Question about Memorex MVD2016 DVD Player
Split screen with black thick line down the middle.
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Thick black line running down the middle of my screen
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
May 13, 2010 | Soyo SYTPT3227AB 32 in. LCD TV
Mines a LG RZ42PX11 it intermittently gets a black vertical line down the middle of the screen.
Hi I have a LG RZ42px11 there are 6 vertical thick black lines running down the middle off the screen, when cold the TV seems OK but if it has been on for around 10mins or on standby the lines stay on screen.
Thanks.
Douglas.
May 13, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Thick Vertical Line
the power supply is defected a capacitor filter is leaking.have a tech repair your tv.good luck.
Mar 01, 2010 | HP PL5060N 50 in. Plasma HDTV
Permanent split screen down middle by black line
The GPU has overheated that is what causing this problem.
You will need to stop the heat build up and get it repaired - you can even do this with a good guide or send it in.
Nov 01, 2009 | Microsoft Xbox 360 Console
There is a thick black line down the middle of the screen
Aug 11, 2009 | Hyundai HPT-4250 Television
Black line in middle of panasonic plasma screen
Oct 13, 2008 | Panasonic TH-50PV30 50 in. Plasma...
Thick Black Line Down Middle of TV
does this only occur with one input and/or does it occur when using HDMI/component cables.
if so, try getting a new HDMI cable. I have the same problem with PS3...and im about to order a new HDMI cable.
Sep 30, 2008 | Panasonic PT-52LCX65 44" HDTV
Thick Black Line on Screen
This is caused by dead pixel sensors. There are hundreds of pixel sensors at the edges of the screen, when they go out it will cause a line varying in size depending on the amount of sensors that go out, and the line can vary in color, red, blue, green, white, and black. Unfortunately, the only fix for this is to replace the screen.
Jul 30, 2008 | Computers & Internet
Memorex MVD2016 DVD Player Logo
53 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Radames Pagan
Radames Pagan
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
