Question about Garden
How to adjustment static governor on a quantum xe 40 briggs and Stratton lawnmower please thanks Robin
  • RobinRossiter
    RobinRossiter Apr 02, 2015
    all fixed now thanks
  • 1,169 Answers
1. Move throttle control to wide open throttle position,
Fig. 45.
2. Loosen lever adjusting screw. Item 8
3. Turn governor crank counterclockwise and hold.
4. Torque lever adjusting screw to 15 in. lbs. (2 Nm.).
how to adjustment  static governor on a quantum xe - 25620370-nglq0ryxf00y1tryejqwkudb-5-0.png
Posted on Apr 02, 2015
Need a throttle linkage diagram for a briggs & stratton engine model 9S502 type 0620-B1
David, This is what I found in google search for B&S carb. linkage diagram, you can also do a search because there are lots more.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Linkage Spring replacement on Briggs Stratton Quattro 4 HP Murray Lawn...
Repairing Lawnmowers For Profit Part 61 Governor Spring Help
briggs and stratton governor linkage diagrams Google Search
briggs and stratton carburetor linkage diagrams Google Search
Jun 10, 2016 | Briggs & Stratton Garden
Manual for briggs and stratton 12000 series mowers quantum
B/S makes the motors for several brands of mowers. Go to the web site and search your model for a download.
Oct 07, 2014 | Briggs & Stratton Quantum Lawn Mower...
How to adjust the governoron a briggs and stratton 44F1
That's not something normally required - governors are usually factory set and very seldom fail. Why do you think you need to adjust the governor on yours?
Aug 03, 2014 | Briggs & Stratton McLane 21Inch 625 GT Gas...
13.5 intek governor adjustment
they are touchy let shop do it for you so you dont blow up engine
Jul 11, 2014 | Briggs & Stratton Briggs Stratton...
Rover QuantumXTL 50 mower wont idle
clean the carby or could have bent governor arm where spring goes
Feb 03, 2013 | Briggs & Stratton Briggs Stratton...
Hello, I am using the Craftsman 675 Brigs & Station 190 cc lawnmower, and I'm trying to turn up the throttle. It apparently does not have a throttle adjuster, and I was wondering if there is any way...
After researching the engine application, I see that this 675 is NOT an OHV engine. It appears it is the L (flathead) engine with the standard features. The 775-875 Platinum series mowers have OHV engine applications. That being said, many mowers have the carburetors with the governed throttles set to run at the the OEM mandated maximum speed. Some (like the Briggs Quantum series engines) have the throttle plate still attatched. You would need to bend it back up and install an aftermarket throttle cable assembley (like Murray makes). You would connect the carburetor end of the throttle cable to the hole in the plate assembly that has the governor spring attatched. Some even remove the governor entirely (internal governor has to stay in) and connect a throttle cable on the plate controlling the butterfly in the carb. Your unit may have this feature with the plate having a few different holes in it in which you could install the end of an add on throttle cable.
Apr 09, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Hi, I just need to replace the spring governor, but because the old one was broken I am not sure of the placement of the new spring, I have been trying to find a diagram so that i can see how it connects...
Kmossman,
There are many different set ups for governors. Typically the spring goes from the arm of the governor shaft ( the one that comes out of the block) to an extention on the throttle shaft. If you have a better picture (larger) you can send me I should be able to mark the locations for you.
Chris at iaff801@snet.net
Jan 09, 2011 | Briggs & Stratton Briggs Stratton...
Garden Logo
282 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
