Question about Plumbing
I need to know the position of the shaft seal inseide my Grundfos JPS4 230V 1 HP Pressure Booster Pumps motor please.
2 Suggested Answers
  • 3 Answers
SOURCE: My Grundfos JPS4 1 HP Pressure Booster Pump keeps coming on for a
Definately sounds like a leak in the pipes from the pressure side of the pump onwards, even the smallest leak will cause it to turn on to regain adequate pressure.
Posted on Jul 09, 2009
Pump keeps blowing house fuse
It is likely that the shaft seal in the pump has failed and the water is leaking into the motor. Water and electrics = fuse blowing!!
Oct 12, 2013 | Grundfos MQ3-35 3/4 HP Pressure Booster...
I have low pressure at house, There is no problem
I am just guessing but it appears there is a restriction such as a partally closed valve.
Sep 01, 2013 | Grundfos Pumps Grunfos UP15-42F 1/25 HP...
Grundfos pump
It sounds like you have a bad pressure switch. I would also check the pre-charge pressure in the expansion tank. This needs to be 2lbs less then the "cut-in" pressure of the switch IE: 30-50 switch 28lbs air in pressure tank.
RJH2O
May 11, 2013 | Grundfos JPS4 1 HP Pressure Booster Pump
Grundfos water pump is humming with no turning, if I take pump cover off and turn the shaft it starts?
Sounds like it could be a blown capacitor in the motor. Disconnect from the power supply and remove the capacitor - it is usually situated undet the terminal box cover- examine it for leakage or distortion and replace it if necessary.
Jan 04, 2011 | Grundfos JPS4 1 HP Pressure Booster Pump
Grunfos pump that even when all outlet valves are off the pump keeps kicking in an out?
sounds like you have internal leakage therofore pressure decreases and pump cycles to regain it.
not sure what you actuating mechanism is. if its a diaphram it needs to br replaced. if its multiple pistons- your seals need replacing.
Mar 03, 2010 | Grundfos JPS4 1 HP Pressure Booster Pump
How to remove the impeller off my Type UP26-96F Grundfos circulation pump
Most of these style knock off in a counterclockwise direction. The impeller is usually threaded onto the shaft that way. A small brass drift and hammer should move it easily.
Jan 08, 2010 | Grundfos JPS4 1 HP Pressure Booster Pump
How do you take off motor
1. Disconnect the booster pumpset from the power
supply.
2. Take the pump frontcase off by taking the bolts
holding it.
3. Take the pump impeller from the shaft. This is
either bolted or screwed to the shaft that is
actually an extension of the motor.
4. Carefully take the mechanical seal off from the
shaft.
5. Unbolt the pump backcase, from the motor,
6. Now you have the motor separated from the pump.
Nov 16, 2009 | Grundfos JPS4 1 HP Pressure Booster Pump
SOUNDS LIKE YOU HAVE A LEAK DOWNSTREAM PROBABLY UNDERGROUND. THE PUMP HAS NO REASON TO COME ON EXCEPT TO BUILD THE PRESSURE BACK UP. HOPEFULLY YOU HAVE A GAUGE IN THE DISCHARGE LINE YOU CAN WATCH IT DROP AFTER THE SYSTEM SHUTS OFF. HOPE THIS HELPS, JODY
Apr 27, 2009 | Grundfos JPS4 1 HP Pressure Booster Pump
Plumbing Logo
80 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
