My washing machine will not spin when on the Normal Cycle. What do I do to fix this?
If I manually put it on drain and spin it will spin, but the timer says 13 minutes, then takes about an hour. The Normal load is also taking 3 times it should and then won't spin.
  • Washing Mach... Master
  • 5,323 Answers
No spin, or lite spin try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand.
Posted on Apr 13, 2015
  • 417 Answers
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Posted on Nov 04, 2008
duby1990
  • 367 Answers
SOURCE: How long should a normal wash cycle take on the whirlpool duet?
One hour and 10 minutes is normal for your washer. All front load washers take a long time. They wash a lot better than top loaders. So to answer your question.. yes its normal.
Posted on Nov 19, 2008
  • 21 Answers
SOURCE: Timer stops at the end of wash cycle, won't began drain cycle
if it fills and agitates but stops at the drain/spin portion, it sounds like you have a problem with the lid switch. if it thinks the lid is opne, it will not drain or spin.
Posted on Dec 29, 2008
  • 135 Answers
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Posted on Jan 22, 2009
  • 713 Answers
SOURCE: after the wash cycles the machine wont drain or
Hi just read your posting .Sorry to ask you this about your lights being on but I need to be sure.Now how many lights do you have in the row that the lights are lit?Is it 8 in total?Now starting from the far left please tell me if it is the 1st and 4th or 3rd and 6th and 8th etc.I just need to be 100% sure because my manual says it is the display module that is faulty and they are not cheap.Please reply and I am sure I can rectify this fault for you.
Posted on Jun 11, 2010
Testimonial: "This person is efficient and I'm so thankful for their help thus far!!"
My washing machine won't spin on a normal cycle only if put on spin and drain
If your washing machine is fairly old, it's quite possible the relay to tell the machine to spin is worn out and needs to be replaced. Call your service dept with the make and model and explain the symptoms. If you still have the manual, consult that also for troubleshooting.
Feb 02, 2016 | Washing Machines
417 44152400 21 code reads e63 and machine not draining properly
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
Nov 01, 2013 | Kenmore Front Load Washer
Won't spin cycle
when sitting for the last spin it may be out of balance,when you have no cloyhes in it,put 1cup of HE clorox bleach and let it sit in tub over nite,then run on heavy duty wash hot water cycle.(no clothes) this should open up drain pump.this may take several trys.
Jul 31, 2010 | Bosch Washing Machines
Washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Mar 19, 2010 | Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
F02/Sud error message fabric softner will not dispense
The pressure switch is sensing that there is still water in the unit,it sits at the top of machine under the top cover,it is round and usually red in color remove the hose/tube from it and blow through it to make sure it is clear,you can also remove the switch itself and lightly blow into it you will hear a couple of clicks put it back together and give it a shot..
Sep 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Our hoover ultra care 1300 large load washing machine spin fault
Jan 21, 2009 | Hoover UltraCare HC6 130M Front Load...
Washer won't drain and clothes stay soaked
Can you give me a model and brand name. Does the washer drain at any time during the wash cycle?
Will it go into a spin at all in any setting? heavy duty, normal and delicate cycle? is water not draining?
Jan 11, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
