Fail to print red dot opposite toner is on nver seen it before and got no instruction manuel
  • 744 Answers
Tell us Make &Model # or you can also Google it to find a manual.
Posted on Mar 31, 2015
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
I have a samsung scx 4521f printer and wen i print thru it black dots on the paper appears..
This is likely to be either residual toner left from a previous leaking toner or that your toner has leaked in the printer. I would recommend running off 30 or so pages and seeing if the dots begin to disappear. Failing this either replace the toner and request a replacement from your retailer.
Nov 18, 2012 | Samsung SCX-4521F Laser Printer
I just purchased a Samsung Multi function color laser CLX-3175FW printer. It prints very light graphics. Eventhough I've set it to print graphics to the best setting, this doesn't help. The...
if you installate the printer you will find the Samsung (Blue) Logo with one watch in your taskbar on the bottem of your screen, double click on this icon, in the new windo click on Printer Setting then on color now you see an buttom "Color Adjustment" click on it, in the new window you can adjust your color via a slitswich for each color, try how you like your printout best.
May 10, 2011 | Samsung CLX-3175FW Multifunction Laser...
Laserwriter 8500 "dirty" print outs
Toner bubbles are characterized by large blotches of color toner on
printed pages caused by color toner leaking from cartridges directly
onto the transfer drum. Solve the problem of toner bubbles by checking the manufacturing codes on the toner cartridges and replacing cartridges as needed. Compatible carts are notorious for this so don't use them.
Heat-stamped on the toner cartridge, opposite the label-end of the
cartridge, is a manufacturing code. If a portion of the code does not
match the list below, replace the toner cartridge.
Use toner cartridges that contain any of the following manufacturing
codes:
 9I
 9J
 9K
 9L
 any cartridge that begins with the numbers 0 through 6 in place of
the 9
Oct 09, 2008 | Apple LaserWriter 8500 Printer
Dots when Printing
Replace toner then you cam make sure wether problem with toner or printer.
May 22, 2008 | HP LaserJet 1020 Printer
Fuser Error
I truly believe that you did not take the fuser out. It is not a simple process and is not readily accessible.
You most likely took out the toner cartridge, which works with the fuser.
The fuser is what "fuses" the toner to the paper so the documents print as expected. There are fuser kits that can be purchased, and they usually come with some decent instructions.
in case of new printer
A fuser problem is serious but if it is is a new printer, use the warranty now. Don't play with it as more than likely you can't recover and you *MAY VOID* the warranty in any attempts, so use the warranty. You should have returned it immediately once the problem cropped-up to be within the quicker satisfaction settlement period, you may now have to deal with a warranty center if not the vendor themselves for repair, but start the process. Plus, document this as well, cal,s letters, etc. to best serve yourself if any other problems arise.
To explain what the fuser is, one must explain what the fuser does.
A laser printer works by assembling the page in its memory, then transfers that "image" by scanning a drum. The drum then picks up a charge which will attract the toner. By varying the laser you can induce specific dots, creating an image on the drum. The drum is rotated through the toner, the charge then attracts the oppositely charged toner particles (the uncharged sections don't have anything) The drum, now dark with toner, is touched to the paper, which has an opposite charge, thus transfer all the toner over to the paper. Then the paper is sent THROUGH the fuser, which basically MELTS the toner onto the paper permanently.
If the fuser is too hot, that means the temp control unit for the printer fuser has FAILED, and that is NOT something you can fix by yourself. The labor will likely cost more than the printer unless it's under warranty.
You took out the toner cartridge, which is NOT the fuser. Toner cartridge is just the toner and the drum together in one unit. The fuser is where it warns "high temp! do not touch!"
Just buy another printer or use the backup printer. Again, this is NOT something you can fix by yourself.
Mar 17, 2008 | Computers & Internet
HP laserjet 2600n
You are spilling blue toner. Try to vacuum out the excess blue toner from the machine. Be careful not to scratch the transfer belt.
Dec 13, 2007 | HP Color LaserJet 2600n Printer
27 people viewed this question
k24674
