Question about Coffee Makers & Espresso Machines
Brand new. worked for five minutes then steam stopped. after another five minutes, started hissing, then water started squirting out of face plate
  • 3,960 Answers
Recommend contacting the seller customer service and arrange for a replacement or refund. Obviously, do not use it anymore.
Posted on Mar 31, 2015
Hot tub stuck in PR mode.
Are the pumps primed, the code represents that the pumps are being primed and should only stay on 2 - 5 minutes. If the pumps are not primed then you may have an air lock or dirty filters. You need to release the air or clean or replace the filters and your pumps will prime.
Mar 27, 2014 | Pool & Spa
;turn coleman hottub on - flashes "pr" for a few min. then it shuts off
If your Coleman has Balboa electronics 'PR' is to notify you that it is in priming mode.
It could also be your pressure switch. On most tubs the pressure is mounted on the heater. If this switch is not reading correctly it could shut the spa down to prevent heater overheating.
Sep 18, 2012 | Pool & Spa
Steam escaping?
do the following step:
1) distilled water and softened produce leak , change the water
2)put water until the LEVEL
3)give time enough thermostat for heating. if you use before to HEat enough produce leak.
4)switch dial off to test the water stop leaking,when the steam setting is NOT working.
5) shake back and forth for a few time, to turn on back it is auto-off function.Can be leak when is auto-off mode
God bless you
Jul 14, 2012 | Irons
My Europro shark steam mop won't steam, light on but no steam.
Hard water deposits. I ran some white vinegar through mine, like a coffee maker, and it worked for a while, but clogged again. So I unplugged it, let it cool and turned it over in the bathtub and squirted a small amount of Lime-Away into the hole where the steam comes out. Let it soak for 5- 10 minutes and it is working like is is brand new.
Sep 15, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Model 1400 little green cleaner does not squirt fluid
its just the prime.if all the water is let out of the hoses it will need to be reprimed with water again.once water fills the hoses it will work fine
Dec 10, 2008 | Bissell 1400 Little Green Pro Canister...
Saeco Magic squirts water out the wand when brewing
Hi Steve,
You have to replace the gasket on the steam pin, maybe you have to replace the steam pin to if it is worn.
Apr 11, 2008 | Saeco Magic Cappuccino Espresso&Cappuccino...
The frothing stick doesn't seem to work
descaling time not with vinegar with descaler vinegar remove calcium in little piece descaler melt it use 1 part descaler 1 part water put in the water container start it up open valve after a few second turn it off leave it for15 minute repeat untill empty after do 2or3 rince descaler is corosif thank you for using fixya pierre
Feb 10, 2008 | Dualit Espresso 889 Espresso & Coffee...
Coffee Makers & Espresso Machines Logo
59 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
