Question about Dynex E23982 Main Board for DX-32LD150A11 DTV26/32 M6 V1.2 20091008, DTV32DAM6V1.2
System lock - Dynex E23982 Main Board for DX-32LD150A11 DTV26/32 M6 V1.2 20091008, DTV32DAM6V1.2
What is the best lock system for home safes?
There are three kinds of locking mechanisms used for home safes,
1. Lock and key system
2. Pass code system
3. Fingerprint system
The safes with above mechanism and also fireproof is an added advantage. You may check online for price comparison also.
Visit Fire Cabinets Direct to find the best safes for your home.
Sep 15, 2016 | Home Security
2002 yukon xl .My locks & alarm system dont work ! What do i do ? I checked fuses also
Power Door Locks Inoperative - All Doors and Switches ?
The MIR/LOCK fuse supplies battery positive voltage for the power mirrors, power door lock switches and the memory seat switch (if equipped). If the MIR/LOCK fuse is open, all systems on the fuse would be inoperative. The fault could be a short to ground in the battery positive voltage circuit, however, a short to ground in the power mirror motor control or the memory seat control circuits could also be the cause if the fuse opens after any of the switches are activated. If a short to ground exists in either the door lock or unlock relay control circuits, a DTC (B3137 or B3147) would set when the BCM commands a lock or unlock function.
Did you perform the Power Door System Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - Door Systems
Actuate all door lock switches to both the lock and unlock positions.
Did all the doors lock and unlock?
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
Go to Step 3
Did any of the doors lock and unlock from any of the switches?
Go to Power Door Locks Inoperative - One Door or Switch
Go to Step 4
  1. Install a scan tool.
  2. With the scan tool, command the doors to lock and unlock.
Did the doors lock and unlock?
Go to Step 12
Go to Step 5
5
  1. Remove the door lock relay.
  2. With a test lamp connected to a good ground, test the battery positive voltage circuits for the door lock relay at the fuse block.
Did the test lamp illuminate?
Go to Step 6
Go to Step 13
The Content Theft Deterrent function provides the theft deterrent by sounding the horn and flashing the headlamps and the park lamps when there is an unauthorized vehicle entry or there is tampering detected.
SECURITY Telltale The SECURITY telltale on the instrument cluster is controlled by both the VTD system and the CTD system.
The VTD system commands the instrument cluster to control the telltale only when the ignition switch is ON. The VTD system uses the telltale as a malfunction indicator. If a DTC is present in the VTD system when the ignition is ON, the telltale will be illuminated.
The CTD system commands the instrument cluster to control the telltale only when the ignition switch is OFF. The CTD system uses the telltale to identify system status.
Telltale FLASHING -- The system is in standby mode. The system is not ready to arm (a door is open).
Telltale ON STEADY -- The system is in delay mode. The system is ready to arm and is executing a time delay of 15 seconds before turning the lamp OFF and transitioning to armed mode.
Telltale OFF -- The system may or may not be armed.
Body Control Module (BCM) The body control module (BCM) monitors several inputs in order to arm and disarm the CTD system. The BCM controls the alarm function outputs. When the BCM detects an unauthorized entry (any door opened), the BCM applies ground to the horn, the park lamp and the headlamp relays. The BCM will send messages to the security telltale in the instrument cluster through the Class 2 serial data link. The BCM has the following 8 basic modes for operating the CTD system. The more detailed descriptions are below.
Off state
Idle state
Disarmed state
Ready-to-arm state
Arm initiated state
Arm delay state
Armed state
Alarm state
The BCM has the following 6 discrete inputs in order to monitor the CTD system:
Ignition 1
Driver door latch (door jamb) switch
Passenger door latch (door jamb) switch
Door lock relay
Door key switch
Passenger door unlock relay
The BCM applies ground once per second for approximately 2 minutes, or until a valid input to disarm the system is received by the BCM.
Check the door lock relay !
Jun 16, 2016 | Cars & Trucks
I bought a honda civic sport 2005 got it resprayed and i built it up and now the alarm keeps going off the key fob doesnt work etheir the battery has been flat . does any body no how to reset the fob or...
Programming
When
Remote control added or replaced. System malfunction.
How
Obtain all remote controls. A maximum of 3 remote controls can be programmed. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press lock or unlock button. Within 10 seconds: Press lock or unlock button of first remote control. System should now lock or unlock vehicle. Press lock or unlock button of second remote control. System should now lock or unlock vehicle. Press lock or unlock button of third remote control. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed remote controls.
IMMOBILIZER CAN ONLY BE SET BY DIAGNOSTIC EQUIPMENT
May 13, 2011 | 2005 Honda Civic
I have replaced the batteries on the key remote control but it does not work
Programming
When
Key added or replaced. System malfunction.
How
Obtain all keys. A maximum of 3 keys can be programmed. Close all doors and boot/tailgate. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press key lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press key lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press key lock or unlock button. Within 10 seconds: Press lock or unlock button of first key. System should now lock or unlock vehicle. Press lock or unlock button of second key. System should now lock or unlock vehicle. Press lock or unlock button of third key. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed keys.
NOTE: If less than 3 keys are to be programmed, remove ignition key after programming last key.
Mar 22, 2010 | 2005 Honda Accord
How to recode remote to vahicle
Programming
When
How
NOTE: If less than 3 remote controls are to be programmed, remove ignition key after programming last remote control.
Jan 18, 2010 | 2003 Honda Civic
2005 Chevrolet Silverado Automatic door locks
I assume you mean that the central locking system will not lock the doors but you can do so manually.
Get inside the vehicle and close all doors.
On each rear door, lock and unlock the mechanism manually a couple of times. In other words do not use the key pad.
Then leave both rear doors in the locked position (manual locking) and operate the lock button on you key pad to operate the central locking system. Wait a few seconds then hit unlock on your key pad and a few seconds later hit lock on your key pad.
If the system fails to lock your rear doors you will need to get the vehicle to an auto electrician to check out the issue and rectify it for you. There are a number of possible causes which cannot be identified without physically checking the system. So you will need to have this rectified by a professional.
Dec 04, 2009 | 2005 Chevrolet Silverado
Automatic door locks will not lock rear doors, they open fine when manually locked but will not lock with switch key fob or when put in gear.
You mean that the central locking system will not lock the rear doors but you can do so manually.
Dec 01, 2009 | 2005 Chevrolet Silverado
Display reads OPEN LOCK when I try to open dvd tray.
Samsung Home Theater Systems have a Dealer Lock or Tray Lock Function that prevents the disc tray from being opened.
There are four procedures for turning off the Dealer Lock function. Try one, then the other, to see which works on your system.
Unlocking Procedure 1 To turn off the Dealer Lock function, follow these steps:
  1. Turn on your Home Theater System.
  2. Press the Stop button on the front panel and the Power button on the remote control simultaneously for four seconds.
Note: Repeating the two steps above turns the dealer lock on again.
Unlocking Procedure 2 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Function button on the front panel for 3 seconds. The display shows the word Unlock.
Unlocking Procedure 3 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Open/Close button on the DVD player on the front panel for more than 4 seconds.
Note: Repeating the two steps above turns Dealer Lock on again.
Unlocking Procedure 4 To turn off the Dealer Lock function, follow these steps
  1. Using the HTS remote press the Menu button + 712, and the HTS will display CAN OPEN.
The Dealer Lock feature is mainly used by retailers to ensure that the display discs are not removed. However, parents of young children may find this feature very useful as well.
Jun 26, 2009 | Samsung HT-DS610 System
My camera on my sony ericsson w580i does not work any help please to fix it myslf
You can add flash menus, change camera driver, change acoustics, add languages with FSX
You can upload stuff to phone either with own_custpack method or via FSX
Rest all remain same. Here is a list a of directories with information. Download the stuff and upload them
ifs/settings/acoustic/ >> Acoustics file
ifs/settings/camera/ >> Camera driver
ifs/settings/display/ >> Display driver
tpa/preset/system/desktop/flash >> flash menus
tpa/system/layout/ >> layout.xml
tpa/system/system/mutlitmedia/mp/skin >> Walkman 2 skins
tpa/system/preset/multimedia/pe >> frames , clipart etc
tpa/system/preset/multimedia/av >> visualizations
tpa/user >> stock pics and themes…
pa/preset/system/settings >> startup and shutdown screens ! all are GIF but with no extension tpa/preset/system/sound >> all sound files
tpa/preset/system/menu >> the famous menu.ml
tpa/preset/system/fonts >> fonts !
/usb/audio >> locked music (can be deleted with FSX only but not with phone)
/tpa/user/audio/ locked music
/tpa/preset/default/audio/ locked music
/USB/IMAGE >> locked images.. can be deleted
/tpa/user/image/ >> locked images
/tpa/prest/default/image/ locked images
;Locked Themes -> /USB/THEME
;Locked Themes -> /TPA/USER/THEME
;Locked Themes -> /TPA/PRESET/DEFAULT/THEMECheck out the FS for more directories and locations icon_wink.gifPlease check out the customization of phone tutorial for more. You can use either own_custpack method or FAR MANAGe
thanks rate it................
Sep 11, 2008 | Ericsson Cell Phones
Dynex E23982 Main Board for DX-32LD150A11 DTV26/32 M6 V1.2 20091008, DTV32DAM6V1.2 Logo
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
