Question about Mitsubishi WD-60737 TV
My tv keeps saying that it has found a new audio receiver and changes the setting to either headphones or a receiver. i don't have any receiver or headphones hooked up to this tv.
It alerts me and then i have to reset the audio to tv every time. it does this about 15-20 times before it finally stops and it is driving me crazy. what can i do to fix this?
2 Suggested Answers
Mustgo
  • 2359 Answers
SOURCE: the "new device found" screen keeps popping up
Inspect for damaged pin on INPUT 1 socket. (left most of the three HDMI connectors)
A quick pull on the cable can damage the pins.
=== If you see mis-aligned pins then please power off the set before making corrective action. ===
============== Here's a textbook instruction from Mitsubishi
If the New Device Found Screen Displays No HDMI Control Option If the New Device Found screen shows no option for HDMI Control, one of these conditions applies: • HDMI Control is turned off in the menus of the new device Action: a. Highlight EXIT and press ENTER to close the New Device Found screen. b. Display the device's setup menus and enable the device's CEC capabilities. c. Wait for the TV's New Device Found screen to appear again. d. If the New Device Found screen does not appear, power off the device. Power on the device and wait for the New Device Found screen to display with the HDMI Control option.
Next time you see the NEW DEVICE FOUND screen pop up.
Toggle the CEC field (on the right side of the pop up) to OFF.
Posted on Jan 05, 2011
How do i put my pioneer receiver to my cable tv,dvd. vsx-917-v-k
For this purpose I am using headphone output of the TV set. I connect the headphone output to the AUXiliary input of the receiver. All you need is an interconnection cable, one end with 3,5 mm stereo male earphone jack, the other end with a pair of RCA jacks. This output of TV provides an additional output signal to your receiver but volume control behaviour (independent volume control for earphone output etc.) changes for different brands of TV sets.
Jan 04, 2015 | Pioneer Audio Players & Recorders
GE audio/video switch AV93294 has what appears to be a adapter port on front , no voltage given. Says audio output. Please explain
As the label says, it's an audio output. The audio from whichever source you have selected appears at that jack so you can plug in something like a pair of headphones or the cable to a wireless headphone transmitter. If you don't have anything to connect there, don't worry about it. It's a convenience, but you don't need to use it.
Aug 14, 2011 | Audio Players & Recorders
I have a set of T 912 wireless headphones. I am unable to set them up on the TV. I am using the white and red cables from the base station to the TV audio red and white. Do you have any instructions on...
The audio jacks on the TV are most likely inputs, not outputs. They're meant to take the audio signal from something like a DVD player, along with the video input on another jack, so you can play it through the TV. There isn't an audio signal coming out from those jacks, and if you connect your headphone transmitter to them all you'll get is silence. Almost all sets now have at least one set of AV inputs, but most don't give you outputs. The manufacturers figure the TV is just a display device, and not a signal source.
Unfortunately, there isn't any easy way to connect your wireless headphones if the TV doesn't have audio output jacks or a headphone connector. If you're comfortable with soldering and willing to do some modification to your TV, it's possible to add a headphone jack. Most people don't want to start tinkering with their sets, though.
If you're using your TV on a cable system without a converter box and the cable hooks right to the set, you're out of luck unless you're willing to add a headphone jack as I mentioned before. But if you have a cable converter box, or you're using a satellite receiver or other set-top box, you can use your headphones with those. These devices typically have direct audio and video outputs available on the rear panel, and you can use that audio output to feed the headphone transmitter.
What most people do these days is use a home theater receiver along with the TV. All sources (the cable box, DVD player, video game console, audio CD player, etc.) connect to the receiver, and the receiver's audio and video outputs go to the corresponding input jacks on the TV. This way, the TV is just the end of the line. The receiver also would provide an output for the wireless headphone transmitter. This system offers some advantages. You'll be able to connect the proper speakers to enjoy surround sound when not using headphones. And you'll be able to use your wireless headphones with the tuner and audio sources like music CDs when not watching TV.
My garmin 660 won't transmit audio through speakers or fm transmit. I go to audio output and it says that "Audio output can not be changed when using headphones" I can use it with headphones...
You have a problem with the headphone jack. Please see this link and read the section about BROKEN HEADPHONE JACK
http://www.sharc.net/gps_audio_repair.htm
Because there is a broken connection, your Nuvi thinks there are headphones connected at all times, so you wont be allowed to change the sound options. I've repaired this problem many times. Don't try it yourself, you risk damaging your Nuvi beyond repair.
- Jim
SHARCNET-USA
Jul 19, 2011 | Garmin Nuvi 660 GPS Receiver
Dont have my manual. i can't get am reception and it was good before. am reception is fine. also have a new lg led tv and the only audio coming out of the tv is an optic one, my onkyo tx-8511 does not have...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-8511-Receivers-manual/id/365ci176/t/2/
As far as the TV audio goes... unless it is the primary source of the audio (tuned through its own antenna and available no where else) why don't you just run the actual primary source's (cable/sat, whatever) best digital audio straight to the Onkyo and skip the middleman that adds nothing to it but expensive unnecessary cable hops.
I'd also run each video sources absolute best video straight to the TV for the same reason.
Apr 15, 2011 | Onkyo TX-8511 Receiver
I cant get any sound I did the trouble shooting
Changing the Audio Output
To switch audio output from the internal TV speakers to a connected external sound system or headphones:
Press 1. MORE.
Press 2. 9 (AUDIO).
Press 3. until the Speakers option is displayed. The Speakers option will display only if an A/V receiver connection has been detected.
Press 4. to switch between TV and either AV Receiver or Headphones.
Check if the MUTE key is on.
• The TV's "Listen to:" setting may be set to SAP (analog program from the ANT input) but no SAP is being broadcast.
• Check that the Speakers option is set to TV to hear sound from the TV speakers. Possibly sound is being sent to one of the audio outputs for an A/V receiver or headphones.
• If using an A/V receiver, check that the Speakers option is set to AV Receiver to hear sound from the A/V receiver speakers.
Press and hold the POWER button on the control panel for 10 seconds to perform System Reset.
Mar 07, 2011 | Mitsubishi LT-40151 40 in. HDTV LCD TV
Innovage wireless headphones/how to connect to TV?
I have a plasma, and found when I plugged my HDR65 to back of the plasma audio out, it worked fine. does this help?
Jan 06, 2009 | Audio Players & Recorders
Connecting new tv to DRA-685
you can use the headphone jack just get an adaptor to change from the headphone type to RCA type. adjust the volume of the tv to 3/4 of the way to give line level to the stereo, use an aux input on the stereo. if you had a suround sound dolby digital / DTS receiver then use the digital coax out to that type of receiver, but since you have an anolog 2 channel receiver you must use the only anolog source (the headphone).
May 21, 2008 | Denon DRA-685 Receiver
My onkyo tx-sr705 produces a humming noise out off all the speakers when no audio is played
I found the source of my hum. I have Direct TV HD. I found that going into the menu settings (Direct tv HD Receiver) /Audio/Sound Effects and turning that option off, I was able to rid myself of the annoying hum. The option has something to do with keeping the audio settings from channel to channel, while it is changing you hear dead air except for the hum. Nice and quit now. Love this receiver!
Mar 06, 2008 | Onkyo Audio Players & Recorders
Motorola DVR headphone problem.
are you connecting the headphones to the tv or cable box. Also is there any home theater systems being used in this setup
Mar 12, 2007 | Arris DCT6200 DTV Receiver
Mitsubishi WD-60737 TV Logo
44 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
