Question about Camping, Backpacking & Hiking
Need to turn off flashlight - Camping, Backpacking & Hiking
  • Bill Buxton
    Bill Buxton Apr 05, 2015
    I'm not sure what you are asking.
  • Bill Buxton
    The switch may be in the tailcap,covered with rubber. Check that out also.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 16 Answers
Most flashlights have a switch. If not maybe you have to unscrew the head until the light goes out. Hope this helped.
Posted on Apr 05, 2015
My streamlight stylist flashlight won't turn on. i had to shake it or mess with rhe end by turning it yo get it to come bsck on. I was holding it in my mouth do you think it got wet
LED flashlights (depending on the manufacture) are not cracked up to what they say they are. The problem with these LED flashlights is that they don't draw enough/much current through the flashlight itself to close the circuit when turned on. So, what happens a lot of times, they become intermittent. Sometimes you have to play with the on/off button to get it to turn on or unloosen the battery end cap or the LED end cap and retighten. Sometimes you have to remove the batteries themselves from the holder and reinstall. Or sometime just spinning the batteries in the holder will fix it till next time. LED flashlight with spring contacts inside work a little better because it's applying pressure to the contact inside the flashlight providing batter connections.
May 27, 2016 | Streamlight Camping, Backpacking & Hiking
Tip
How to replace the lamp in a Mini Maglite
The Mini Maglite is a durable, compact flashlight. If your Mini Maglite stopped working, check or replace its two AA batteries first, and if that doesn't fix it, you'll probably need to replace the lamp. You can order replacement lamps in packs of two online, or you may be able to find them locally in a hardware store.
To replace the lamp in a Mini Maglite:
1. Unscrew the bottom of the flashlight. (Hold the flashlight with the head facing down so that the batteries don't fall out.)
2. Remove the batteries.
3. Unscrew the flashlight head from the barrel.
4. The lamp is mounted into the flashlight on two prongs; gently pull up on the lamp to remove it.
5. Install the new lamp by lining the prongs up with the two holes and slowly inserting it fully.
6. Screw the flashlight head back on.
7. Reinsert the batteries.
8. Screw the base back on.
When you've finished, turn the flashlight on (by turning the lens cover or the head counter-clockwise) to verify that the new lamp works. If the light doesn't come on, take the flashlight apart again and check to make sure the lamp is installed correctly and fully. Since the lamps come in packs of two, if you can't get the first lamp to work, try the second lamp in the pack. If that lamp doesn't work either, check your batteries and make sure the lens cover and head are both screwed on all the way.
on Jan 12, 2011 | Kitchen Appliances - Others
Tip
LANTERN OPERATION 1. PUSH THE LANTFRN/FLASHSLIGHT/OFF (11) TO ?LANTERN 1+2? OR...
LANTERN OPERATION
1. PUSH THE LANTFRN/FLASHSLIGHT/OFF (11) TO “LANTERN 1+2” OR “LANTERN I”. THE LANTERN WILL BE TURNED ON.
2. PUSH THE LANTERN/FLASHLIGHT/OFF (11) TO “FLASHLIGHT’ TO TURN ON I’HE FRONT LIGHT.
3. PUSH THE LANTERN/FLASHLIGHT/OFF (11) TO “OFF’ THEN BOTII LANTERN AND FLASHLIGHT WILL BE TURNED OFF.
4. PUSH THE BLINKER/SIREN/OFF (12) TO “BLINKER” AND THE FLASH LIGHT (10) WILL BLINK.
5. PUSH THE BLINKER/SIREN/OFF (12) TO “SIREN” AND THE SIREN WILL BE TURNED ON.
6. PUSH THE BLINKER/SIREN/OFF (12) TO “OFF” AND BOTH THE FLASH LIGHT (10) AND THE SIREN WILL BE TURNED OFF.
7. PULL OUT THE LANTERN (16) AND ADJUST THE LANTERN ANGLE.
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
How do I turn on flashlight on Maven ZTE
The best way to turn on your flashlight is to download a flashlight app on the Google Play Store. most of these apps have a simple switch to turn on and off the flash on your phone.
Mar 08, 2016 | AT&T GoPhone ZTE Maven 4G with 2GB Memory...
Replace batteries for stanley 95-112 flashlight
95-112B - Stanley Tripod Flashlight battery replacement is in the center chamber. Open the three legs, then put your fingers around the bottom part of the center chamber and turn counter-clock wise. Wella put in 3 new AA Batteries.
Apr 14, 2014 | Stanley 3in1 Tripod LED Flashlight 95155
How to turn lite off
With IOS 7 it is very easy to turn the flashlight ON and OFF.
When you are in the home screen you have to swipe your screen from the bottom towards the top. A menu will appear. 64380167-2721-4575-b0bb-bf6ea793596e.jpeg
By pressing the flashlight icon you can turn the flashlight ON and OFF. You'll also find shortcuts to the timer, calculator, camera, controls for music and buttons to turn several wireless connections ON and OFF.
I hope this wil solve your problem.
Feb 01, 2014 | Apple iPhone 5c
Had flashlight for 7 months . it will not turn on . What can I do to check the problem
Either the battery is out of power or your flashlight is malfuction. Firstly you need to buy a new battery to check the real issue. If the new battery won't change the situation, that means there is something wrong with your flashlight, therefore you may plan to pucharse a new one. If you don't want to spend much money on it, you can think order one from online store. I recommend the following headlamp to you:
http://www.aurabuy.com/bright-76-led-4-modes-led-mega-headlamp-4xaa.html
Mar 31, 2013 | Camping, Backpacking & Hiking
How come flashlights are called flashlights if they don't flash?
In the early days of flashlights, the battery life was very short. So if you needed to use a flashlight, you would turn in on only for a second and then shut it off. Hence, the term flash-light.
Jul 09, 2012 | Camping, Backpacking & Hiking
I can't turn off my Nokia 6111 flashlight.
you turn it off by pressing Clear once more. You can also find the flashlight from the main menu by selecting 'Extras,' 'Flashlight,' and then 'On/Off.' The Flashlight icon appears on the display when the flashlight is on.if this didnt not turn off the flash,then try the hard reset remove the batteries and leave for about 5mins, then back
Jan 03, 2010 | Nokia 6111 Cellular Phone
Camping, Backpacking & Hiking Logo
279 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
