Question about Garden
Carb leaks lots of gas gaskets look ok - Garden
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
Spray water with soap on it, then you will see where the fluid is coming from
Posted on Mar 31, 2015
Putting new gas line on as I have had lots of trouble with gas leaks. anyway gasket fell off of carb. can you send a pic of how it goes on? the gasket that is
Mike,
Sorry to hear the carb is leaking. This happens when the Carb Float Needle gets stuck and is easy to rectify.
If you watch this video on YouTube it will show you how to free up the Float Needle. It is the same procedure on all Carbs:
https://www.youtube.com/watch?v=7LrBmeBcVnA
Dec 20, 2016 | Sigma Powers Inc Rural King 6,500 Watt...
Why does the carb not prime with fuel?
Check the primer bulb. If it has a small hole or leak it will not generate the suction with which to suck the gas in to them prime the engine. And make sure that the top of the carb with the bulb is firmly attached to the rest of carb to prevent any base leaks by the primer.
Sep 20, 2015 | Garden
Why won't it run?
If the carburetor is ok, check the fuel pump. If it had bad gas in it, the tiny diaphragm gaskets within the fuel pump might be gummed up a little. You can check the pump volume if you remove the fuel line from your carb, aim it into a bucket or other receptical, and watch it pump. The gas should pulse smoothly with a little force. I'm not sure how to describe it, but it should be more than just a trickle, in other works. If your pump seems to be doing ok, and all of your fuel lines are clean and clear, the problem may be an intake manifold gasket leak, a carburetor mount gasket leak, or the intake manifold itself may be leaking. The intake manifold is two-piece, pressed aluminum with a sealant in between the two pieces. A leak at any of the three locations I mentioned would cause the problems you're experiencing. The fuel would of course reach the carb, but due to the any leaks, the vacuum needed would be decreased to the point that it wouldn't be enough to draw the fuel through the carb.
Hope this helps.
TW
Apr 21, 2015 | Bobcat Miller 225 Welder Generator 907209...
2012 blowing lots of smoke mixture ok carb ok could it be gearbox oil seal near new bike
is the oil emulsified with water as you mite have a seal or head gasket leaking ? when was it last rebuilt as it is a competition bike and needs to be done more than a road bike ! ?? i would strip the engine and replace all seals and gaskets as its cheaper than a new crank etc !
Feb 28, 2013 | Sherco Motorcycles
Engine will only run if gas is manually put into carb
hi there galawson
provided compression and spark are ok and exhaust is clear
sounds like unit has a air leak and is not creating a vaccuum / pressure impule to operate the pump diaphram in the carb - pressure and vaccuum test the crankcase to see where the air leak is comming from
it could be c/case seals, base gasket, carb gasket -insulator block gasket, manifold intake boot , impulse tube split /broken or the carb just needs to be rekited with new gaskets/daiphrams / needles /levers etc
you willhave to remove muffler and carb block them off with rubber and a metal plate and pressurize to 7- 8 psi throug the spark plug hole with the piston at btc
you will soon hear and see a air leak if you use saopy water to brush around the area
replace faulty / leaking parts and assemble
cheers hope it helps
pauly 46
Sep 15, 2011 | Garden
Husqvarna 324L 4 stroke, runs fine, but leaks gas, from carb whil
gasket is worn out. You can buy a generic gasket set from your local lawn shop
May 29, 2010 | Husqvarna 28cc Gas Line Trimmer
Runs in idole, but boggs down and quit when i give it gas....(double edge echo hedgetrimmer 1500 gas power
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Dec 03, 2009 | Echo Garden
Craftsman gas leaf blower will not start. Spark and gas lines ok. Not getting gas to plug even after prime and several pulls. How do I find gas supply problem. Diaphram in carb looks ok .It actually...
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
1) spark plug
Chain Saws:
Remove Carburetor
Nov 25, 2009 | Craftsman Garden
Craftsman gas blower no start
Basics to check:
b) is there spark
1) spark plug
Chain Saws:
Remove Carburetor
Will not start. few months old. maybe bad gas
Basics to check:
b) is there spark
1) spark plug
Chain Saws:
Remove Carburetor
Nov 15, 2009 | Homelite Consumer Products Backpack...
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
