Question about HP Deskjet 1510 Allinone Inkjet Printer Copyprintscan
Copy feature provides cloudy results
Copies contain dark patches in random locations on copied page.
  • Robert Murphy
    Robert Murphy Mar 31, 2015
    Thank you, that seems to help.
  • HP Master
  • 1,680 Answers
Is the print function perfect ? if not
perform a self clean and or replace inks
Posted on Mar 31, 2015
Its me again,after the user changed a new toner cartridge after few copies there is a dark back ground in copy.before replacing the toner the copy was perfect pls help me in this problem
Hi, After a few copies, the toner supply unit pulls more toner, which results in dark copies. To fix this, you have to reduce the contrast (to minimum). Also, make sure that there is no excess toner within the toner supply unit.
Hope it helps! Good Luck! Thanks for using Fixya! CreativeTECH
Sep 27, 2011 | Panasonic Workio DP-4530 Copier
DARK SPOTS
Are the dark spots random and moves location with every copy or are they at exacly the same place on every copy? Random you will need to remove the drum/toner and use a blower to clean the inside of the machine,failing that replace the drum unit.If the spots don't move clean the top glass.Let me know
May 21, 2009 | Sharp AL-1641CS Laser Digital Copier
Dark copies with overprinting
Cleaned the coronas as per instruction book. Done this before but this time it made a difference.
May 07, 2009 | Lanier 1205 Copier
Ricoh Aficio MP C2550 does not default to one to one copy after use for 2 to one (front to back) the next person to use it gets charged for 2 copies when they only wanted one.
The machine should be set up so that it resets each and every time the card is ejected.
You might find the setting in user tools, but some where on the machine there should be a setting that resets the machine upon card removal. typically machine are set to reset after so many seconds of inactivity, but on coin and or card controlled machines you want the reset at card removal. You may have to have your service tech come in and set it up as it may be in Tech settings, if not in usee tools on your machine.
Hope this is of some help.
Ed
May 06, 2009 | Office Equipment & Supplies
Bad copies on our Canon ir2200
Most likely the fixing film needs to be replaced. A few years ago Canon made the fixing films available to authorized dealers.The film itself should only cost a few dollars.The other thing might be the Drum unit itself.They are not so cheap.Independent dealers and service agents are generally cheaper than say, Ikon or Danka
Mar 26, 2009 | Office Equipment & Supplies
Darkening the copies
Here's information from the HP manual:
Use the copy features
The HP All-in-One enables you to produce high-quality color and black-and-white copies on a variety of paper types, including transparencies. You can enlarge or reduce the size of an original to fit a specific paper size, adjust the darkness of the copy, and use special features to make high-quality copies of photos, including
borderless copies.
Press Copy repeatedly to display the appropriate menu. The following menus are available:
– Number of copies
– Reduce/Enlarge
– Copy Quality
– Copy Paper Size
– Paper Type
– Lighter/Darker
– Enhancements
– Set New Defaults
2. Press the until the appropriate setting appears.
3. Do one of the following:
– To change more settings, press Copy.
This selects the current setting and displays the next menu.
– To start the copy job, press Start Color or Start Black.
To save the current settings as defaults for future jobs
1. Make any needed changes to the settings in the Copy Menu.
2. Press Copy repeatedly until Set New Defaults appears.
3. Press until Yes appears and then press OK.
This should help you.
Feb 20, 2009 | HP Officejet 5610 All-In-One InkJet...
New scx-4521-FG/ too much fad
The darkest copy setting is obtained when the contrast is set to dark and the toner save is turned off. If the originals being copied are too light, this unit has trouble seeing the image and the copies are extremely light as well. If the originals are good and dark, try using original toner cartridges.
Be blessed.
Oct 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
We can't take copies and prints with our hp officejet 6110 all-in-one printer.I think we've got this problem because;we haven't got driver for our printer. Thanks for help.
The person making the clarification request is right. Even if your printer isn't connected to a computer, it should still be able to copy. That means it probably isn't a driver issue.
I did find a page at the HP web site that talks about troubleshooting copy problems. The web page is pretty long but the link I'm providing should open the page to the right section:
Nothing happens when the copy button is pressed
Since you can't copy or print, it may be that the two problems have the same cause, such as a paper jam. Take a look at the contents on that link and see if it helps. Post back your results. Good luck.
Sep 21, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP 4650N Will not print more than one copy of a job
make sure when printing it has all checked off in the page range box instead of pages
Aug 28, 2007 | HP LaserJet 4650n Printer
HP Deskjet 1510 Allinone Inkjet Printer Copyprintscan Logo
Seeker5211
Seeker5211
