Question about Kenmore Washing Machines
Why is my Kenmore washer model 11047532602 beeping when I press the power button? It will not do anything.
    Top Expert:
  • Kenmore Master
  • 43,127 Answers
Pedestal 46262
How do you mount base to washing machine?
Jan 08, 2014 | Kenmore HE2 Plus Front Load Washer
Kenmore Oasis no error code keeps beeping low -loud
If its the main board that you are having an issue with, honestly i will suggest to get a new one instead, might cost you as much as buying a new one if you are going to have it repaired.
May 14, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing machine beeps, doesn't run
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
How do I stop my washing machine door alarm beeping?
do this and fix it. God bless you
However read the instr. manual section troubleshooting /
if doesnot have download from www.fitness.manualsonline.com
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Sep 28, 2012 | Hotpoint WMA74 Front Load Washer
Where do I find the MCU on my Kenmore h2plus washer?
  • 1 Check for any error codes in the Estimated Time Remaining display. The code "F20" indicates a water inlet problem. Press the Stop button twice to end the cycle and check that the faucets are turned on fully. Take a look at the inlet hoses. Close the valves and unscrew them. Look for any clogging on the screen and clear it.
  • 2 "F21" indicates a draining problem. Again, press the Stop button twice and take a look at the drain hose. Make sure it's not kinked, frozen or clogged.
  • 3 "SD" on the display indicates the machine has gone into its Suds Routine. The Suds Routine removes excess suds so that the garments rinse properly. It's not a problem, but can be an indication you've used a non-high-efficiency powder. Just let the SD routine complete and the draining will continue.
  • 4 Make sure the washer is level if it gets noisy or vibrates too much. Use the leveling feet to adjust the level. They screw and unscrew for adjustment. Make sure the shipping bolts were removed from the back of the machine if the machine gets too noisy. See the "Removing Transport System" section in the instruction manual.
  • 5 Check that you are using HE detergent if you spot leaks. Check that the fill hoses are tight and that the drain hose is secured to the drain pipe. Check that the drain isn't clogged.
  • 6 Make sure the load is balanced if the washer won't drain or spin--or if water remains in the washer. Redistribute the load.
  • Buy Custom Car parts.
    Jun 02, 2012 | Kenmore HE2 Plus Front Load Washer
    Kenmore washer HE3t won't turn on but is making beeping error sound when pressing power button. Is there a reset button to press or common problem
    2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
    3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
    4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
    5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
    7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
    15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
    15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Jul 10, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@@
    Jun 20, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
    What does code F21 mean on a Kenmore HE2 plus washer 11047532602?
    it stands for longer than normal drain interval,press "pause/cancel" twice to clear, if it returns then look for obstructions in the water drain from the basket all the way to the drain in the house,or possibly it could be a bad washer drain pump
    Nov 19, 2009 | Kenmore HE2 Plus Front Load Washer
    My HE5t front loader not powering on
    This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
    This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
    Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
    Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
    Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
    Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
    These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
    NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
    If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Sep 10, 2009 | Kenmore Washing Machines
    Washing machine will not start
    The washer has a stuck button on it which usually means you need a new control panel. Let me know the model # and Ill let you know for sure. Thanks
    Dec 15, 2008 | Kenmore 24032\24036 Top Load Washer
    Washing Machines Logo
    Sal DeAngelo
    fordexpert
    Mike Carew
