Question about HEALTHRIDER Exercise & Fitness
My healthrider when I plug in the key, these words appear on the screen "***** canyon, part 2" I try pressing other buttons but those words keep appearing. Is the screen frozen?
Model is Healthrider H55t
  • 103 Answers
SOURCE: I have a Healthrider S500i Model #HRTL12991
Unfortunately the only way to repair this is to replace the actual console. (pad and console are all one unit) The other issue is that I do not believe the console is even available for this product unless you purchase it from a third party.
iconservice.com is the official parts site for healthrider and the console is not listed as available for this model.
Hope this helps, Tim
Posted on Nov 25, 2009
  • 43 Answers
SOURCE: healthrider s5001 treadmill stops during workout
check manual for maintance on walking belt lubercation- mtr shutting down to over heating-pulling too many amps to rotate rollers/belt and to move you. Friction problem
Posted on Jan 08, 2010
  • 3 Answers
SOURCE: My Healthrider 400se Treadmill slows down after 10seconds
Use only a single-outlet surge suppressor that is
UL 1449 listed as a transient voltage surge suppressor
(TVSS). The surge suppressor must have a
UL suppressed voltage rating of 400 volts or less
and a minimum surge dissipation of 450 joules.
The surge suppressor must be electrically rated
for 120 volts AC and 15 amps. There must be a
monitoring light on the surge suppressor to indicate
whether it is functioning properly. Failure to
use a properly functioning surge suppressor could
result in damage to the control system of the
treadmill. If the control system is damaged, the
walking belt may change speed or stop unexpectedly,
which may result in a fall and serious injury.
Posted on Apr 15, 2010
bwinton
  • 83 Answers
SOURCE: Belt slipping on treadmill
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Posted on Apr 30, 2010
bwinton
  • 83 Answers
SOURCE: belt is slipping on healthrider treadmill
Unit immoblize
reset the machine follow this steps and fix it. God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Dec 05, 2013 | Life Fitness 95T Inspire Treadmill
Mohamed1324
reset the machine use the small button to the side of power button and proceed according. God bless you
    • 3
    • 4
    • 2
Dec 02, 2013 | Exercise & Fitness
Does anybody know what a bar that looks like its loading on the bottom of the screen ans nothing works means on my x7i?
Reset the machine with the small button to the side of the power button, and disconnect the machine power cord by 2 minute and toucht the small swithc with the eraser pencil make click.
Now try again. However if the problem persist try this:
    • 3
    • 4
    • 2
God bless you
Nov 29, 2013 | Nordic Track Incline Trainer X7i...
FF appears on the display and treadmill will not operate
please follow this steps and fix it. God bless you
    • 1
    • 3
    • 4
    • 2
Nov 03, 2013 | Proform 695 LT Treadmill
Repco rp300tm
1) reset the treadmil.2) adjust the speed sensor, see the diagram attached. 3) Run the software calibration for easy diagnostic and fix it. God bless you
    • 1
    • 3
    • 4
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button 31d332da-cd1c-4885-8ae4-393941ca1930.gif
Oct 18, 2013 | Proform Perspective Es Treadmill PFTL99806
I cannot see You Tube on my I Pad
reset the system and try again.God bless you
    • 1
    • 3
    • 4
    • 2
Oct 16, 2013 | Exercise & Fitness
Rebok i run RE14301, plain blue screen. It was working until my son played with all of the buttons! We have tried turning it on and off and pressing the reset button but this does not seem to have worked
Instructions 1.
    • 1
    • 3
    • 4
    • 2
Oct 15, 2013 | Exercise & Fitness
Fitstride t920 treadmill faults
Reset the machine follow this steps and fix it. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
· 2
· 3
Oct 07, 2013 | Exercise & Fitness
PLO5 error message on Quinton Clubtrack treadmill
Try to clear the error message. God bless you
  • 2
  • 3
Jan 25, 2013 | Quinton Stairmaster Clubtrack 3.0 GymTough...
I have a T802 Healthstream treadmill that has an error 2 on it? Can't clear it.
Instructions
    • 1 Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
    • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3 Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
Oct 15, 2012 | Exercise & Fitness
Exercise & Fitness Logo
Top HEALTHRIDER Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
