Question about Refrigerators
Needs a compressor. where can I get it and how hard is it to install.
  • Refrigerators Master
  • 5,323 Answers
Usually to expensive to buy and then u have to have the freon line soddered, would more than likely be cheaper to buy another fridge, r u sure the compressor is out? whats the problem?
Posted on Apr 22, 2015
My refridgerator stop getting cold i tested the compressor and showed it is in good shape i would like to hard start it to see if it would stay running how would i hard start the compressor
Installed 3n1 start kit - did not help. compressor shows good resistant between all windings, not grounded, but hard start kit did not start it either. But this video might help You to wire 3n1.
Oct 29, 2013 | Stainless Cal Flame Refridgerator Steel...
How to wire in new hard start
It's very simple to install a 3N1 Supco Hard Start Relay, Some refrigerators have a run capacitor located on compressor or mounted nearby. It will be important that you use the run capacitor in with the 3N1 Hard Start. Here is a Photo of the=> URCO810_3_N_1
The instructions come with the 3N1 Hard Start Relay. Can you please post the model number of your refrigerator here so I can look up a wiring diagram? Look around the fresh food section door frame for your model number. I do need to know so we can get the right run capacitor in the 3N1 hard start circuit, Thanks Sea Breeze
Jan 30, 2013 | GE GSS25LGP Side by Side Refrigerator
Turn my roof top ac on , fan runs but when compressor tries to run lights in camper dims 3 to 5 sec. don;t kick breaker off, any ideas?
You need to get a reading on the current draw of the compressor. Use a clamp on ampmeter to do this. Compare your reading with the data plate on the compressor. Your compressor may be getting ready to go out. You can also check the capacitor. If may be getting weak and need replacing. Another idea may be to install a hard start capacitor if the compressor is OK.
Sep 05, 2010 | Dometic Rooftop RV Air Conditioner
I have amana bottem freezer,1 month ago i
Hello, Unfortunately the compressor likely is seized now. There are a couple of reasons that the original start device failed, 1) faulty connection. 2) poor quality part. 3) compressor was running non-stop due to other deficiencies in the unit or 4) the compressor was failing to begin with. The compressor may indeed check out ok as far as electrically ( windings ) but the mechanical component ( rotor ) has locked/seized up. You can determine whether it is the windings by checking the ohm value between common to start, common to run and run to start ( c-s, c-r, r-s ) and look for values similar to 6ohms, 3ohms, & 9ohms. Then check the start and run & common windings against the compressor casing to see if windings are shorted. In order to double check the mechanical component you'd need another hard start, ( or a test cord direct to 120vac, but that should only be done by an experienced tech ). nothing else will start it at this point obviously or you wouldn't be using a hard start already. The other unfortunate issue is this, many of these compressor's have a 10yr. parts only warranty but that was voided as soon as the 3in1 hard start was installed. In the end I'm likely not telling you anything you didn't already suspect or know in fact, but it is likely the compressor. I sympathsize, seized compressors **** ! Hope this answers your question and moves you forward. good luck macmarkus :)
May 08, 2010 | Amana ABB1927DE Bottom Freezer...
New copeland compressor wont start
Hello,By all means install a hard start kit on the cap.Your wiring is correct.A scroll compressor usally doesn't need a start kit but I have seen 5 ton units that take one.Check the compressor tag and make sure the compressor is not a 3 phase motor!
Apr 21, 2010 | Heating & Cooling
Intertherm S3QA042K compressor won't restart
You probably need a hard-start kit. A hard-start kit connects to the run capacitor and provides a starting boost for your compressor. If you install a hard-start kit, monitor your a/c for a while because it is possible that the bearings in the compressor are going bad.
Jul 30, 2009 | Heating & Cooling
Magic Chef MCBR1000w stopped cooling
If the compressor runs on 120 volts AC, (some are three phase DC, you can use a 3n1 hard start kit, they are very simple to use and cost around $20 dollars, you can purchase them at HVAC supply stores. If the compressor continues to short cycle after installing the hard start kit, then you need the compressor replaced and should check your warranty, this is often an expensive repair.
Jun 15, 2009 | Magic Chef CTB1821AR Top Freezer...
Compressor starts then stops after 5 seconds
Installed hard start Kit for this little freezer. No help. Needs new compressor.
May 28, 2009 | Freezers
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
