Question about Sony Car Audio & Video
How to fix static problem on sony xplod cdx ca 750x
Installed a sony xplod cdx ca 750x cd player in my car recently, hooked up everything, cd player works but when turning to fm only static is heared, resetted, turned local off, problem stays
5 Suggested Answers
SOURCE: Sony CDX-MP40 only works after hitting reset button
If you dosn't find a solution, then I'am very interested in buying the faceplate for this unit. batman@galnet.dk
Posted on May 25, 2008
welcomejee
  • 10594 Answers
SOURCE: need a wiring digram for a sony xplod cdx-gt300 cd
Click Sony Support to dwonload installation guide of CDX-GT300
Posted on Oct 22, 2009
Lexdiamonzz
  • 203 Answers
SOURCE: sony xplod am/fm cd model cdx-m610 will play cds
Make sure that you have the antenna plugged in and if you have a power antenna make sure that you hook up the solid blue antenna wire behind on the radio harness to the power antenna wire from the car plug.
Posted on May 21, 2010
  • 29 Answers
SOURCE: how do i reset my clock on my sony xplod cdx
To set the clock:
Press and hold the select button until the setup display appears.
Press the select button repeatedly until "CLOCK-ADJ" appears
Press SEEK + (the hour indication flashes)
Rotate the control dial to set the hour and minute. (To move between hour and minute, press SEEK + or -)
After setting the minute, press the select button and the setup is complete.
To display the clock, press the DSPL/SCRL button.
Posted on Mar 15, 2011
I recently installed my sony xplod to my jeep and the radio, volume works fine. when i insert a cd, i hear nothing, counter and track displays but no sound...please help
are you using an amplifier? if so, it sounds like you are using the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) to turn the amplifier on.
Feb 17, 2011 | Sony XPlod CD Player w/MP3 Playback...
Display works and cd will play but it wont play am or fm radio
if you installed yourself make sure u hooked up the antenna
Dec 03, 2010 | Sony XPLOD CDX-GT200 CD Player
My sony explod cd for my car wont power on everything is hooked up and it will eject the cds but nothing else..what do i do?
check the radio fuse on your car most likely its bad. If you pull out the radio the red wire should have power when the key is turned on and if not you have a fuse problem
Jun 14, 2010 | Sony XPLOD CDX-GT200 CD Player
No sound to the subs
Possible solution: Check to make sure your ground connection is connected to metal that is NOT covered in paint. This is not a solid connection and can ruin your amp over time. Simply scrap away the paint and re-connect. This was a problem i ran into recently.
Jul 27, 2009 | Sony XPlod CD Player w/MP3 Playback...
Wiring color meaning
did you buy a factory radio connector to connect the old harness to the new radio wiring if not you can get one at wall mart for 20 dollars and it will be color coded
Mar 08, 2009 | Sony XPLOD CDX-GT200 CD Player
FM Radio won't work on my Sony Xplode XR-C5300X
Same issue here, hardly used the unit, and have no radio reception, all else works including the CD changer
Dec 14, 2008 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
Cd player
DOES IT TRY AND SPIN THE CD>?
or does it just kinda click and then spit it out?
May 30, 2008 | Sony CDX-M800 CD Player
Sony xplod cdx s11
press Sel until you get on display "Low" adjust level with volume keys + and -....
jgospodaric
Nov 29, 2007 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
Car Audio & Video Logo
53 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
