Question about Coffee Makers & Espresso Machines
I bought the product off the shelf. It had no box and basic instructions. I can use filter coffee, but how do I keep it on for hours? It switches off after an hour.
  • 744 Answers
Make & Model # for help or Google
Not all coffee makers can be set to stay on. Most turn off in an hour as a safety precaution to keep coffee from cooking dry and breaking coffee pot.
Without more info we can not help you.
Posted on Mar 31, 2015
Instructions in manual for programming brew time is incorrect
Here's the Black & Decker products page where you can find another manual.
Here is a list of all their supported coffee makers.
http://www.blackanddeckerappliances.com/products/coffee-and-tea/coffee-and-tea-makers.aspx#/?page=1&filter.brand=Black%20and%20Decker&filter.categorytier2=Coffee%20and%20Tea&filter.categorytier3=Coffee%20and%20Tea%20Makers
If linking directly to a search result dosn't work use this link and enter, Coffee Maker, in the search box.
http://www.blackanddecker.com/Products-Accessories.aspx
Dec 16, 2013 | Black & Decker CM1050B
Just bought the machine. Basically, the problem is that the steam wand goes of on its own (or as soon as I push the coffee button) and that I cannot turn the steam handle at all or do anything to stop...
Hi. Make sure all your buttons are off. (switches all facing the same direction). Then make sure the tap is turned off. Switch main power on. Then switch the coffee on. you should hear the pump start. usually loud at 1st, then it will get quiter as the water is pumped up through the group head. When water is pouring through the group head, switch off the coffee button. Now let it finish heating. If you can get to this stage, then everything is ok. If you cant get it to this stage then you have a problem with the machine. Most likely a themostat on the boiler. Darryn REPAIRER
Sep 22, 2011 | Rancilio Silvia Espresso Machine
Hamilton Beach brew station dispenses very slowly. I have cleaned it twice but still takes a long time to fill a cup!
Try to have a look whether there is a limestone layer built up on the element.
That will slow it down, while most probblems will stop it alltogether.
Remove by leaving white vinegar in it overnight.
Sep 04, 2011 | Hamilton Beach BrewStation Deluxe 47474...
I bought a Bissell Poweredge Pet vacuum from target. There were no boxed products so I took it off the shelf. The instructions are in the clear filter, but I can't get the vacuum to release and let me...
If you go to this website, http://www.bissell.com/poweredge-hard-floor-vacuum/
you can download a manual for you vacuum. Look on the right side of page for "downloadable documents and click on the manual.
This will give you instructions so you can take the filter apart.
Hope this helps,
Handie Andie
Mar 26, 2011 | Bissell Vacuums
No Instruction book & water/coffee doesn't drip from the filter
I also have this machine, I LOVE IT!!! The instruction manual can be reuqested from the "after sales support" on 1300 366 144 or on warrantyhelp@awa.com.au
Jun 16, 2009 | Krups Super Automatic XP 9000 Espresso...
No instructions on programming auto shut-off time (feature listed on box).
You have to use the "Auto-Off" feature, which is located on the same button as on/off:
The automatic shutoff time (ASO) can be
programmed to shut off immediately after
brewing (0:00) or up to 4 hours later. The
default shutoff time is 2 hours.
Press and hold the On/Off button to display
current shutoff time. To change the preset
time, press and hold the On/Off button until
the red power light and LCD display begin to
flash. This signals that you have entered the
Set automatic shutoff mode. Set the time
you want coffee to begin brewing by
following the instructions in “Entering Time
Set Mode.”
When the coffeemaker shuts itself off, two
tones will sound.
NOTE: Automatic shutoff may be
programmed either before or during coffee
brewing. If you program the auto shutoff
time after brewing is completed the unit
will automatically account for elapsed time.
For example, if you set the auto shutoff for
40 minutes and 25 minutes have already
elapsed, the unit will shut off automatically
after 15 minutes (40 minutes minus the 25
elapsed equals 15 minutes).
-Tha Mp3 Doctor
Apr 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Don't understand how it works
This coffee maker has a hot water reservoir that heats and stores hot water so it can brew coffee faster. Once you fill the reservoir by pouring a potful of cold water into the top, you can turn on the switch at the side of the unit and in about 10 minutes the water in the reservoir will be hot. I usually leave this switch turned on to keep the water in the reservoir hot. The front switch turns on the pot warmer at the front of the unit, so it should be turned off unless you are making coffee or keeping a pot warm. To make a fresh pot, put a filter and ground coffee in the removable filter basket, slide the basket into the unit, place an empty carafe on the warming burner and using a separate container pour fresh water into the filler at the top of the unit. The fresh water displaces the hot water in the reservoir and voila, the coffee carafe starts to fill. The amount of fresh water you added is the amount of coffee you will end up with, less a little bit that might have evaporated if you only make coffee every morning or less often. Most units have a plunger under the filler lid that keeps the fresh water from going in to the hot water reservoir until you close the lid, so close it after pouring in the water. Also, turn off the front switch if the carafe is getting low or empty, as it can get hot enough to crack the carafe. If you're not going to be using the coffee maker for several days, turn off the side switch or unplug the unit to save energy and reduce evaporation from the reservoir. I love mine. It makes great coffee and is much quicker than the drip type.
Apr 14, 2009 | Bunn NHB Coffee Maker
Pressure problem
Just a thought here...are you using the correct grind of coffee and have you tamped it thoroughly to keep the pressure up through the grounds? There are a number of sites on the web which talk about how to use an espresso maker. I'm sure you'll get the inspiration you need there to learn to do it right.
Jun 01, 2008 | Isomac Giada Espresso Machine
"Tea Drop" manual
It's December, so you may not still be looking, but you put in 1 tea bag in each side for 1/2 pot of tea, or 2 tea bags in each side for a full pot. If you are using loose tea (tastes better - I just buy Lipton), then you put in 1 Tablespoon in each side for a 1/2 pot and 2 Tablespoons in each side for a full pot. Hope this helps!
Jan 21, 2008 | Sunbeam Tea Drop Tea Maker HTM5B
Coffee Makers & Espresso Machines Logo
53 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
