Question about Mitsubishi WD Televison & Video
Model wd-62827 - WD Mitsubishi Televison & Video
  • 744 Answers
I have a mitsubishi wd-62827 tv. How do I access the bulb to replace it? Do I take the back of the tv off or the front?
on the back bottom right corner there are 2 Phillips screws holding a vent cover remove that, should have a small tunnel the lamp screws you can turn by hand pull handle to remove your lamp
Jul 03, 2011 | Mitsubishi WD-62827 62" Television
WD-62827 62 in. HDTV Television: mY LAMP WENT OUT ND NEEDS TO BE REPLACED, IS THIS ...
yeah ive had this tv for 4 years replaced lamp when i got it then about a year ago there was a but power surge that ruined 2 pc monitors and that lamp just google WD-62827 replacement lamp pick a place to buy from the only tool you'll need is a phillips screwdriver
May 17, 2010 | Mitsubishi WD-62827 62" Television
My mits 62827 doesn't show the composite inputs, hdmi inputs, and the front tv input and they don't work when I plug stuff into them. I have tried to reset the tv, and tuned it off and unplugged it but it...
This set should have a soft reset and a hard one---try the soft reset first----with the set on and using the Mitsubishi remote MENU, 1, 2, 3, enter.
The set should turn off and come back on. Check to see if the missing things are back. Usually this happens if there was a momentary power outage etc.
You may have to auto program the set and on some models it removes labels(instead of DVD etc it will say video input) BE DONE OVER.
Let me know what happens and if you need help let me know.
If this helped you rate this solution as I do this here for free.
SD TECH .
Dec 14, 2009 | Mitsubishi WD-62827 62" Television
Mitsubishi WD-62827 shuts down after pushing the device button.
With the remote press menu 2470 enter then do a system reset after the set has reinitialized this should fix your problem, you will have to reprogram your channel settings afterwards though.
Oct 17, 2009 | Mitsubishi Televison & Video
Green Flashing Light - TV Powers Down (WS 62827)
Initialize the settings by pressing "menu, 2, 4, 7, 0, enter". After settings have been initialized, press the system reset button on the front of the TV.
Aug 08, 2009 | Mitsubishi WD-62827 62" Television
Mitsubishi WD 62827 pictures flashes colors
TAKE THE BACK OFF AND LEAVE IT OFF . NOW TRY IT. IT WORKED FOR ME STRANGE BUT IT WORKED
Apr 27, 2009 | Mitsubishi WD-62827 62" Television
Whites and Light Blues Very Pixely
If it's happening on all of your settings, It's probably going to be a problem with the DLP light engine. That TV came out in 2005, right? Did you buy it brand new, or as a floor model etc.? In any case, it's more than likely out of warranty and going to be a pain in the wallet. Best Advice I can give you with this info is hold out for some price cuts this holiday season. Sorry I couldn't be of help.
Nov 07, 2008 | Mitsubishi WD-62827 62" Television
Re: black line across the top of screen!
Is it a bias line or is it there constantly? A biased line goes away as the set warms up and that could be caps in the digital board. If it's there all the time the LE or color wheel could be bad. Need a bit more information on this to be helpful.
Bill
Apr 29, 2008 | Mitsubishi WD-62827 62" Television
Mitsubishi WD-62827 Problem
Uh Oh! Unless this is something simple like a loose piece inside the projection chamber shadowing the screen it would have to be the light engine ($$$) warping due to overheating of its plastic housing. Check inside the cabinet for loose objects in front of the lens, then clean all the fan filters, then call your warranty company.
Hope Ya Fix It!
Jan 15, 2008 | Mitsubishi WD-62827 62" Television
Vertical line down the center of screen
A WD62827 is a V30+ chassis and is a DLP format projection screen Tv, not a flat screen, am I missing something?? For the symptoms you're describing with a WD62827 remove and reseat the DVI cable between the chassis and optical engine. If removing and reseating the DVI cable does not resolve the issue you may need to replace the Optical Engine part # 938P019020
BTW the current software version for this unit is 7.04.1F if you have anything less you might think about updating the software also..
Hope this helps!
Bill
Nov 29, 2007 | Mitsubishi WD-62827 62" Television
Televison & Video Logo
43 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
