Question about Kenwood TS-850S AT Transceiver
Does it have 11 meter band and can it run on 27.555
  • Kenwood Master
  • 3,368 Answers
That is not legal
Posted on Apr 03, 2015
How can i buy a galixy 27 at and how much its a antenna
Google the model and you should find if it still is available, usually if 11 meters (CB) or Ten meters (ham band just above the CB band any antenna for those areas are adjustable to use for one or both bands.
Dec 19, 2012 | Televison & Video
Fix my connex 3400 hb sideband button
Hi there, if you are talking about the Connex CX 3400 HP there is no sideband or SSB on this radio. It is only AM and FM 10 meter Ham radio. Many people do modify these radios to include the 11 meter frequencies which is the CB band. Maybe knowing the actual bands and their frequencies will help some too this radio does have 6 different bands ranging from (Band A. 28.015 thru 28.455) (Band B. 28.145 thru 28.585) (Band C. 28.115 thru 28.555) (Band D. 28.085 thru 28.525) (Band E. 28.055 thru 28.495) (Band F. 28.025 thru 28.465.) I hope this will help you. Bob
May 13, 2012 | Connex CX-3400hp AM/FM 10 Meter Amateur...
Midland 75 785 purchase from us will it work on uk channels
  • For 11 meter (CB) the standard 40 channels will be the exactly same as the "EU" set of frequencies (channels). However the "UK" 11 meter (40 channels) and the U.S.A. 40 11 meter (40channels CB) will not work together at all. This includes any actual Citizen Band radio, excluding Export 10 an 12 meter radios often labeled as "CB'S" which they are not.
  • Hope this helps.
Oct 29, 2011 | Midland 75-785 Handheld CB Radio
I have purchase a midland 75785 cb isit compatable with uk chanels
  • Hope this helps.
Oct 29, 2011 | Midland 1001Z 40-Channels Base CB Radio
Convert to a 11 meter band radio.
CB............... citizen band is 11 meter.
That is an 11 meter with Single Side Band radio.
Sep 02, 2011 | Ranger TR-966 CB Radio
Just buying magnum s9 radio can it be used on 11 metre band or has it got to be modified for 26-27 cept channels as i think its just a 10 metre radio please advise many thanks.
Hey,
The magnum S9 is factory set for the 10 Meter band but can be "tweaked" to get up into the 11 meter band...
check out this neat and easy mod:
http://www.radiomods.co.nz/magnums9mod.html
Hope this helps!,ben
Jan 13, 2011 | Magnum S9 Base CB Radio
I have a FT-8900 and want to be able to open the AM side so I can use it on frequency 26.805 is there anyway it can be done
The Yaesu FT-8900 is a quad band FM transceiver only. It can not be modified to receive or transmit AM, SSB, RTTY or CW. It works on all or portions of 70 centimeter, 2 meter, 6 meter and 10 meter bands. The 26.805 Mhz frequency is 11 meters, so it is out of range of the 10 meter band in the radio, it is close. Even if able expand the transceiver, the AM / SSB mode commonly found in this band makes it impossible to use. Further, the radio is not FCC Type Accepted for use in this band.
Sep 05, 2009 | Yaesu Radio Communications
Gtl dx will not transmit below 26.955
First off, the 200 GTL DX is a 10 meter radio. Running it on 11 meters (CB) is illegal, as it is not FCC type accepted. If you go below 26.965 mhz, you are outside of the 11 meter band, and operating illegally.12 meters does not start until 24.930, so ultimately, the freq's between 24.930 and 26.965 mhz are restricted even to a licensed amateur radio operator.
Jul 09, 2009 | Cobra Radio Communications
Information on how to use DX 45MP radio
The DX 45mp is a 10 meter radio meaning you need a license to use any other band other than the normal 1- 40 cb channels, its capable of going beyond the normal cb range.Ask if it has been converted to 11 meter. Channel E should be the normal if it has been converted from 10 meter to 11 meter. Im sure its been converted if its been used for a mobile cb application. Normal cb band is called 11 meter 26.965 mhz to 27.405 thats 1- 40 . Your not supposed to talk on the other bands unless you have an amature radio license but everyone does anyway . I have several galaxys and by far in my opinion are the best on the market. Go to www.cbtricks.com on the home page go to Radio Informaion click it go to G and follow it to Galaxy DX radios youll find all the info for this radio you can even print out the channel chart to see where everything is. Good luck and if you have any more questions just ask. Thank you Chia
Nov 05, 2008 | Radio Communications
10 meter portable
There is no factory made 10 meter CB Radio made for US use. CB Radios use 11 meters, and the FCC doesn't allow the combination of 10 and 11 meter radios combines. Although, many people modify 10 meter radios to work on the 11 meter ( CB ) band, it's not legal. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 15, 2007 | Magnum 257 CB Radio
Kenwood TS-850S AT Transceiver Logo
300 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
