Question about Toro Garden
What is the compression on a 17.5 hp wheel horse riding lawn mower
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 13 Answers
Likely between 7.5:1 and 9:1 compression...
Posted on Jun 26, 2015
woobie dog
  • 1273 Answers
SOURCE: put the wrong oil in my riding lawn mower. Should
It should be OK, provided no damage was done to the engine when you ran it. Hopefully, you caught it quickly. Just to be on the mechanically safer side, I'd change the oil again. If your mower is equipped with a filter and you didn't change it after the 2 cycle happening, change it, too. If you have a filter, always fill the filter with oil before you mount it if the orientation of the filter allows. Fill the engine with oil. Check and start. There may still be some smoking until you clear the residue out, and you may even have to clean your spark plug(s) a time or two. You should see a gradual improvement in your exhaust plume. If any damage had occurred to your engine, you will likely hear abnormal sounds. If this is the case, shut the mower down immediately and investigate forther, with your local professional.
Best Regards! --W/D--
Posted on Jul 11, 2009
  • 72 Answers
SOURCE: Mower Deck not level
there is a geared bolt at the deck suspension un lock it and rotate it will raise and lower the deck
Posted on Aug 04, 2009
  • 78 Answers
SOURCE: honda lawn mower wheel drive works, but needs adjustment, how?
Take the covers off the drive,there should be a hollow bolt the cable comes thru, it should have 2 adjustment nuts This lengthens or shorts the cable. There also may be a adjustment on the handle.
Posted on Oct 27, 2009
  • 89 Answers
SOURCE: craftsman lawn mower wheels won't turn
take cover off the top off deck and see if your belt have came off next turn deck sideways but before you turn it sideways take air filter off cause oil can come through and ruin the filter noe look and make sure the belt is on the pully
Posted on Nov 04, 2009
SOURCE: 10 year-old lawn mower Craftman Eagle 1, 6.5 horse
sounds like the main jet is blocked. remove it and run a piece of fine wire through it and retest.
Posted on Nov 28, 2010
I need a picture diagram of the drive belt the way it goes around pulls my belt broke on viking automatic 17 HP Intel model#mt435h
If you cannot find a website where you can type model in and find pattern you will have to call mfg. And have them fax or email you one.
Aug 03, 2017 | Garden
I need to locate a owners manual for a wheel horse 1978 312-8 tractor
I have found this older printed manual of a Wheel Horse lawn tractor for sale on the internet.
http://www.atomicmall.com/view.php?id=705372
I have NOT located the manual for your exact model yet.
Jun 12, 2011 | Garden
My toro wheel horse tractors & riding mower 31-12K801 312-8 keeps backfiring when I am mowing the lawn and stops and will not turn back on until you let it set for awhile. I had replaced the spark ...
I had a mower with exactly this behavior. Mine had a 14 HP Kohler Engine. After considerable frustration, we replaced the electronic ignition module, and it has worked perfectly since then.
Aug 17, 2010 | Sport & Outdoor - Others
3.5 horse power rideing lawn mower 638 R L yard machine by M T D
There is no such thing as a 3,5 hp riding mower,a serial number or a model number would help,along with an actual question.
May 17, 2010 | Mtd Garden
How do I change the drive belt on a 17 horse Craftsman lawn tracton number 917.252531.
Page 24 of the manual:
http://www.managemylife.com/mmh/owner_manuals/23145/CRAFTSMAN-Lawn,-Tractor-L0909236?brand_name_search=917252531+CRAFTSMAN
May 08, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The starter will not crank over the compression stroke
You needv to check whatever the tractor uses for a decompresser,whether it be a lobe on the cam or the camshaft it's self.Sounds like it's not decommpressing during crank.You may need to just set the valves.
Oct 23, 2009 | Garden
I have Toro Wheel Horse riding lawnmower model # 70040 - 790000
need the ser number of the unit. the pulley don't split its one part, i need the ser number . this is no easy job. good luck
Oct 13, 2009 | Toro Lawn Mower With Toro Power Tools
17 HP Briggs & Str lawn mower engine that is smoking a lot -
compression test it can either rent or buy one should be over 90psi!!!
Jun 28, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a 1987 craftsman riding 17 horse mower. I
Sounds like the rings are worn and letting oil escape past them into the cylinder head. After all, it's been in service a long time. There are several options, including a rebuild with boring out the cylinder and put oversize rings in, buying a new engine and replacing the old one, or just buying a new mower.
Sirwriter
May 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
87 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
