Question about Datacard Office Equipment & Supplies
Hi, I have the card Printer Edisecure DCP340+ it was working perfectly, I just format my PC and tryed to install it again ! The problem when i connect it to any PC it is recognized as DATACARD SP55
It is Edisecure Brand and now it became Datacard brand
    Novelist:
    Scholar:
  • 66 Answers
If you re-formatted the PC, then you likely wiped out the instance of the correct driver for your printer. Windows typically does not come with a driver for any but the most popular ID-card printers. When you reconnected the EdiSecure printer, it likely associated it with what it believed to be the closest driver to the one required (but missing) - the Datacard driver. To correct:
1. Through the Windows Control Panel, then Device and Printers (or Printers and Faxes if WinXP), find the instance of your printer (set up as Datacard); right-click on it; select "Remove Device" (or "Delete", if WinXP);
2. When complete, disconnect the printer from the PC;
3. Through Windows Control Panel => Programs (Add/Remove Programs if WinXP), find and un-install any instances you find of Datacard programs or drivers;
4. Reboot your PC;
5. From either the printer's install disk, or the manufacturer's website, download and install the correct driver for your Windows OS. If prompted to re-boot, do so. NOTE - do not connect the printer to the PC until you are either prompted to do so by the driver-installation program, or the installation completes normally and without errors.
6. Connect the printer to the PC. Give Windows time to recognize the device, associate the new/correct driver, and tell you it's ready for use.
7. Check in the Windows print center (Control-Panel=>Devices & Printers (or Printers & Faxes) to verify that it is now recognized as an EdiSecure printer.
Posted on Apr 17, 2015
4 Suggested Answers
  • 43 Answers
SOURCE: datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Posted on Nov 23, 2009
  • 36 Answers
SOURCE: Card jam in datacard printer
The rollers in the printer that move the card wear out and the rubber degrades over time, You need to have all the roller replaced and the printer should function like new. Contact MIdWestIDSolutions.com for pricing on parts or service.
Posted on Mar 18, 2010
  • 36 Answers
SOURCE: SP55 Datacard
The printer does not know the the model of the ribbon installed and thinks it is a monochrome (single color) Print ribbon. You can verify this in the Driver toolbox under the supply tab, or in the advanced printing options.
The Datacard SP series printers use an RFID Radio freq. tag in the take up spool end of the ribbon. This identify s the ribbon model and supply use settings for the printer.
Make sure you have the most recent driver and firmware from Datacard, There is a firmware Update Available to help reading "weak" RFID tag's
Next try removing the RFID tag from another (old) ribbon and see if it that fixes the problem)
Aside from that you:
May have a counterfeit (non-Datacard) ribbon
A bad RFID tag
Someone removed your RFID tag
You need a firmware update (weak RFID tag)
A bad RFID reviver in the printer, which is a fairly cheap repair.
Basically try a new print ribbon if that does not correct the issue, have the printer serviced.
www.TulsaBiz.net
Posted on Sep 01, 2010
Trying to install printer
You should have install the printer driver on your pc before paired them in the first time. This is to make sure your printer can work smoothly on your PC/OS. Otherwise your OS will run its standard driver ( sometime this standard driver will not work perfectly for your printer, especially for uncommon printer brands ).
So, again for best result you need to install its original driver ( it usually bundled on printer box while you bought).
regards
Sep 16, 2011 | Computers & Internet
My Eltron P310 card printer pulls in the ribbon alongwith the card, past the print head. Thanks for any advice
Sep 08, 2010 | Zebra Eltron P310 Thermal Printer
My polaroid dvf 130 camcorder won't connect to my computer.the software it came with says it doesnt need a driver since I have windows xp what should I do?
this is what i did, and it worked perfectly. go out and get a sd card * any gig u want* as soon as u put the sd card into the camera, FORMAT IT!!!!. do that before u do anything else. don't format it on ur pc or laptop. format it on the camera. if u do that it will work perfectly. i don't know why it wasn't in the manual to format sd card first. but if u try to take pics first, that will mess up the entire system and u will be assed out a sd card. it took me 3 sd cards to figure this out. the cards worked fine but not in the camera. then i formatted it on the camera first and it works fine. the other sd cards i use for other things, i won't discard them but they won't work in the cam. but remember again GET NEW SD CARD AND FORMAT THE CARD IN THE CAMERA FIRST.
Jun 29, 2010 | Polaroid DVF130 Camcorder
Files in my kingston pendrive does not open up
Hi manoj_clc,
The "other PC" needs to have the same application installed that created the files. It sounds likely that is the problem for the other PC. If the files are failing to open using the PC that originally copied the files, then try formatting the USB drive (formatting deletes all data). Before you copy the file again, make sure the same file opens from your computer prior to copying it. Now copy the file to it the USB drive again.
Kingston Tech Support
May 03, 2009 | Kingston 4GB Secure Digital High Capacity...
Flash card won't work in HP735
Hi there.
You must format the SD card after you put it in the camera. If you don't format it, then it won't work.
Don't forget to vote for my solution! Thanks,
Rob
Jan 19, 2009 | HP Photosmart 735 Digital Camera
Formating 64gb pen drive
some memory cards / items do not work with FAT32, you should try to re-format using your PC to FAT16 format.
Dec 31, 2008 | Electronics - Others
MMC memory card is corrupted (1GB). does not format.
Please try to format the memory card using a memory card reader on computer and then insert the card back in phone, it will say corrupted again, but now you try again to format it from phone and it should work now,,.....
Nov 06, 2008 | Nokia 6600
It says printer cartridges missing or not detected cartridge error, or not deteceted, started with printing only partial pages, now nothing. changed cartidges, rest printer, still nothing
Is it working perfectly before installing new cartridge.
Try to turn off and reinstall the cartridge again. Also shutdown the PC. Then power on PC & then Printer.
Do unplug before PC start.
Let me know the status. Dont forget to rate me if it help you.
Regards
ELLIN
Sep 23, 2008 | HP Officejet 5610 All-In-One InkJet...
Lexmark p315
You mention two problems, are they both still active? The memory card issue could be a defective card; I've had brand new cards not work a number of times. It could also be a defective card reader in the printer but its more likely the memory card may simply need to be re-formatted. - Save any pictures you may have on the card to your PC if you need to keep them. - Format the card using the camera utilities. Do not use the computer to perform the format. - Try it again. If formatting the card doesn?t do it you might try another card you know works. If it does work in your printer then its probably the card, if not that strongly suggest the printer card reader is at fault. Let us know if you have any other questions and please don?t forget to rate this posting.
Feb 06, 2007 | Lexmark P315 InkJet Photo Printer
122 people viewed this question
Top Datacard Office Equipment & Supplies Experts
Safe-Card ID...
jason
Don  Farrell
Don Farrell
Are you a Datacard Office Equipment and Supply Expert? Answer questions, earn points and help others
