Not getting power to motor - Office Equipment & Supplies
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 111 Answers
Bad battery, clean corrosion off battery post or terminals, battery cable have corrosion
Posted on Mar 31, 2015
Why won't my Rainbow E Series won't turn on?
It sounds like your motor is probably dead.
You would need a new motor if the Rainbow is getting power and the power nozzle works.
You can find a new motor here:
Rainbow motor
GoodVac.com
800-775-6586
Jul 29, 2014 | Rainbow E series Canister Wet/Dry Vacuum
1998 ford taurus se windshield wipers don't work
first you have to check if the motor has power. get a tester and test for power on the motor. if you are not getting power check a fuse, is you are getting power but the motor is not working then you may have to change it.
May 07, 2014 | 1990 Ford Taurus
2004 canyon no voltage at heater resistor
The resistor provides the ground circuit for the blower motor. So you would need to have power at the blower motor first. Grounding the motor or resistor should make the motor run.
The blower motor gets power from a 30amp fuse which gets power from a relay.
Jan 18, 2014 | 2005 GMC Canyon
It will not turn on.... is there a reset button
Check the cord to make sure you are getting power to the switch, if so check the switch to make sure you are getting power through the switch. If so, follow the power to the motor to see if you are getting power to the motor. If you are getting power to the motor and it still will not run it may need a new motor.
Sep 19, 2013 | Dyson DC27 Bagless Upright Vacuum
Electric window will not close on 1999 chevrolet silerado
Check the window lift motor connect when the switch is operated on the door, is it getting power? If it is getting power then the motor is defective, if it not getting power it can be the switch or the wiring to the door and window motor causing the problem of no power window operation.
Oct 23, 2012 | Cars & Trucks
Power is not coming on
see this causes and fix it. God bless you
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced.
Sep 27, 2012 | Wagner Spray Tech Wagner 915 1,500-Watt...
2006 hyundai elantra passenger side window will go down but not up from driver or passenger switch
The motor is a basic reversable electric motor, you provide power and ground to go one way then reverse it to go the other.
Are you getting power and ground on the wires in both directions ?
Aug 17, 2012 | 2006 Hyundai Elantra
My trolling motor stopped working suddenly. It is a 96 motorguide 56. It is completely charged. What else do I check. I check 5 fuses by the battery as well.
First you need to check to see if power is getting to the motor. If power is not getting to the motor, then check the battery. If you are getting power to the motor, then troubleshoot starting with checking to see if power is getting to the foot pedal. From there check the switches, and make sure they all have power. If they do, then most likely it is the brushes which could be worn on the powerhead itself.
Jun 02, 2011 | MotorGuide FW40 FB 42" 12V FLXMT Trolling...
The fan doesn't work for the front defroster/heater.
Using a test light, check for power at the blower motor connector. If thereis power there, replace the blower motor. If there is no power there, it could be the blower motor switch or the blower motor resistor. The most common is the blower motor resistor.
Jan 04, 2011 | 2004 Dodge Grand Caravan
I have a Jacuzzi laser sand filter. The system worked fine until I noticed that the circulating motor was extremely hot when running. The pump and motor were very old and in poor shape. So I replaced the...
this sounds like a supply power problem. The motor is not getting enough power. Check the line to see how many amps you're getting. The motor will tell you how many amps you need on the data plate. When a motor heats up and trips it's internal high limit, it's usually due to insufficient supply power. Heat is a byproduct of inefficiency. Also, if this is running on 220v, make sure both legs of 110 have power. Sometimes motors can attempt to run even though half the volts are missing.
Oct 30, 2009 | Jacuzzi Cyget In Ground Pool Pumps
jasbo
jasbo
