Question about Winter Sports
I have a 2005 Skidoo 600 Renegade SDI just wondering if there is anyway of running it without the battery
4 Suggested Answers
MrScary66613
  • 1990 Answers
SOURCE: 2005 Jeep Liberty Renegade Differentials
This totally depends on how Much "Hard Driving" that you do. Offroad, 4x4 all the Time, ETC.... If you do I would Change at every 50,000 If not Every 80,000 is OK
Posted on Jan 10, 2009
mike0862
  • 5530 Answers
SOURCE: My uncles 600 sdi expedition ,, will run on a fully charged battery ,.. But while riding the snowmobile will discharge battery and eventually cut in and out and stop .. Relays have been switched aroun
Sounds like the alternator is faulty!
Posted on Jan 04, 2015
Testimonial: "This is what im thinking also .. But also thinking maybe a chafed wire or bad ground could be discharging or not charging the battery, should this snowmobile run without a battery , should the stator generate enough energy to run snowmobile , if so how can i trouble shoot the stator , how much voltage should it be putting out on which wires ? Thanks"
  • 1162 Answers
SOURCE: 2004 600 sdi ski-doo missing at 4500 rpm
have you checked the plugs? they could be fouled or a build up of carbon. have you checked or rebuilt the carb, if so did you change the fuel lines they could be cracked and sucking air.
Posted on Jan 30, 2015
Testimonial: "new plugs. sdi so no carbs and throttle body was cleaned"
2005 skidoo 600 with sdi. Starts dies in a couple of seconds will not go into high idle pulled plugs and there wet.
Likely one of two things
1) Bad spark quality, bad plugs, incorrect gap etc.
2) Lack of spark to the plug
Get a spark tester, cheap and easy at the auto parts store, and start there
Feb 20, 2017 | Cars & Trucks
2003 skidoo legend 800 sdi 2tek. Temp gauge quit working
Check the wire coming out of the sensor to ground with an ohm meter, as the motor warms up, it should change. If it doesn't its the sensor, if it does its either the gauge or the wire going to the gauge.
Dec 30, 2016 | Winter Sports
What type of oil should I use in the 600 sdi, synthetic or regular
I am skidoo fan and I love the sdi motor!!! absolutely bullet proof!!
I am a firm believer in using BPS synthetic oil, it usually says what type of oil it requires right by the oil fill cap....go with manufacturers recommendation
Mar 14, 2015 | Ski-Doo 2009 Expedition TUV 600 H.O. SDI
Can plug wires be crossed?
I have the Same Sled and It runs pretty good. Love the fact that it can start with the push of a Button but to answer your question, the Wires are separated so that they should automatically go to the Right Cylinder and if I remember correctly, they SPARK identical so if they do fit (Mine Won't) it should start anyways. a DEAD BATTERY will not allow the sled to start, it is SDI (Semi-Direct Injection) and it requires power to Work....
Feb 24, 2015 | Ski-Doo 2004 Legend GT Sport 600 H.O. SDI
I have a 2005 skidoo rev 600 sdi and it wont start it has spark and it is getting gas I don't know whats wrong
Air, fuel, compression and spark. check those, figure out what you don't have. But 9 times out of ten the carb needs cleaned. And that does not mean blowing some carb cleaner in there and saying "well I cleaned the carb and it still wont work" like half the guys on here. to clean a carb you must disassemble it.
Feb 16, 2015 | GAS Motorcycles
Skidoo has no pick-up power
I am assuming that you have checked the following?
Compression
Replaced Spark Plugs
Cleaned the Needles (Making sure you can see through the Center of the Jet
Nov 30, 2013 | Ski-Doo 2006 Mach Z Adrenaline 1000 SDI
Skidoo renegade 800 will not go into reverse
did you see if the brakes or anything under the car was not hanging underneath it?
Jan 18, 2013 | Cars & Trucks
Winter Sports Logo
471 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
