Question about Kenmore Elite Central Water Whole Home Filtration System
Installation manual for Sears water filter model # 625755
Model # 625755 Code# 08163 S/N 1516
3 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: HEPA FILTER REPLACEMENT
Looks like there are is an 2 indentations on the back, these are tabs, push them in and push the cover up, it should come off.
Posted on Jan 29, 2008
blueextc3221
  • 15935 Answers
SOURCE: Sears washer model number11045087400 stopped
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Does anybody know where I can download an "Owner's Service Manual" for a MURRAY 40607x9a. I think I have tried everywhere. Thanks, Rich Fowler
according to sears, It doesn't exist Copied from website.
Can't locate your model number? Use our finder
Choose your product type Select
Common model number plates model_number_finder.png model_number_finder.png View sample model numbers by selecting your product brand Select close.png Change your water filter every 3-6 months. Get FREE SHIPPING with reorder. Shop Water Filters End Change your water filter every 3-6 months below search -->
0 results for model number: MURRAY 40607x9a
May 13, 2016 | Murray Garden
Looking for a manual for sears kenmore portable sewing machine model 158.13200
Search the internet for:
Manufacturer + Model + the word "Manual"
Nov 22, 2015 | Kenmore Sewing Machines
Looking for water filter
The model number is probably ET8WTKXVB00 . If this is the correct model, it does not have a water filtration system. The manual is available from http://www.managemylife.com/mmh/owner_manuals/6142/WHIRLPOOL-Top-Mount-Refrigerator-L0604713?brand_name_search=ET8WTKXVB00 . Sears Parts Direct and other appliance parts stores have the parts diagrams and most replacement parts for the ET8WTKXVB00. No filter is listed and no add-on water filtration systems are available for the refrigerator.
I hope this helps. You could put a whole house filter before the water line gets to the refrigerator if you have a problem with the taste of the ice.
Sep 21, 2012 | Whirlpool Refrigerators
Cannot locate water filter for my kenmore Refridgerator 106-57562792
Yes the filter is only available on some models. This is noted in the manual next to the part description: Part 14 Water Filter (on some models).
The entire set of parts lists (including a replacement grill plate, if you want it) is available from Sears Parts Direct: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10657562792/0582/0165000?pathTaken=&prst=0&shdMod=10657562792 . The grill plate is part 13 on the cabinet diagram.
I hope this helps.
Sep 04, 2012 | Refrigerators
No water in spray arms
Since water is recirculated during the cycles, there is most likely a filter of some kind in the water path and that is probably clogged with debris.
Go to the Sears parts dept. and enter your make and model to see if they have your machine listed in their library. If so, there will be a line drawing of the machine so you can locate where the filter is located and possibly reorder from that same page. Sears carries or supplies parts for about every make and model.
Sears parts
Apr 26, 2010 | Frigidaire 24 in. FDB636GF Built-in...
Need a manual for sears model 139.18856, 1/2
According to Sears your model number is bad. Double check the number and they will have the owners manual with complete installation instructions.
Sep 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Does the refrigerator model #363-9554710 have a water filter? and if so where is it located?
Hi: It would appear it was built in or about 1995 unless Sears has changed there modes numbers again. Most likely no. If there was a factory installed water filter it would hang down in the upper right section of the fresh food compartment. A plug might also be installed there to bypass it. It would look like a big plastic wing nut. If someone installed an aftermarket water filter it would be behind the fridge and you would have to pull the fridge from the wall and check. I hope this helps, Jeff
Jun 12, 2009 | Refrigerators
NO...I am looking for a KenmoreFilter # 69768 Purshase at Sears and they DO NOT carry the filters.Its time to change the water Filter. Please see if you can help me. Wanda V.Neal wanda_v_neal@hotmail.com
If anyone is looking for the Kenmore Coffee Water Filter model 69768 - Sears / Kmart re-branded the filter under the Cuisinart name making them near impossible to find under the Kenmore name. HERE is the link to order them under the Cuisinart name at SEARS (its the EXACT same filter and they come 2 to a pack)
http://www.sears.com/shc/s/p_10153_12605_00869768000P
Apr 19, 2009 | Oster 10 Cups Coffee Maker Model 3297-053...
Kenmore Elite Central Water Whole Home Filtration System Logo
432 people viewed this question
Top Kenmore Water Filters & Coolers Experts
John Tripp
John Tripp
Tom Chichester
Are you a Kenmore Water Filter and Cooler Expert? Answer questions, earn points and help others
