Question about Kenmore Kitchen Ranges
Where is the pilotless ignition located at - Kenmore Kitchen Ranges
  • Kenmore Master
  • 473 Answers
On the oven, it is usually attached to the back center of the burner under the over floor which can usually be removed. If you are asking about the top burners, the spark tip is right next to each top burner. The spark module that supplies the spark is usually on the range back, sometimes in the control panel area or just below it under a cover plate or box. Most ovens these days use a glow bar ignitor for the oven that glows red hot the complete time the oven burner is on. Looks like black ceramic and is very brittle if hit too hard.
Posted on Apr 01, 2015
I have a Hot Point Gas Stove my burners all turn on but when I turn on oven nothing seems to happen
If you have a pilotless model it is very likely that your oven igniter is bad. This is fairly easy to replace. A contunuity check will show if the igniter is bad.
Nov 25, 2013 | Stoves Ovens
Gas is not coming through in oven
follow this test and fix it. God bless you
A lot of times the problem is with a dirty or a clogged burner. Make sure the burner is clean.
If you have a pilotless model, it uses a spark igniter to ignite the gas, which works in a combination with a spark switch (located on the burner gas valve) and a spark module. Because it is not simple to test these parts and find out which one is defective, we recommend to contact a professional appliance technician.
Nov 05, 2013 | Kitchen Ranges
No water comes out of hot water faucet
Most likely water heater.
If it's electric heater, check circuit breaker in breaker box.
If it's gas, check if pilot light is lit.
If it's a gas, pilotless heater (quartz igniter), check that the igniter works.
Oct 17, 2013 | Water Line - 4 Rolls
Pilotless ignition wont turn off wont stop clicking
You will need to replace the ignition switch assembly. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Frigidaire FGF378AC Gas Kitchen Range
The oven is not firing up, though there is gas getting to the stove top.
unit is a pilotless ignition therefore check the hot surface igniter. see if the igniter heats up. check for loose spade connectors where the wires plug into the socket. this unit has an infinite resistance but won't work if the resistance isn't there.
Oct 17, 2009 | Hotpoint RGB745 Gas Kitchen Range
Oven will not turn on
You need to replace the igniters for the top or the ignition filiment if it is the bottom.  You can get these at any appliance center.
Mar 12, 2009 | Ovens
Stoves 900G gas oven stopped working
Sep 03, 2008 | Stoves Premier 900GRa Gas Double Oven
Kitchen Ranges Logo
67 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
