Question about Moentrol Pressure Balancing Volume Control with Built-in Three Function Transfer Valve with Stops - 1/2" CC
Why the water flows from shower head and faucet at the same time after moentrol valve installed?
frcs68
  • 1605 Answers
SOURCE: shower head leaks water when water is turned on
take out the cartridge from the fixture and make sure it has all of the "O" rings and stoppers.
look at the instruction again, make sue you are installing it the right side up. if all that, the shower still leak, then you need to talk to the place you brought the fixture, it may have a defective cartridge.
Posted on Jan 13, 2009
  • 127 Answers
SOURCE: how do i install a moentrol 3320 transfer valve
You have water going to it just like a regular valve, but you run the water out of the 3 function piece to your different water features.
Posted on Apr 11, 2010
Dplumber
  • 119 Answers
SOURCE: I just installed a Glacier Bay tub/shower faucet
The faucet may be installed upside-down.
Posted on Aug 25, 2010
  • 4350 Answers
SOURCE: leaking shower/tub faucet, looking for replacement
Call Moen directly. They will ship what you need to your door, for free.
Posted on Sep 18, 2010
  • 1116 Answers
SOURCE: Installed moen 3510 moentrol valve in new shower.
Are you saying you get hot water, but when the valve is turn all of the way to the very hot position, the valve shuts the flow of water off?
Posted on Aug 26, 2011
Moen single lever shower handle gives only hot water
A bit more information is needed; is this a Moentrol or a Posi-temp valve? You will need to shut water down to the shower. If it is a Moentrol, it could be an issue with either the cartridge or the pressure balancing spool. If you are at least getting water, I am going to assume that it is a Moentrol.
You will need to turn water off to the valve. Pull the cartridge and examine as to whether or not debris is blocking the supply holes of the cartridge. If your valve has built in shut off screws, you can slowly turn water on to clear any debris that may be inside the inlet port. I typically use a piece of PVC to go over the valve body so that water does not leak between the wall and the shower. Again, just turn water on enough to start it flowing.
If you do not notice anything amiss with the cartridge, it could also be the pressure balancing spool. If that is on your valve, it will be a flat head screw about the size of a nickel. Water will need to be off for the removal of the spool as well. Again, you will be looking for debris that is blocking water flow.
If this is an older Moen faucet, you may just want to replace the cartridge while you have it removed. If it is a push/pull, it is a Moentrol. If you have to turn the handle for water to come out, it is a Posi-temp. In my area, the cartridges run from $20-$40. However, Moen does offer lifetime on their cartridges. Lately, I have had a few more hoops to jump through to get the replacement cartridges from Moen, but they are still very pleasant to deal with.
Oct 16, 2014 | Moen & Posi-Temp Single Handle Shower Or...
Why does moentrol bath valve give hot water pointed to "C" and vice versa?
Easy one.
Feel the pipes. The pipe on the right should be cold. If the pipes are correct, turn the cartridge 180 degrees.
Jan 20, 2013 | Moen & One Handle Tub & Shower Faucet
My water pressure is very low from the original install is there a way to adjust the faucet to allow a better pressure flow
Your issue could be caused by the water restrictor in the shower head. To know for sure, remove the shower head and then turn the water on.
Very tough water restrictions have manufacturers using plastic water restrictors in the shower heads.
Although you are not supose to, some shower heads can be taken apart to modify, or remove the restrictor.
I hope this helps you.
Jan 31, 2011 | Moen 3175 Legend One Handle Shower Faucet...
On new Moen shower faucet, when I turn on faucet, water drips from shower also.
The faucet was installed upside down.
The shower riser pipe in the wall is to short( the distance between the faucet and shower head).
One of the biggest problems is if your shower faucet was installed with Pex pipe to the tub spout. Pex pipe will restrict the flow and force the water back up and out of the shower head.
The tub spout must be piped with at least 1/2 brass pipe nipples and fittings, or 5/8 OD. copper pipe and fittings.
Hope this helps, if you further questions please let us know.
Sep 08, 2010 | Moen 3175 Legend One Handle Shower Faucet...
When you turn to hot it doesn't come out. Cold does.
Assuming that you have hot water at other faucets the problem could be a varnish buildup in the cartridge. After shutting off the hot and cold water either by turning off the main or at the faucet stops (if equipped), remove the cartridge and soak it in white vinegar to break up the varnish. You can clean it up with an old toothbrush and make sure that it is working. It should rattle when you shake it. new cartridges are not very expensive so you can just buy a replacement at any home center as well. If you are the original owner of the faucet Moen will send you a free replacement cartridge if you call them.
May 24, 2010 | Moen 3175 Legend One Handle Shower Faucet...
HOW DO I FIX A LEAKING FAUCET ON A MOEN L3189
you need to remove the cartridge behind the handle. If it is dripping from the spout or shower head.
If you pull the handle to turn it on it is called a moentrol valve and take a number 1225 cartridge....it it just turns to turn on it is called a posi-temp valve and takes a 1222 cartridge.
Oct 20, 2009 | Moen & One Handle Tub & Shower Faucet
Moen single handle bathtub faucet
Something is caught in the stem. Make sure the stem is free of debris. Also check that the valve or cartridge is intact.
Jul 02, 2009 | Moen 2919 Chateau Two Handle Tub and...
Just installed shower and faucet in bath tub when you turn the water on the water comes out of the faucet and shower head. When you pull the lever for just the shower the water cuts off at faucet and comes...
Verify the height from the shower valve to the Shower head, the instructions specify the correct distance if it is too short the pressure could be getting up to the shower head.
Perhaps the water pressure it too high at the valve not allowing all the water down the faucet outlet, there are set screws on the sides of the shower valve to adjust the water allowed in the mixing chamber.
Something is restricting the water flow to the faucet, creating enough pressure to send some of the ater supply up to the shower.
I hope some of these ideas help
Mar 01, 2009 | Plumbing
Shower Handle
You do not mention what make faucet we are talking about.
Moen makes two styles of Shower valves
The one that you discribe is called a Posi-Temp the goes from off to cold and to hot as you turn the valve counter clockwise.
The pressure should be greater mid range ans the cold and hot water mix but generally not noticeable.
A Moentrol valve is that should have been iinstalled in order to have greater control on temp and pressure.
Moentrols work but turning the valve clockwise for cole and counter clockwise for hot and pulling out on the valve for the water to come on.
sanray
Jan 09, 2009 | Plumbing
Moentrol Pressure Balancing Volume Control with Built-in Three Function Transfer Valve with Stops - 1/2" CC Logo
126 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
