Question about Garmin nuvi GPS
My NUVI 55 keeps turning off and on
My unit turns off and on while driving (yesterday approx. 20 times in 5 hour trip) and when I was connected to my computer to update maps and check for fixes to this problem
    Scholar:
  • Garmin Expert
  • 186 Answers
Charge the unit overnight with a high capacity usb charger, 2A or higher. If the probably persists, you have either a batter issue (Amazon sells battery kits) or your car charging system is defective. Your device is not getting enough charge to stay on.
Posted on May 02, 2017
3 Suggested Answers
sharcnet
  • 2130 Answers
SOURCE: GARMIN NUVI 200 SAYS NO DETAILED MAPS FOUND THAT SUPPORT ROUTING
Please click on this link to obtain more information on this problem:
http://www.sharc.net/discus/messages/6/250.html?1247812497
- Jim
SHARCNET-USA
Posted on Jul 17, 2009
HarryHarley
  • 343 Answers
SOURCE: NUVI 260 lethargic, navigation guidance and map take 15-20 minute
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good explanation you gave. More than most do.
Make sure you have the latest nuvi "Firmware"
then update the maps. I would start with making sure you have the latest WebUpdater on your computer before you proceed with any updates.
If a nuvi 200 is has an older version of system software glitches may occur. The device may be missing letters or have jumbled letters or displaying duplicate letters or strange symbols on the address screen. To correct this you will need to update the system software of your nuvi. You can easily do this by using Garmin’s WebUpdater program:
  1. Click the following link to download the WebUpdater program: http://www.garmin.com/products/webupdater/howtoinstall.jsp
  2. Follow the on screen prompts from the website
  3. Choose RUN/OPEN
  4. Follow the on screen prompts
After the program has been installed it should run automatically. If it does not please use the steps below.
To run WebUpdater:
  1. From the Start menu, click All Programs and find the Garmin folder
  2. Click WebUpdater
  3. Connect your nuvi to an available USB port on your computer
  4. To search for an available update, choose NEXT
  5. As the program automatically finds updates, choose NEXT to load the update. Once the update is complete, you can search for other updates such as voice languages, Bluetooth, and Traffic Receiver.
  6. Disconnect the unit to ensure it powers on.
Take your unit outdoors and keep it in a stationary position with an open sky view until it reacquires satellites.
Posted on Feb 24, 2010
Will not turn on.
Must be dead, try googling 2555 master reset, try plugging it into the computer, otherwise I'veheard gGarmin will sometimes give you a credit toward a new unit if you call them.
May 31, 2014 | Garmin nuvi 2555LM 5" Screen With
Obd2 system rediness status won't clear so I can run the smog test due to replacing the battery.
takes a long time to run the rediness test since there are 6 different tests to complete...
PROCEDURE 1
EVAPORATIVE EMISSION SYSTEM LEAK MONITOR
Inspection Conditions
Engine coolant temperature: 30°C (75°F) or less (The engine is stopped before the test drive is started).
Atmospheric temperature: 5 - 30°C (41 - 113°F).
Condition of A/T: Selector lever D range.
Fuel remained in fuel tank: 30 - 50% is recommended.
Time required: 16 minutes or less after started the engine.
Drive cycle pattern: One trip monitor (from start to ignition switch to "LOCK" (OFF) position. Well be completed while traveling with the following drive cycle pattern.
Test Procedure
Engine: start.
Accelerate until the vehicle speed is 89 km/h (55 mph) or more.
While keeping the accelerator pedal opening degree constant, keep the vehicle speed at 89 km/h (55 mph) or more and travel for 16 minutes.
Return the vehicle to the shop, then turn the ignition switch to "LOCK" (OFF) position.
PROCEDURE 2
FUEL TRIM MONITOR
Drive Cycle Pattern
Engine coolant temperature: 100°C (212°F) or less.
Atmospheric temperature: -10 - 60°C (14 - 140°F).
Time required: 30 minutes or more.
Drive cycle pattern: One trip monitor (from start to ignition switch to "LOCK" (OFF) position). Will be completed while traveling with the following drive cycle pattern.
Test Procedure
Engine: start.
While keeping the accelerator pedal opening degree constant, keep the vehicle speed at 89 km/h (55 mph) or more and travel for 30 minutes.
PROCEDURE 3
CATALYTIC CONVERTER MONITOR
Drive Cycle Pattern
Atmospheric temperature: -10°C (14°F) or more.
Engine coolant temperature: Not set.
Time required: 16 minutes or more.
Test Procedure
Engine: start.
Travel for 300 seconds or more while keeping the vehicle speed at 89 km/h (55 mph) or more.
Decelerate until the vehicle speed is within 80 km/h (50 mph) or less.
While traveling at 56 - 80 km/h (35 - 50 mph) for 10 minutes or more, fully close the throttle at least once in 2 minutes and decelerate for 10 seconds or more.
Do not repeat deceleration too often.
Vehicle speed may go below 56 km/h (35 mph) after the deceleration.
Stopping and braking are permitted. (If stopped or drive at 56 km/h (35 mph) or less for more than 5 minutes the monitoring may be stopped. In this case please restart monitoring from the beginning.)
After completing the above deceleration, bring the vehicle speed back to 56 - 80 km/h (35 - 50 mph) and keep it in the range until starting the deceleration again.
Repeat the above deceleration at least 5 times.
PROCEDURE 4
HEATED OXYGEN SENSOR MONITOR
Drive Cycle Pattern
Engine coolant temperature: 100°C (212°F) or more.
Atmospheric temperature: -10°C - 60°C (14 - 140°F) or more.
Test Procedure
Engine: start.
Accelerate until the vehicle speed is 56 - 80 km/h (35 - 50 mph).
While keeping the accelerator pedal opening degree constant, keep the vehicle speed at 56 - 80 km/h (35 - 50 mph) and travel for 16 minutes or more.
Stopping and braking during this operation are permitted. Keep the accelerator opening degree constant for 1 minute or more after each acceleration.
PROCEDURE 5
EXHAUST GAS RECIRCULATION (EGR) SYSTEM MONITOR
Drive Cycle Pattern
Atmospheric temperature: 5 - 60°C (41 - 140°F).
A/C switch: OFF.
Test Procedure
Engine: start.
While traveling 16 minutes or more at 56 - 80 km/h (35 - 50 mph) with engine speed 2,000 r/min or above, fully close the throttle at decelerate for 5 seconds or more until the engine speed reaches 1,000 r/min or under.
Stopping and braking are permitted (Rapid deceleration and sharp steering are not permitted).
After completing the deceleration, bring the vehicle speed back to 56 - 80 km/h (35 - 50 mph) and keep it in the range until starting the deceleration again.
Repeat the above deceleration at least 8 times by fully closing the throttle valve.
PROCEDURE 6
OTHER MONITOR (Main Components, Sensors & Switches, Wire Breakage & Short Circuit)
Drive Cycle Pattern
100°C (212°F) or less (Except engine coolant temperature sensor monitoring).
30°C (86°F) or less (Engine coolant temperature sensor monitoring).
5°C (41°F) or more (Except engine coolant temperature sensor monitoring).
-10°C (14°F) or less (Engine coolant temperature sensor monitoring).
Time required: 21 minutes or more.
Test Procedure
Engine: start
Accelerate until the vehicle speed is 56 km/h (35 mph) or more.
While keeping the accelerator pedal opening degree constant, keep the vehicle speed at 56 km/h (35 mph) or more and travel for 16 minutes or more.
Return the vehicle to the shop.
After stopping the vehicle, continue idling for 5 minutes, and then turn the ignition switch to the "LOCK" (OFF) position. Moreover, the vehicle should be set to the following conditions for idling.
A/C switch: OFF
Lights and all accessories: OFF
Transmission: Neutral
Sep 15, 2010 | 1998 Mitsubishi Eclipse
Garmin 1300T just turns off. After hours or days it comes back on. One time in the middle of 6 hour trip it just shut off. I have the newest software and have replaced the unit 5 times and all of them...
OK i have the answer ,man i had the worst trip EVERY thanks to this charging flaw, the flaw is that the unit can only charge while off, so if your on a trip this will not work i had to drive 3,100 mile there and back i literally broke down and cried i was lost in tenissi with no idea what to do or where to go, i LOVE, LOVE, LOVE this gps but it has a very big flaw in it being that you can only charge when it is turned off
Jan 03, 2010 | Garmin nuvi 1300 Car GPS Receiver
When charging the Nuvi 1250 in the car, does a green light mean it's charging? If so, is it safe to assume when the light is out it's fully charged? If so, we just charged ours for 4 hrs. but the battery...
We still haven't resolved this problem. After charging the unit for approx. 4 hours, we could at least turn it on and it stayed on but the battery status still only had one bar.BUT not for long. Now it's back to the original problem which is: when the unit is turned on, it only stays on for about 5 secs. and goes off. I tried calling the mfg. yesterday and was on hold for 1:30 min. and figured they're just not going to answer. Now I know why they want customers do it on-line; we have to pay for the answer, which I think is ridiculous after purchasing their product.
Dec 29, 2009 | FixYa Computers & Internet
My garmin nuvi 1350 powers down while travelling i have to hold power button on to power back on
ALL GPS require charging via the AC charger or USB supplied, If you have not done this then the battery will lose power quickly when connected to 12v car outlet. This source is a maintenance charge, not the main charger. Therefore it will deplete and try to shut down, despite being connected. Holding the power button on to force it is a dangerous driving practice and will eventually damage the unit( not so bad as getting you and any passengers damaged by this practice)
Charge your unit fully before you use it, if that is daily then disconnect it and put it on the AC or USB to raise the charging level to full so it's ready to go for the next day.
If it fails to charge fully, then your actions have damaged the battery and it will need to be replaced.
Please rate my help++++Thanks for using FIXYA
Nov 21, 2009 | Garmin nuvi 1350 Car GPS Receiver
Unit comes "on" for approx. 30 sec, then turns "off". battery indicates approx. 25%
If the unit has been on the charger for several hours and you still only get a reading of 25%, the battery must be replaced. Please see this link:
http://www.sharc.net/gps_battery_repair.htm
- Jim
Sep 24, 2009 | Garmin Nuvi 660 GPS Receiver
  3. Choose RUN/OPEN
To run WebUpdater:
  2. Click WebUpdater
Aug 22, 2009 | Garmin nuvi 260W GPS Receiver
Can not turn on my GPS Garmin nuvi 760
Can you try the direct to outlet charger? If you dont have one can you try a different charger? If that does not work then that means that the unit might be defective. Contact Garmin at 1-800-800-1020
Mar 07, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garamin Nuvi 350...blanked out and won't turn back on.
Try the computer USB adapter. After it's been connected for about 20 seconds then try powering on the Nuvi. Even if your unit's battery is dead the USB connection should hold power on the unit so that the computer recognizes it as a Mass Storage Device (Windows). If that doesn't work then use the wall adapter and leave it plugged in for an hour or so. At that point if the unit fails to power on then push the reset button in the back under the antena and hold it in for 10 seconds while the cord is connected to the wall. This will clear any software related issues that would stop it from powering up - any other result indicates most likely a hardware failure. At least rule out your plugs.
Jun 07, 2008 | Garmin nuvi 350 GPS Receiver
GPS Logo
98 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
