Question about Miscellaneous
How do I fix a T12 lighting fixture without the normal starter plugins? In a cold/warm exchange moisture got in the circuit board starter and blew components.
I have a double T12 fixture that was cold, then warmed up and condensed moisture on the starter circuit board and blew some components. How do I tell what the components are I need to unsolder and replace? I can see two that are obviously damaged, i.e. perhaps resisters or capacitors etc. I can supply a picture of the circuit board. It was not a normal fixture with a plug in starters.
SOURCE: Power Surge damage. Suggestions on which part to replace.
I would start looking at the power supply, it's usually a separate board where the a/c line plugs into. In many cases i have seen that the problem you described is from a damaged power supply, sounds like something is shorting causing the power supply to continuously come on and off. I would first check the capictors to see if any of them have blown, usually cylinder looking and sometimes you'll see an X or a K at the top of the cylinder, if it's blown then the top will be bulging out instead of being flat. If all those look good then there is probably a short somewhere else like in one of the transistors, if so you'd be best to just find another power supply board to replace.
Posted on Nov 09, 2007
22yooper
  • 828 Answers
SOURCE: Frigidaire side by side fridge
Power to compressor must be off (about 5 minutes) before a restart should be tried. Some of these relays are thermal and must cool down before power is reapplied.
Posted on Sep 15, 2008
meBNme
  • 334 Answers
SOURCE: hello i have proble with air conditioner and heater is a split system unit
What its telling you is that there is an outdoor "thermostat" that senses the outdoor temperature.
The system has found a failure on this area.
It is telling you to check the sensor to see if its actually the sensor thats bad, or something else.
Then its telling you to check the wiring and connection of the sensor to the control board for any loose wiring or broken connections, and to repair it if so.
It then says if niether of those two checks reveal any problems that the problem is the board itself and it should be replaced.
To answer the question, resetting it probably will not work.
There is a small chance that due to power surge, flickering lights, or just a fluke one time glitch that there is nothing rally wrong and resetting would work.
95% chance that is not so.
Posted on Dec 10, 2008
CarlGehrke
  • 169 Answers
SOURCE: PM0435003 Powermate - Damaged Capacitor on Board.
Yes, having a leaky capacitor in there could prevent the generator from making electricity. This capacitor is the voltage regulation on brushless generators, and it's the smoothing cap on the models with brushes. I wrote a somewhat long explanation of how to troubleshoot powermate generators that may be of help.
Since writing that post I've found that the Pramac company has started suppling parts for powermates, you can find them at www.powermate.com One used to be able to obtain a brand new board from the company but not any of the individual parts. If you're going to go the "Radio Shack" route, I suggest that you also check all of the diodes on the board, they may have been spiked when the generator shut down under load. I wouldn't think your stator windings or your rotor windings got hurt, but since you've go tthe thing apart it can't hurt to check them.
Regards,
Carl
Posted on Dec 15, 2008
Matampong
  • 153 Answers
SOURCE: monitor fuse keeps blowing
There is definately a shorted component that causes the fuse to blow. Nomaly the ceremic capacitors are the cause of the problem. Check to see if there is visiual dark or burnt ceremic caps with label sameting like this "SCK 083" near the fuse area and change it. Hope it helps,cheers.
Posted on Jan 22, 2009
I have a T12 fluorescent light fixture and replaced the bulbs and ballast. I have double checked all the wiring connections. I get the bulbs to light when I move the bulbs, but only for a second.
Your description sounds like the connectors for the tubes. Also RECHECK wiring. Different on newer ballasts. See below...
Turn off fixture, unplug, or deactivate fuse...
Pull out bulbs and the tin fixture cover/reflector.
Extract the bulb connector. Go to hardware and buy 4 more, and just replace them. The connections fail where the wire connects and the rigours of bulb replacements damage this piece. TONS easier to get new pieces.
ALSO!!!! many new (fancy schmancy) ballasts WIRE UP completely differently from the old ballast. Follow the wiring diagram on the NEW ballast. This detail trips up many.
Doc
Sep 13, 2016 | Photography
My brand new shoplights flicker nonstop. Both of them. Bulbs are gef34 cw c41 eco hg. Lamp calls for f40 t12 in 25, 34, & 40 watt varieties. Am i using the wrong bulbs? or are my lights garbage?
Brandon, Do the lights have cold start ballast in them, if they do best to use cold start bulbs. press the helpful button
Do not put two different size or make of bulbs in the same fixture.
Feb 07, 2016 | Dryers
Zanussi condenser dryers
It can be mechanical or electrical malfunction. I would check tank microswitch, float and lever.
Below is explained how the condensate drainage system works and that will facilitate fault detection.
The warm and cold air circuits cross inside the heat exchanger, which results in a thermal exchange which condenses the humidity contained in the warm air. The condensation which forms in the heat exchanger is collected in a sump, from which it falls by gravity into a tank. When the water in the tank reaches the max. level, the level of the water in the sump increases, which causes the float to move upwards, thus actioning a microswitch; The microswitch for dryers with electronic board sends a signal to the electronic circuit when the tank has been filled, switches off the appliance and lights a pilot lamp which indicates to the user that the tank is full. The microswitch with electromechanical control switches off the dryer (the timer motor is powered and ends its cycle) and lights a pilot lamp which indicates to the user that the tank is full.
Dado
Aug 10, 2014 | Zanussi Dryers
Edgestar wine cooler blowing fuse on the left side circuit board
If you have replaced the circuit boards it's probably associated with a wiring short circuit or compressor failure. Suggest you get a professional technician to further investigate the fault. In the interim check for a short to the frame of the unit, an internal light or for moisture issues or a condensation issue from water.
Mar 25, 2014 | EdgeStar ES TWR325ESS-32 Bottle Dual Zone...
Hello Expert. I have a few years old Samsung LCD 37in. model LE37A457C1D. Few drops of water got in from the top of the set, when it was off. When turned it on, darker 5inch wide vertical stripe appeared....
It is important that you do not switch the set on unless the board is cleared of moisture that is conducting the circuits to bridge and short causing the change in the pictures. so remove mains plug from the outlet , remove rear cover. now take out the main boards after marking the connectors and using a hair dryer warm the boards while looking for water logged into the circuits. You can also use a soldering iron the steam off if there is water within pockets in the board. Only when you are convinced that there is no moisture should the board be set back into the tv.
Apr 27, 2011 | Samsung Televison & Video
Micro wave range light blew out when turned on. Removed old bulb and it had some white plastic melted on it. Replaced the bulb, and the light doesn't work.
Your going to need to disassemble the light fixture to perform electrical work. Its possible in the process that you may have accidently blown something else. If so, be prepared to peform
units soldered connections on the main projection board warm up as the system warms up. Thus, the loose capacitors, resisters, and diodes are causing the CHANGE when the system warms up. When metal contracts, it expands thus losing the connection needed for a solid connection. This process is normal after the units have reached their service life. Keep in mind that you can repair this but at the expense of time if you have never performed this type of work.
Jan 26, 2011 | Whirlpool MH7140XF Microwave Oven
Replacing old flor 48" tubes
There are three types of fluorescent 48" bulbs t 12, t8, and t5. they are not interchangable. if you have a fixture that has a t12 type ballast, it will not light up the t8 bulbs. you have to change the ballast to a t8 style. just to clarify, the number stands for 10ths of an inch in diameter on the bulb. a t12 is 1.2 inches, a t8 is .8 inch and a t5 is .5 inch.
Nov 20, 2010 | Microwave Ovens
Cool white flouresent bulbs (t12) will work in fixture with trigger ballast but daylight (t12) will not work????
check the numbers at the beginning of the bulb itself,, be sure its for a regulated ballast not a electronic one depending on which ballast you have
Aug 01, 2010 | Home
When "cold", my Phillips cdc935 skips on the first track, only, of many of my cds. After warming up that is no longer a problem and successive cds, including the first one played, do not skip.
Open CDC-935 player and clean sled section (that moves optical lens left-right) as it seems dusty and causing skipping of cd tracks.
Hit "add a comment" button for further query / info.
Thanks.
May 04, 2009 | Audio Players & Recorders
Re: KitchenAid Coffee Pot
I had a similar problem with Err 1, Err2, and Err 4. To resolve Err 1, if you have room, remove the coffee filter and coffee, pour more "warm" not hot water into reservoir. If you have 4 cups cold water add 5 cups warm. Then start coffee maker and let it run thru. Then drain coffee pot and start over to make coffee with tepid water. Err 1 indicates the coffee maker temp sensor is too cold from room temp or water temp.
Err 2 is a result of cleaning. First question "Did you remove the charcoal filter?" The charcoal filter can be removed form the filter stick by prying two tabs away gently and removing the filter for removal. The filters can be purchased @ www.Kitchenaid.com
One pot run thru with descaler can loosen scale and make sensor go "blind". Just run a full pot of clean plain water thru one maybe two times. A pot solution should be a solution of 1/4 pot WHITE vinegar, 3/4 pot clean cool water. Run this thru once, then two clean pots of fresh water as if you brewed a pot of coffee. NEVER USE CLR WITHOUT RUNNING NO LESS THAN THREE CLEAN WATER POTS THRU MAKER!!!! This is so you can continue to enjoy drinking coffee, nothing like a cup cleaning you out!
Err 4 is simple, you have a stuck button. Unplug maker and gently press each button making sure they aren't stuck in.
Jul 20, 2008 | KitchenAid KCM511OB 10-Cup Coffee Maker
Miscellaneous Logo
Top Miscellaneous Experts
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
