Question about Garden
Oil is coming out the two holes that fit to the air filter, what's wrong?
I purchased this mower late last summer. Only used it for a few times and put it up for the winter. Mowed a bit two days ago and all was fine. Got it out today to mow and did. When I finished, which wasn't much and this is what has happened. What is wrong?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
That's probably caused by excess crankcase pressure. The rings on the piston could be slightly stuck in the piston grooves allowing a bit of 'blowby' into the crankcase. Try a bit of 'Seafoam' mixed in the gas as an upper end lubricant and with a little use the rings should loosen and begin doing their job of keeping the compression on TOP of the piston and not bypassing into the crankcase.
Seafoam is a general system lube that can be used in fuel, oil, transmissions etc. Marvel Mystery Oil would be a good choice to loosen things up a bit too.
Posted on Apr 01, 2015
MNfisherman
  • 11896 Answers
SOURCE: lawn mower won't start
Carb is most likely gummed up and will need cleaning. Anytime a gas motor is store through a season, you should use a product called "stabil" in the gas to prevent gumming up. Also check that there is a strong spark coming from coil. To do this, remove spark plug, hook it up to the coil and set it on motor block and pull it over. You should see a strong spark. If you don't see the spark, then either the coil is faulty or the magnet from coil to flywheel is not getting good contact.
Posted on Jul 03, 2009
SOURCE: Mower won't start - has oil/gas & just used last week
take the air filter off and rub it on your balls
Posted on Apr 17, 2010
  • 72 Answers
SOURCE: my 2 year old craftsman
Check for a spark to start off with. I just had to replace the coil in mine.
Posted on May 17, 2011
  • 14 Answers
SOURCE: My JCB 5.5hp mower starts then chugs and stalls after about 10 seconds. I do try to adjust the choke but to no avail. Can anybody advise please
The carburetor might be dirty. I would clean the carburetor and replace diaphragm if your carb has one. Sounds like the engine is not getting enough gas to stay running. Hope this helps!
Posted on Jun 14, 2012
Healeyman
  • 1198 Answers
SOURCE: Oil coming out of air filter
Look for a crankcase ventilation tube or such, It may be covered with grass dust and stuff, is probably a sponge to keep dust out of the motor. Rinse it out, and make sure the airway is clear.
Posted on Nov 25, 2013
Oil is coming out of the two holes that connect to the air filter. What is wrong?
Check your oil and see if its too full. Over filling will do that and you could do damage if you run it that way as well make it impossible to start.
Mar 31, 2015 | Garden
Tip
Basic lawnmower spring maintenance
Before it gets too late its worth firing up the lawnmower (and any other garden power tools) to make sure they are running well for the coming months. Here are a few basic tips to make sure it will be worry free for the summer.<br /> <br /> Give it gas: fill it up with fresh quality gasoline (mixed properly with fresh oil if its a 2 stroke). Old gas is not the same as new gas, volatile compounds will evaporate over time leaving you with gas that is harder to burn. Ideally you have used up everything in the tank the previous fall.<br /> <br /> Let it breathe: make sure the air filter is clean. For foam filters you can just clean them with a bit of gasoline (you can use the old stuff if you still have some). Paper filters need to be replaced, typically every year.<br /> <br /> Light the fire: a strong spark is the key to reliable ignition. If the first two tips don't give good results its probably time to change the spark plug.
on Jun 13, 2011 | Garden
Oil leaking out on yardman mower
You haven't supplied a lot of information but generally when this happens it is due t the mower being tipped the wrong way.
If you must look under the mower then tip it back with the handles to the ground and front wheel in the air.
Now to rectify your problem; The air-filter will probably be saturated with oil. It will probably be the cartridge type which is not serviceable. Purchase a new filter (take your old filter so the sale person can compare like for like). Before you refit the new filter, take out the sparkplug, it will probably be saturated in oil - wash it in petrol, let it dry then refit it. The engine should start and belch out great quantities of smoke. Don't be alarmed this will burn away. Once the smoke has cleared, check the oil level, fit the air filter and mow your lawn.
Jul 18, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Husqvarna 6021p won't start
Make sure spark plug wire is connected and that plug is not blackened and fouled out. Also check your fuel filter (plugged?), the handbar safety lever & it pull cable and make sure it is opening the breather assembly down at the motor or closing the proper switch (unsure of the setup) Those are typically the most common problems. Good Luck
Jun 07, 2012 | Husqvarna 6021P 21-Inch 149cc Kohler XT-6...
Purchased lawn mower last summer this year it will not start.
change gasoline, spark plug, clean air filter after setting for the winter the carburator gets a buildup in it from the gas, you may have to use starting fluid to get it to fire over.
May 03, 2011 | Garden
Had a problem with my Sears riding mower late last summer. It runs for like 5 minutes then will conk out. I wait 5 minutes 10 minutes or so, it starts up and conks out again like after 3-4 minutes. I...
check your gas tank cap, it is vented, if it gets clogged up fuel will not flow properly and engine dies of fuel starvation. By waiting a few minutes you have allowed the pressure to equalize in the tank enough to get enough fuel for engine to run.
Mar 05, 2010 | Garden
Self-Propelled Model Starts, then dies after about 15 seconds
I posted same problem as this couple days ago. Took mower to shop. The governor spring (located just under the air filter) had come off. So glad it was something so minor!
Jul 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Lawn mower blowing out white smoke
Change the oil...it is diluted with water or gas
Apr 05, 2009 | Garden
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
