Question about Dell Computers & Internet
How to remove a blue 3x5 rectangle with, No input signal in the upper right corner my screen?
It appeared when using SKYPE and has never left. I have removed SKYPE.
  • Dell Master
  • 3,957 Answers
This seems to be a problem between your computer and your monitor. The monitor is basically telling you that it is not seeing anything from your computer.
1. Check to ensure the cable is attached firmly. If you have been plugging and un-plugging the cable often, check the connector and make sure the pins are all straight. One bent pin can stop the whole thing.
2. Check to make sure your computer graphics card is up to date, and that it is properly working. Check your screen settings, and make sure they are correct for your equipment. It could be a setting problem.
3. Check the monitor with another computer [actually, this would be one of the first things to try] and your computer with another monitor if possible. Do not use the same cable for the tests.
Posted on Mar 31, 2015
How do I Delete contact from Skype? I use IPad
http://community.skype.com/t5/iOS...iPad/Deleting-contacts-in-Ipad.../517823
    1)Open skype
    2)On right side tap skype contact, all contact icon appear
    3)Touch and hold the icon you want to delete until a X appears at the left upper corner of icon.
    4)Tap the X to delete the icon. Then tap the cancel button at the right upper corner after finish.
Mar 21, 2015 | Computers & Internet
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
Small black rectangle in upper left corner of toshiba 52hm85 dlp
Sounds like it is closed captioning coming up. I would go in and verify both your TV's and the Cable/Satellites closed captioning is off.
Mar 06, 2010 | Televison & Video
How to remove "no composite inpute signal"
If you have the same problem with both monitors, it sounds like a display card setting or problem.
The chances of you having the same problem with different units is 1- 50.
Try the monitors on a different PC and get back to me.
Sep 02, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Unknown icon
I had the same problem for awhile too.
The box is your call equalizer settings.  The descending line indicates "boost bass" and the ascending line indicates "boost treble"
This usually only shows when you have your BB headset connected, to change the settings:
-plug in your headset -make a call, (voice mail works good for this) -press your menu button -select "Enhance Call Audio"
-make your selection
You'll see your choice on the screen
Let me know if this helps 208E019D
Apr 16, 2009 | RIM BlackBerry Bold 9000 Smartphone
How do I make stop Skype from making numbers on websites dialable
Open your browser and look for the blue Skype icon in the upper right-hand corner (icon should be blue with an "S" and "123" with a green phone image.
Click on the Skype icon.
A window will pop up asking you if want to "Turn number highlighting on". Uncheck the box to disable and click "OK".
Feb 20, 2009 | Skype IM
Rolling Screen
Does it do this on any other of its various inputs?
It is indicating that the signal is weak and we need to varify if it is just this one (whatever you currently have it hooked to).
Dec 27, 2007 | Protron PLTV-32 Television
TV turning on and off
Air 2 is the source it's looking at for a signal - - where is the signal plugged into? and are you able to change the input or source to look at another?
Bill
Nov 29, 2007 | Akai PDP-5016H 50 in. HD-Ready Plasma...
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
