Question about Health & Beauty
Need to put the blades back in cant figure out how
I dont know where the spring goes
  • shaveroutlet.com
    shaveroutlet.com Apr 07, 2015
    Hi Evans Repair, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What is make and model of the unit??
    Problem Solver:
  • 7 Answers
Maybe you should not have taken them out if you don't know what the hell you are doing. And you should have a manual that came with your shaver...for gosh sakes. Or google the instructions online.
Posted on Apr 07, 2015
4 Suggested Answers
  • 62 Answers
SOURCE: small blade is loose
Complete instructions on how to change the blades can be found on our website at www.andis.com under the service tab and then use and care. If you continue to have the same problem please call the Andis customer service line at 1-800-558-9441.
Posted on Jan 08, 2009
  • 8 Answers
SOURCE: I need picture diagrams on how to put the blades
You need to have the Model # and Make of the Trimmer in ? To help you
Posted on Aug 01, 2009
SOURCE: I can't find the manual
their is 2 long wires with a l shaped hook on the the smalles blade that goes on the bottom the points of those wires go in the holes in the bottom of it which is a white thing with 2 groves in it make sure the blade is facing away from where the screws go the take the plastic pad and put it in the 2 holes of the top blad the set it on their facing the same direction the push down till its flush the put the 2 screws back in
Posted on Feb 28, 2011
I have a yard machine 46 inc deck i took the deck off and now i dont remember where the pto engage blades spring goes model number 13rn771h729 yr. 2007
it will be near the rear of all the pulleys probably just above top of pulleys look for a simple hole where it hooks usually a 1 inch piece of stock
May 16, 2014 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
Cant put the springs back in on side of the blade
you will need the jigsaw-blade springs-putter-backer tool. Available from all good hardware stores.
Apr 02, 2014 | Dewalt Saws
Mfirefighter173@aol.comhave a craftsman 17 hp lawn tractor and dont know were to put the spring that engages the mower blades, had to take apart to put in new mandril and cant seem to find were to put this...
There are four pulleys on the deck. Two for the blades, one idler, and one tensioning. The two smaller ones are the idler and tensioning. The tensioning is the one on the right. The post coming out the top of the pulley is where the spring goes, it slides over the top and a clip goes throught the hole at the top of it to retain the spring.
I hope this helps.
Aug 18, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
How do I assemble the blade guard for my Makita Miter Saw Model LS1030? I accidentally disassembled the guard it when changing to a new saw blade. I cant figure out how to get the tension spring back in...
lay the spring into the plastic safety cover, you will see a catch for one portion of the spring, the cover plate goes over it and there is a tab on it to catch the loose end and then the center plate which screws on to hold everything in place, check by turning the plate that holds it onto the saw for free movement. You can go to makitausa.com and in the header area on the right type in your model number ls1030n and you can download or look at a breakdown to see what I am talking about. Let me know if you need more assistance, just found your question.
May 01, 2011 | Makita 10" Miter Saw LS1030N
I have a Porter Circular Saw, 18v, Cordless, 6 and a half inch blade. I'm a novice, so I unhooked the wire latchet that held the lower guard on. I figured out how to put the saw blade on, yet I have the...
Remove the battery, take the blade back off and you will see the holes for the torsion spring. what you will have to do is start putting lower guard on but pretenstion the spring so it will fit back into the proper holes, it might be a benefit to remove the small bumper so that you can move the guard more. when installing the blade you don't remove the lower guard just retract it and slide the blade in place. Usually there is a retaining ring to hold the guard in place but I looked at a breakdown and didn't see one. Let me know if you need more assistance before voting please. Thank you
Feb 02, 2011 | Porter Cable Portercable Pc186cs 18v...
Concept MS100 mitre saw blade guard dillema.
I have changed the blade a few times, There is no need to remove the spring, etc. All you do is remove the bolt holding the guard and rotate it counter clockwise and it exposes the blade.
I am looking for parts for this saw. Anyone know where to get them?
Jul 06, 2010 | Makita 10" Dual Bevel Sliding Compound...
The spring has fell out of the head when i was changing top i dont know how it goes back together
pull the black thing with the little blades until it detach, put the spring inside the hole, reassemble
May 09, 2010 | Braun Silk-epil 3370 Epilator
The spring from the back where you load the paper has pop out and I dont know where it goes, and now I can not print anything because the paper cannot go through? Can someone help and guide me to put
The location of the spring is located near of the sensor.The sensor is attached by the sweveld arm then install the spring in the center of the pivot area of the sensor.So that the sensor will goes up ,it need a spring to do the act.
May 28, 2009 | Epson Office Equipment & Supplies
Health & Beauty Logo
180 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
