Question about Music
Power on/off switch does not work consistently. Tried to to clean it, but no affect
    Top Expert:
  • Music Master
  • 3,113 Answers
You don't mention what the instrument or amplifier you're asking about, but generally if cleaning a switch doesn't help, you'll need to replace it.
Posted on Apr 01, 2015
Low volume on one channel on a pa 2400 8 channel mixer
Check the pots in the affected channel for clean wipers. You can squirt chemical cleaners into them or you can remove all power and go to the controls and go back and forth from one extreme to the other and virtually wipe the surface clean via friction. If that and checking connections does not do the trick you will have to resign yourself to the fact that you have a loss of gain in the affected amp and you will have to inject a signal and resort to signal tracing to locate the culprit.
Sep 06, 2017 | Music
My Fender Hot Rod deluxe makes a popping noise when switching back to the clean channel.
This is because your clean channel only runs through the pre-amp section, requiring an increased volume level to match that of the volume of the drive section which is overdriven by the pre-amp circuit. my suggestion is to use lower volume level on the clean channel of the amp. To get any volume boost you may need to match the two channels you could use a signal/volume booster or overdrive pedal between your guitar and amp input, switching it off and back on when you switch back and forth between channels.
Jul 15, 2012 | Fender Hot Rod Deluxe Guitar Combo...
I've had my Taylor T3 for over two years with no problems. Done a lot of gigging with it as my main axe. Just got off the road and discovered a major problem: the volume on my neck pickup is...
More likely a failed selector switch. Try working it back and forth a few dozen times. Contact cleaner may be tried too, squirting in the back of the switch.
Jul 04, 2011 | Taylor T3 Guitar Electric Hollowbody
Hello, My Boss CS-3 Compression Sustainer pedal is having issues. I bought it around 6 months ago. When I first discovered the problem, it didn't work at all when turned on. It just made this feedback...
Make sure you use Alkaline battery and NOT rechargeable type... the rechargeable battery will NOT work in the pedals (their voltage is lower even though they are labeled as 9 volt replacement).
Other internal problems can be due to cracked circuit board or broken solder joints. These are very common as people step on the cables when plugged in. This breaks the connection inside. A fuzzy sound often occurs when one of the contacts is marginal due to bad solder at the jack terminals.
Mar 22, 2011 | Roland Boss CS-3 Compression Sustainer...
Keystation 61 key won't play
Most of these use conductive rubber pills that are pressed onto circuit board traces by the keys.
Clean the board AND the pills with 99% isoprophyl alcohol and QTips.
May 31, 2010 | M-Audio M Audio Keystation 88es 88 Key USB...
My amp has 2 channels, clean and distortion. distortion works, but the clean channel doesnt. When i hit the button, it switches the distortion off, but there is no sound. The distortion light stays on...
initially you want to think bad solder joint, but it think its a bad mosfet or rectifier or diode. it would be hard for an untrained person to identify your problem let alone an experienced tech. it may be time to move on to another amp. in my shop it would be at least 65 bucks for the repair. so where did the "heat"/energy go from that point and what parts were affected. there may be a domino affect. burn one part, not usually.
yostamplifier.com
Jan 17, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
My sustain pedal does not work on my Roland Juno-D keyboard.
Have you tried the pedal straight into the amp without going thru the Roland?
Does the sustain pedal turn on with the foot pedal or is it a separte stomp switch to turn it on?
May 31, 2009 | Roland Juno-D
Music Logo
164 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
