Question about Panasonic NN-H965BF Microwave Oven - Countertop - 2.2 ft - 1250W - Black 037988909117
How do I remove the display/keyboard panel - Panasonic NN-H965BF Microwave Oven - Countertop - 2.2 ft - 1250W - Black 037988909117
How do I replace the bulb for the display panel of a Sharp Microwave oven Model # R-314F ?
Normally switch power off and remove plug from wall socket, undo screws around side and back panel and remove outer cover, then the light socket will be visable so change light bulb and reassemble, CAUTION: high voltage may be present so best left to service person for safety
Jul 23, 2014 | Sharp Microwave Ovens
How to remove keyboard on dell xps L521X
Here's the repair manual which includes instructions on removing and replacing the keyboard. Grab a t5 screwdriver (or bit for your drill) from the hardware store if you don't have one. You'll need it to get into the back panel. Good luck!
https://www.hansonsgeeks.com/PDF/Dell/Owner%20Manual%20xps-L521x.pdf
May 29, 2014 | Microwave Ovens
Nn2555 display weak
In many cases , cockroaches are found to habit within specially when not used and can spoil the main board, panel display and connectors. Remove the front panel and board and confirm and if so you need to wash the board and reset. Also it can be due to failure of the display or drive from the board
Jan 30, 2013 | Microwave Ovens
Digital display of Bauknecht MCG 1731 micro-wave isn't readable in daylight.
If the microwave is workingg fine otherwise , then you can remove the display panel and see if there is dirt or insects that have clogged the display. Use a hair dryer to slighly warm the panel , check the voltage to the display panel from the main board and processor. If there is no issues here then it is possible that the display is weak and needs a replacement
Jul 11, 2011 | Microwave Ovens
I have a whirlpool microwave oven over the range. Model GH 5184xps-4 when I press start, it comes on for one second then it shows a code -F7- and stops
TOUCH PANEL & MICROCOMPUTER BOARD TEST FOR WHIRLPOOL....
The microwave oven may be provided with a self diagnostic routine that can be operated
through the touch pad keyboard. To enter the self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "O" (square) is displayed...
POWER FAILURE & FAILURE CODES
Power Failure: After a power failure, the WELCOME screen will be displayed.
F2 Keyboard Failure: Refer to the Tech Sheet and conduct a touch panel continuity test.
F3 Humidity Sensor Failure: Refer to the Tech Sheet and test the sensor.
F6 Microwave Relay Failure: Check the microwave relay.
F7 Microcomputer Board Failure: Change the microcomputer board.
Hope helps.
Apr 12, 2011 | Whirlpool Microwave Ovens
Display panel has lost most of its dots. can't read it
debe ser revisada por un tecnico por que parese ser la targeta de control da?ado por incectos o por cucarachas
Oct 05, 2010 | Sharp R-1750 Microwave Oven
My GE Spacemaker XL1800 ovenstarted to show F3 error message and three beeps. Keyboard except light and fan keys was dead. Disconnected it from the wall outlet and forgot about it for three. weeks....
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
I would need to know your actual model number to tell you exactly, but on GE most models you can replace the control panel assy, which comes with a new keypad, and that's an easy DIY job with a part cost of about $100, sometimes less.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Next, disconnect the strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
You can find exploded view diagrams and order parts here.
Dec 25, 2009 | GE Microwave Ovens
Sharpe Microwave R-316F Display Light
first remove the outer cover by removing the screws at the back.then u should see a screw behind the control board that holds it.remove that screw and the control board comes out.disconnect the wires from control board and remove remove the panel assly.then remove the screws that hold the control board to the panel.
Aug 18, 2009 | Sharp R-316FS Microwave Oven
How do I change a fuse in a GE JVM 1440 microwave oven? I have looked at all supporting material and do not know how and do not want to mess it up without having instructions. Thanks
Remove 2 screws from front vent cover and removed vent cover
Remove one screw from top of display
Gentley push display panel up about 1/4 inch and tilt the top toward the front.
Disconnect 3 thin gauge molex connectors
Disconnect 1 heavey gauge connector
Remove screw from grounding wire at botton of display curcuit board
Remove display panel completely
Remove grill from above display area
To the left is a 2 x2 inch square board
Coil, capacitor and fuse block
Remove fuse
Check fuse rating
Match fuse rating and replace
Jan 28, 2009 | GE JVM1440 Microwave Oven
Keypad on microwave wont work
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "—" is displayed...
POWER FAILURE &FAILURE CODES
F2 —Keyboard Failure: Refer to the Tech Sheet and conduct a touch panel continuity test.
F3H —Humidity Sensor Failure: Refer to the Tech Sheet and test the sensor.
F6 —Microwave Relay Failure: Check the microwave relay.
F7 —Microcomputer Board Failure: Change the microcomputer board.
Oct 18, 2007 | Microwave Ovens
Panasonic NN-H965BF Microwave Oven - Countertop - 2.2 ft - 1250W - Black 037988909117 Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
