Question about John Deere L100 Series
Blows fuse every time i engage blades - John Deere L100 Series
  • John Deere Master
  • 1,169 Answers
Shorted Pto Clutch coil if electric clutch is used. Min Resistance is 1.5 Ohms for the coil.
Posted on Mar 31, 2015
I have a husqvarna loyth20f42y riding mower it wasn't starting replaced the solenoid and ignition switch. now it starts but every time I engage the blades it blows the fuse
Because it blows when the blades are engaged, it is probably the PTO switch or electric clutch. You can check both quickly with a multi-meter. The clutch should ohm out at 2-5 ohms.
Oct 30, 2016 | Husqvarna Garden
What causes fuse to blow every time I try to engage blades?
To engage the blades is it a knob to an electric switch that you pull?
If so does the wire from the switch activate a electric clutch?
Is the wire damaged and shorted to the frame, is the clutch shorted. If you provide the brand name and model number I might be able to find a schematic for your mower.
Video shows an electric clutch but yours may be different but this should give you an idea of where to look. Riding Mower Electric PTO Clutch Won Engage When Hot Problem Fix
Oct 02, 2014 | Garden
Fuse blows when i engage blades on my bad boy ztr
Is the fuse a 15 if so there could be a short some where.
Oct 02, 2012 | Garden
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
http://www.lawnsite.com/showthread.php?t=164509&highlight=clutch+adjustment
Nick
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My swisher zt blows the fuse every time i engage the blades...can get the engine to run and drive. problem is only when i start the blades. any ideas?
Check the all wiring from the engage blade button back to the electric clutch for worn spots that may be grounding out on the frame.
Sep 17, 2010 | Swisher Zt2560 Zero Turn Radius 60" Riding...
Blowing fuses
try unplugging the pto, starting the mower and then engaging the blades. If it still blows a fuse the problem lies in the mowers wiring. If not the problem is the pto. Hope this helps
Jul 13, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
FUSE BLOWS WHEN BLADES ARE ENGAGED CRAFTSMAN MODEL # 917.27686
Most probably you have a wire shorting to the frame of your mower.
Trace (follow) the wires from the switch, checking for any frayed, burned, or bare wires.
Repair as needed.
Apr 17, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
Apr 04, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere L100 Series Logo
87 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
