Question about Vehicle Parts & Accessories
How do I reattach the compass to rearview mirror?
MrScary66613
  • 1990 Answers
SOURCE: temp sensor and compass not displaying on my 2003 yukon xl
Yes. Look in the Fuse Panel inside the Truck. Use a Good Maglight or LED Flashlight and Hold it Behind the Fuses to see the Blown Ones. It is usually in an AUX Outlet. Also check thr Fuse Relay Box under the Hood for a Blown Fuse using the Same Method. See if there is a Relay for this also. If so, Replace it. Let me know if you need any more Help! Please Rate my Response, I need all the Help That I can Get!
Posted on Jan 26, 2009
truenoae86jp
  • 44 Answers
SOURCE: Reattaching a rearview mirror on a BMW
Small little trick, Clean everything well and wipe it with acetone.  Use your hot glue gun to glue it back on.
Works actually pretty well.
I hope this helps
Posted on Feb 19, 2009
SOURCE: 2003 Sierra rearview mirror
replace outside sensor
Posted on Feb 28, 2009
johnjohn2
  • 5763 Answers
SOURCE: The compass and temperature display
This may be a loose connection or a bad mirror which contains the display, follow the wir to mirror, you will see where it plugs into the mirror, remove the connector and check the connector for a loose wire to connect and then plug it back in and see it that makes a diffrence if not then i would say to replace the mirror.the wiring to mirror comes out from under the roof liner and if there was no repairs done ib that area then the wiring will be okay, it very uncommon for a wiring problem in that part of the wiring unless you had work done in that area, for example a windsheild replacement. hope this is helpful, good luck.
Posted on Mar 13, 2011
mychellaccou
SOURCE: The airbag light stays on and the temperature and compass display on the rearview mirror won't work.
2003 Chevy Silverado
our rearview mirror has gone off and the airbag light stays on.
i've determined that this is a fuse, the SIR fuse under the hood, but what I can't figure out is why it's blowing.
It's either something to do with when we hook up the lights to the trailer or it might be from where we installed a new car stereo.
I took it to the Chevy dealer for some other things and told them there was a fuse blown to the rearview mirror and to the airbag and just asked them to replace the fuse while it was in the shop.
on top of the $700 i was already spending, they charged me $98 to diagnose that it was a blown fuse and like $11 to change it, even though I already told them it was the airbag fuse. Highway robbery. And they wonder why we don't like 'em.
Posted on Jan 20, 2012
Reattach rearview mirror
Go to any auto parts store that carries Loctite brand mirror foot attachment glue kits, follow instructions to the letter, if not it will fall off right away.
Aug 31, 2014 | 2002 Pontiac Grand Prix
How to do I get the compass and temperature gauge to work in the rear view mirror again. Directions are NW and SE all the time
Calibrate the compass built into the upper-right corner of the rearview mirror by holding the compass button (an "N" with two crossing lines) until your zone number appears. Determine your zone number by looking at the map in the owner's manual. Press the compass button until a "C" appears. Then drive in a circle three times at 5 mph or less in an uncongested area. The compass will automatically orient as a result of the circling.
Read more : http://www.ehow.com/how_5927729_reprogram-avalon-after-battery-change.html
Aug 19, 2014 | 1999 Toyota Avalon
Dec 28, 2011 | 2003 Chevrolet Silverado 1500
I have a 2000 buick regal. the rearview mirror fell down. How do i get the metal piece out to reattach to the windshield?
should just be a torx 15 also t15 screw driver to unscrew it and u must use the rearview mirror adhesive sold at most parts stores
Jun 12, 2011 | 2000 Buick Regal
How do you reattach the rearview mirror on a 2001 tacoma Thanks
get a rearview mirror glue kit and follow the instructions.
Aug 02, 2009 | 2001 Toyota Tacoma
Can not find the set screw for this inside rearview mirror to rea
There is a little opening at the bottom of the mirror mounting part; gently push a small, flat screwdriver into it and slide the mirror off.
Jul 01, 2009 | 2000 Toyota Avalon
1999 gmc jimmy rearview mirror diagram needed
It should just slide out. You might have to use a little bit of force
Jun 11, 2009 | 1998 GMC Jimmy
Custom Rear view mirror
Hiya...ALL factory-installed rearview mirrors are installed with different wires due to options.
About 6 different rearview mirrors are installed with those options such as On-Star, light, compass, and those features which use different wires....THIS CANNOT be modified with different rearview mirror....**for example, the Equinox owner attempt to pull out a factory-installed base rearview mirror and put in different one that has compass/temperature built into the rearview mirror**
However, the wires are located inside the front headliner which requires removing the sunvisor (and possible removal of interior plastic trim part at the left/right ends of the windshield) prior to pull the headliner down, and a small metal philips or torx screw is used to secure the rearview mirror onto the bracket glued to the windshield.
The best solution is to leave the original factory-installed rearview mirror in place.
May 16, 2008 | 2006 Chevrolet Equinox
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
