven sensor at room temperature should have resistance about 1080 Ohms, and it rises with temp rise.
    Nov 26, 2009 | Kitchen Ranges
    Ge oven turns off by itself, and sometimes gives
    F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F2
    Note: Also see fan thermal switches Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
    · Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
    · Control senses oven temperature above 935 degrees F with the door in the locked mode.
    · Stalled cooling fan or airflow problem. · Look for welded relay contacts. (Heating elements on in off mode).
    · Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
    · Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
    · Look for electrical noise interference in the oven temperature sensor circuit (Ham radio, cordless phone, etc.).
    Nov 11, 2009 | GE Profile JTP18 Electric Single Oven
    Oven not heating KitchenAid KERC506HWH3
    I have a one year and 2 month old KitchenAid KEMC308KSS03 Wall oven/microwave combination.
    After a self cleaning cycle the oven would not heat again. Eveything else works fine the microwave, controls, etc.
    The problem is the thermal limiter switch that KitchenAid used. It is a one shot thermal limiter that opens if the back of the oven goes above 120degrees C and does not reset when it cools down.
    The KitchenAid PN is 9759243 BUT don't replace it with the same part if you have this problem. KitchenAid want $84 for this silly thing and it a piece of junk. Buy a PN 317-1368-ND from DigiKey Inc. 1-800-344-4539. This is a 120 degree C thermal limit switch but it will RESET itself when the oven cools down so if it happens again you won't have to pull the oven. This part cost s $6.60 from DigiKey and is a much better part than the original one from KitchenAid.
    The switch is on the back of the lower oven, there is a cover that comes off and you will see it screwed to the back with two wires connected to it with faston terminals. It is an easy permanent fix for this problem.
    KitchenAid is ABSOLUTELY NO HELP with this (as ususal).
    I hope this helps.
    Nov 04, 2007 | Frigidaire FEF336BC Electric Kitchen Range
    Oven won't heat
    I have EXACTLY the same problem, occured today 9/25/07. Model RBS305PDQ16. At least I know I am not crazy... You know when Ronald Regan was President the CIA analysts assured him that the Soviet Bloc was ready to crumble because the people were constatly complaining that "nothing seened to work anymore." ...must have included ovens...
    Sep 20, 2007 | Whirlpool RBS275PD Electric Single Oven
    KitchenAid oven shut down during self-cleaning
    I've had the same problem and have had the thermo-protector switch replaced four times. After the last time I was so ********** I wrote to the CEO at Whirpool/Kitchen Aid in Benton Harbor, MI with my complaint. Today I received a call from an extremely nice lady in his office who said that they were sending me an updated kit for repair free of charge. The part number is 9759243. She offered that this was a known problem but was limited to just one production run - my luck!
    If you are having this problem with your KGSA906PSS write to the CEO at Whirlpool!
    Sep 15, 2007 | KitchenAid KGSA906PSS Gas Kitchen Range
    LG LRE30453ST (Electric) Stainless Steel Range Logo
    155 people viewed this question
    Top LG Kitchen Ranges Experts
    JP Services
    JP Services
    Dan Webster
    Dan Webster
    Oloyede Monsuru
    Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
